    Modlumi - Easy 3D modelling
    408 Posts 9 Posters 71.1k Views 9 Watching
      Not yet on the 0.14 the erase group on the Outliner! πŸ™‚
      Number version of the "Installer" file is always crypted !:) modlumi-9dd7225-Setup-x64
      0.14 on the desktop installed! πŸ™‚
        Request:
        does it possible to have the segment of the Arc Circle in the color of the axis after the first click ?
        When it's snaped on it of course!
        Now we have just the box message "On Red Axis"
          Request
          Have a Snap 3D when you Draw a Circle, a Polygon !
          Seems Rectangle and Arc Circle has yet that!
          Else it's a nightmare for make after a rotation etc...
            There is something with the display of Guide Lines! ?
            Create Guide Point fails..
            Create normal Guide lines is difficult!
            this function seems have regressed!
              Request
              Editing Points (geometry)
              Subdivide a line
              Push Pull a Line (s) like an extrude πŸ™‚
              Subdivision of a solid volume
              Multiple selection for multiple edition...
                Bug about Sweep ? 0.14 File .modl linked!
                bug_0.14.zip
                  Request
                  Sweep between 2 profils, 2 rails
                  Or more simple first : Sweep with % πŸ™‚ (like the Move Rotate existing)
                    Bug ? No Snap 3D for make the PushPull at the middle of a vertical side segment for example ?
                    Put a Point Guide or a Line help not more!
                      Request
                      When you have made a Push Pull on a face said 2 units
                      You click on another face = same Push Pull ! πŸ™‚
                        • pixelcruncherP
                          Modlumi 0.15 is out
                          Download it for Windows from https://modlumi.com/download/latest/windows, or open the browser version at https://modlumi.com/app/. If you already run 0.14 on Windows, it will offer you the update.
                          New feature
                          • Choose how many segments an arc has. As in SketchUp, type a count such as 12s and press Enter, or press + and -, before the first click or while drawing. Later arcs keep the count, from 2 to 360.
                          Fixes
                          • Textures show the right way up. Every image texture rendered upside down, including textures in imported SketchUp models. It was easy to miss on wood or brick and obvious on logos and text.
                          • Guide lines reach the edges of the view again. In 0.14 guide lines stopped partway across the screen and changed length as you orbited.
                          • Sweep tells you when the profile you point at has no face. Clicking an outline of edges with no face did nothing and showed no message. The status bar now says that the profile must be a face.
                          • The Windows installer is named after the release. The installer's file name and the version in Windows' installed apps list showed only a code such as 9dd7225. They now start with the release number: modlumi-0.15-f3066c8-Setup-x64.exe.
                          Full release notes: https://modlumi.com/docs/release-notes/
                          Thanks for the reports. Keep them coming!
                          • pixelcruncherP
                            Here's another plugin. Mind you, this is all vibe-coded; it doesn't have the same level of care as Modlumi itself. It's an experiment to see how far I could take the API and what was still lacking:
                            GitHub - thomasloockx/modlumi-kitchenmaker: Parametric kitchen cabinets for Modlumi, ported from IngeTrazo KitchenMaker V.2 for SketchUp (GPL-3.0)
                            Parametric kitchen cabinets for Modlumi, ported from IngeTrazo KitchenMaker V.2 for SketchUp (GPL-3.0) - thomasloockx/modlumi-kitchenmaker
                            GitHub (github.com)
                            If you wanna build your own plugins: https://modlumi.com/docs/guides/getting-started/
                            • KrassK
                              Krass
                              your link is off
                              Thomas I can't import image texture with the desktop version..
                              Krass
                              • pixelcruncherP
                                @Krass Thanks! The repository was still private by mistake; the link works now: https://github.com/thomasloockx/modlumi-kitchenmaker
                                About the image texture: I can't reproduce it here yet. Could you tell me:
                                • How you import it: Materials > New image material..., or a texture inside an imported .skp?
                                • What happens: an error message, or nothing at all?
                                • The image's format (PNG, JPEG, WebP, TIFF...), its size, and the folder it's in (for example, does the path have accents in it?)
                                A screenshot or the image itself would help too.
                                • pixelcruncherP
                                  @pilou About your request for a sweep between 2 profiles and 2 rails: is it something like this?
                                  You pick a start profile, an end profile and two rails. The section blends from one profile into the other, and the rails set where each section sits, how it turns and how wide it is. Closed profiles get capped, so you end up with a solid.
                                  Mind you, this is just a demo: a vibe-coded plugin to explore what we can do with the plugin API, not a fully fleshed-out tool. But I think it could become a nice plugin. Let me know if this is what you had in mind, or what's missing.
                                    This one above is perfect for the 2 Rails / Profils! Excellent for a speedy volume!
                                    Of course you can add a "scalling rail" like a third rail but...
                                    I had thought about also a more simple first : Sweep with % πŸ™‚ (like the% Move Rotate existing)
                                    So same face Start and End but with a different size! And only one rail !
                                    Both seems useful! πŸ™‚
                                    • KrassK
                                      Krass
                                      I'm reading the instructions carefully, but I can't manage to install the plugin.
                                      Krass
                                      • KrassK
                                        Krass
                                        for th image import issue, it works now.
                                        For hte kitchen maker plugin. Do we only have to download plugin.json and and pic it from the plugin manger?
                                        Krass
                                          Guide Lines and Points works as expected in Web version 0.15
                                          But absolutely not in the Desktop version 0.15 ! πŸ™‚ So Bug!
                                            Request
                                            Multiple Push Pull
                                            A random selection after a True Bend for example! πŸ™‚
