    Modlumi - Easy 3D modelling
    384 Posts 9 Posters 53.9k Views 9 Watching
    • pixelcruncherP
      Hey folks,
      I'm building Modlumi (https://modlumi.com/), a 3D modelling program that aims to be as easy to pick up as SketchUp.
      It's still early days, so expect rough edges. That's why I'm posting now: I build in the open, and early users' feedback directly shapes what I work on next.
      What I'm looking for:
      • Bug reports: crashes, weird geometry, anything that feels off
      • Workflow friction: where you got stuck or reached for a tool that isn't there
      • First impressions: what you liked and what confused you
      How to give feedback:
      • In the app: click the feedback button in the bottom-left corner (see screenshot)
      • Or reply in this thread if you'd like to discuss
      Thanks for giving it a try!
      Here's how to give feedback from within the app:
      Reply Quote 3
      • majidM
        majid
        Nice, very nice:
        I tried to "fillet between two lines using an arc; was not able to do.
        Also, selecting an edge on a face ; not able.
        And the rest: will message/email you or we will talk.
        • pixelcruncherP
          pixelcruncher Extension Creator @majid
          @majid Thanks man! Love to get your feedback.
          • pixelcruncherP
            Update: what's new in the browser version πŸš€
            A big thank-you to @krass, @majid and @rich-o-brien for their feedback. Your bug reports and suggestions shaped almost everything below. Here's what changed this week:
            Modelling
            • Selecting edges is much easier. Before, the face under the cursor usually won over a nearby edge. Now visible edges near the cursor get picked first.
            • Push/pull works in more places. You can now push/pull next to overhanging faces, pull up from an attached overhang, and push/pull where two volumes touch along an edge.
            • Typed push/pull distances follow the cursor, like in SketchUp. Drag into a wall, type 0.3, and it pushes in instead of out. Typed values also no longer pick up tiny rounding errors.
            • Explode for groups and components.
            • Zoom Extents with Shift+Z.
            • Snapping works better on edges seen in perspective, and to the point where a locked axis crosses an edge.
            • Fixed several geometry bugs: holes lost when tracing roof boundaries, nested faces, faces flipping when you draw edges on them, and arcs split by crossing lines.
            Files
            • Save and open Modlumi projects (.modl). You get Save, Save As, a marker for unsaved changes and a "save before leaving?" prompt.
            • SketchUp files open with their saved scene camera, so you see the model the way it was saved.
            • Save to Image downloads a PNG of your view.
            Look and feel
            • Lighting now comes from the camera, as in SketchUp, so walls facing you are no longer a dull grey.
            • Shortcuts work on AZERTY and QWERTZ keyboards. Letter shortcuts now match the letter printed on your key.
            • Menus release the keyboard as soon as you choose an item.
            Feedback
            • You can attach your SketchUp file to a feedback report, which makes geometry bugs much easier for me to reproduce. The feedback button is also easier to find now.
            Coming up
            • A native desktop version. It's the same Modlumi, running as a full app on your computer.
            • A Python scripting API. You'll be able to automate modelling tasks and build your own tools with Python scripts.
            Try it at https://modlumi.com. Please keep the reports coming! πŸ™
            Mike AmosM 1 Reply Last reply
            Reply Quote 2
            • majidM
              majid
              Shared some more ideas...
              majidM 1 Reply Last reply
                Mike Amos @pixelcruncher
                @pixelcruncher
                Keep them coming, more than a bit of a one stop shop imho.
                Shaping up very nicely, Sir.
                Reply Quote 2
                  You remake SketchUp ? πŸ˜‰ What is yours Ai Coding tools ?
                  Seems there is a problem after an Offset πŸ™‚
                  • pixelcruncherP
                    I'm a software engineer by trade, so I'm not coming at this as a complete newbie. But right now, I have been using GPT-6 Sol as my coding buddy.
                    Thanks for the bug report!
                      No drawing Rectangle By 2 Points in 3D Space ?
                      There is multiple selection but not Multiple Extrude ?
                        Else very very pleasant to use!
                          Reply Quote 2
                          • majidM
                            majid @majid
                            @pixelcruncher Did you receive any shared file, Sir?
                            • pixelcruncherP
                              Thanks! Can you try this again? This should be fixed now:
                              sweep-fix-demo.mp4
                              Keep those bugs flowing!
                                That is perfect ! Works in closed or not total path!
                                Even Section profil is not perpendicular to something!
                                And not on the path!
                                Very cool function!
                                1 Reply Last reply πŸ˜†
                                Reply Quote 3
                                • ntxdaveN
                                  ntxdave
                                  OK guys, I am feeling really stupid. I have tried the browser version, but I am not getting things right. How do I create a rectangle and give it the size? I tried to enter the dimensions, but it did not work. What am I not understanding?.
                                  Press F1...thank me later
                                    I believe there is a little bug somewhere! πŸ˜‰
                                    There is just the last faces who are yet in place! πŸ™‚
                                    I have verified in hide them ! πŸ˜‰
                                    Very cool that you have keept original " */ " of the copy functions !
                                      @ Ntx Dave
                                      Just Left DoubleClick for have the drawing of the Rectangle, then write 1,2 for a rectangle or 2,2 for a square Enter ! etc.. πŸ˜‰
                                      Or Just Press R , Left Click and Drag for see the Blue Rect , write 2,2, Enter for a square etc...
                                      It's quasi the same than SketchUp! πŸ˜‰
                                      ntxdaveN 1 Reply Last reply
                                        You have not: Inverse Selection ?
                                        There is no Snap in 3D Space of the second click of the Arc Circle ?
                                        • ntxdaveN
                                          ntxdave @pilou
                                          @pilou OK, I finally got it to work; I am having some user problems but will continue to learn how to use the tool.
                                          I would like to have some more options for entering the information when in the drawing mode.\
                                          • pixelcruncherP
                                            pixelcruncher Extension Creator @pilou
                                            I have verified in hide them ! ;)f
                                            @pilou You were right; that was a bug! Sweeping a face along the bar's own path now cuts a clean tunnel: the far end opens up instead of keeping that last face in place.
                                            A sweep that stops inside the solid still gives you a recess. Can you try it again on your model? Keep those bugs flowing. I'm drinking from the firehose.
                                            Cheers!
                                            Thomas
                                            ntxdaveN 1 Reply Last reply πŸ‘
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
