Modlumi - Easy 3D modelling
Else very very pleasant to use!
@pixelcruncher Did you receive any shared file, Sir?
Thanks! Can you try this again? This should be fixed now:
Keep those bugs flowing!
That is perfect ! Works in closed or not total path!
Even Section profil is not perpendicular to something!
And not on the path!
Very cool function!
OK guys, I am feeling really stupid. I have tried the browser version, but I am not getting things right. How do I create a rectangle and give it the size? I tried to enter the dimensions, but it did not work. What am I not understanding?.
I believe there is a little bug somewhere!
There is just the last faces who are yet in place!
I have verified in hide them !
Very cool that you have keept original " */ " of the copy functions !
@ Ntx Dave
Just Left DoubleClick for have the drawing of the Rectangle, then write 1,2 for a rectangle or 2,2 for a square Enter ! etc..
Or Just Press R , Left Click and Drag for see the Blue Rect , write 2,2, Enter for a square etc...
It's quasi the same than SketchUp!
You have not: Inverse Selection ?
There is no Snap in 3D Space of the second click of the Arc Circle ?
@pilou OK, I finally got it to work; I am having some user problems but will continue to learn how to use the tool.
I would like to have some more options for entering the information when in the drawing mode.\
I have verified in hide them ! ;)f
@pilou You were right; that was a bug! Sweeping a face along the bar's own path now cuts a clean tunnel: the far end opens up instead of keeping that last face in place.
A sweep that stops inside the solid still gives you a recess. Can you try it again on your model? Keep those bugs flowing. I'm drinking from the firehose.
Cheers!
Thomas -
@pixelcruncher How the heck do you draw something like this. I am currently feeling really stupid and am not doing well. The object in the model looks kind of neat but I cannot understand how you drew it.
How the heck do you draw something like this? So far, I am not doing very well when trying to draw objects that are not all that complicated. Is there some place I can go to learn how to use the drawing tools better?
Not really; you are on the bleeding edge with us. This software doesn't have documentation yet
But a lot of your SketchUp skills should translate over. Note that it's all still very alpha, lots of bugs to bite you. But many eyes make all the bugs shallow. -
Before you post i have verified on a more simple one ... that was a repetive bug!
Here modified by hands!
So I must return to your last version!
@pilou, what are you using for those renders? They look cool.
I use only Gemini free there is maybe a little limit of number images by day but sufficient for me... in case of overpass i use this terrific free one ( 95 % of functions have Free Access : Vizcom ! )
https://vizcom.com/ You can make in free 1,2,4,8 k images!
A must and Online so for my very old Latop (more than 12 years old) that is paradise!
I will go test your new opus!
Ah you are speedy!
Seems no more bug inside Sweep now!
How do you draw something like this in Modlumi?
