    help with a thread
    40 Posts 3 Posters 5.4k Views 3 Watching
      Leggy
      Aha I got you mixed up, that was the one I watched
        Leggy
        I’m the problem, ha ha
        I need a back to basics tutorial, I always seem to miss a certain point and nothing happens . I can see the way both of you do the threads but I’m missing something
          Leggy
          Ok I’ve managed a male and female thread on a 150mm diameter, with a 0.3 offset, . It’s very tight can wind it on for 2 threads , and that’s it. Tomorrow doing another female with an extra 0.3 clearance on all faces, so see how that goes. I think it’s the shrinkage on the printer that’s causing the problem
          Thanks Guys for all your help
            Dave R @Leggy
            @Leggy said in help with a thread:
            That's probably it. You'll have to work that out based on the material.
              Leggy
              I finally got it to work , pictures to follow , thanks Guys
                Leggy
                  Leggy
                  1CB2BC12-596F-4745-BC0F-C832939B95AE.mov
                    Well done @Leggy
                      Leggy
                      Hi guys
                      Again thanks for all your help
                      Is there a chart you use to look up thread dimensions, pitch, tpi , crest etc
                      I was trying a m22 x 2.5 and got a bit confused on the chart I was following, so I asked ChatGPT
                      After 4 hours of me telling it, it was wrong, it finally agreed 🙄
                      I was drawing it in SU then asking it questions on the iPad
                      When I get home I’ll upload my figures and see what you think, the thread looks good on the screen, but that doesn’t mean it will fit
                      Thanks Dean
                      Dave RD 1 Reply Last reply 👍 Reply Quote 1
                        Leggy
                          Leggy
                          These are what chat told me
                            Dave R @Leggy
                            I would use the following site:
                            External Metric ISO Thread Table Chart Sizes M20 - M55
                            Metric external thread size table chart for sizes M20 to M55 Bolts and screws per. ANSI/ASME B1.13M-1995.
                            (www.engineersedge.com)
                            I wouldn't bother with the radiused corners because they'd be too small.
                              Leggy
                              Ill check it out
                                Leggy
                                What about tpi?
                                  Dave R @Leggy
                                  What about tpi?
                                  What do you mean? The thread pitch is given along with the other dimensions for the threads. TPI standas for Threads Per Inch and is not used for metric threads. M22x2.5 indicates the nominal diamter is 22mm and the pitch is 2.5mm. The helix rises 2.5mm for each rotation.
                                    Leggy
                                    Ah ok , I see what you mean, this is where ChatGPT was messing with me
                                      Leggy @Leggy
                                      How do I get rid of the grey spiral in the last picture?
                                        Can't you just select it to highlight it and hit Delete to make it go away?
                                        Are you modeling internal or external threads?
                                          Leggy
                                          No, it seems to be in hidden sections, so would have to select every faucet on the plane and line
                                          What I found is if I draw an arc from the top of the inner profile to the bottom, and do the helix , I can click on the curve and can delete it all 🤷🏼‍♂️
                                          cant see the difference vwhy, but it works, the threads are great
                                          what I found is a difference in tolerances, I printed 3 nuts with 0.1/15/2 offsets in petg and tpu, 0.1 was good in petg, but had to go to 0.2 for tpu
                                          what a week of RND
                                            Dave R @Leggy
                                            Likely you need to weld some edges first.
                                            Not surprising. They have different shrink rates.
                                            • Dave RD Dave R referenced this topic on
                                            • 2 / 2
