    help with a thread
    40 Posts 3 Posters 7.2k Views 3 Watching
      So what's your problem in trying to model it in SketchUp? What's not working?
      @Leggy said in help with a thread:
      there are only 4 crests on the thread
      When you model it make it 2 or 3 turns longer so you can cut the extrusion off nicely.
      • L
        Leggy
        I’m the problem, ha ha
        I need a back to basics tutorial, I always seem to miss a certain point and nothing happens . I can see the way both of you do the threads but I’m missing something
        • L
          Leggy
          with a 150mm diameter
          • L
            Leggy
            ok , after watching Rich's video about 8 times I'm making progress. I was missing the upright extension
            what's curve origin? I set it to -1.5 as in the video, so that made the male thread , now to make the female which ill offset by 0.3
            Dave RD Rich O BrienR 2 Replies Last reply
              Dave R @Leggy
              OK. So you don't need the video tutorial I did? Good enough.
              L 1 Reply Last reply
              • L
                Leggy @Dave R
                @Dave-R where is it?
                Dave RD 1 Reply Last reply
                  Rich O Brien Moderator @Leggy
                  I did a video?
                    Dave R @Leggy
                    where is it?
                    • L
                      Leggy
                      Aha I got you mixed up, that was the one I watched
                      • L
                        Leggy
                        • L
                          Leggy
                          Ok I’ve managed a male and female thread on a 150mm diameter, with a 0.3 offset, . It’s very tight can wind it on for 2 threads , and that’s it. Tomorrow doing another female with an extra 0.3 clearance on all faces, so see how that goes. I think it’s the shrinkage on the printer that’s causing the problem
                          Thanks Guys for all your help
                            Dave R @Leggy
                            That's probably it. You'll have to work that out based on the material.
                            • L
                              Leggy
                              I finally got it to work , pictures to follow , thanks Guys
                              • L
                                Leggy
                                Reply Quote 2
                                • L
                                  Leggy
                                  1CB2BC12-596F-4745-BC0F-C832939B95AE.mov
                                    Well done @Leggy
                                    • L
                                      Leggy
                                      Hi guys
                                      Again thanks for all your help
                                      Is there a chart you use to look up thread dimensions, pitch, tpi , crest etc
                                      I was trying a m22 x 2.5 and got a bit confused on the chart I was following, so I asked ChatGPT
                                      After 4 hours of me telling it, it was wrong, it finally agreed 🙄
                                      I was drawing it in SU then asking it questions on the iPad
                                      When I get home I’ll upload my figures and see what you think, the thread looks good on the screen, but that doesn’t mean it will fit
                                      Thanks Dean
                                      Dave RD 1 Reply Last reply 👍
                                      • L
                                        Leggy
                                        • L
                                          Leggy
                                          These are what chat told me
                                            Dave R @Leggy
                                            I would use the following site:
                                            External Metric ISO Thread Table Chart Sizes M20 - M55
                                            Metric external thread size table chart for sizes M20 to M55 Bolts and screws per. ANSI/ASME B1.13M-1995.
                                            (www.engineersedge.com)
                                            I wouldn't bother with the radiused corners because they'd be too small.
                                            • 2 / 2
