    help with a thread
    40 Posts 3 Posters 7.2k Views 3 Watching
    • L
      Leggy
      I’m the problem, ha ha
      I need a back to basics tutorial, I always seem to miss a certain point and nothing happens . I can see the way both of you do the threads but I’m missing something
      • L
        Leggy
        with a 150mm diameter
        • L
          Leggy
          ok , after watching Rich's video about 8 times I'm making progress. I was missing the upright extension
          what's curve origin? I set it to -1.5 as in the video, so that made the male thread , now to make the female which ill offset by 0.3
          Dave RD Rich O BrienR 2 Replies Last reply
            Dave R @Leggy
            @Leggy said in help with a thread:
            OK. So you don't need the video tutorial I did? Good enough.
            L 1 Reply Last reply
            • L
              Leggy @Dave R
              @Dave-R where is it?
              Dave RD 1 Reply Last reply
                Rich O Brien Moderator @Leggy
                I did a video?
                  Dave R @Leggy
                  where is it?
                  • L
                    Leggy
                    Aha I got you mixed up, that was the one I watched
                    • L
                      Leggy
                      • L
                        Leggy
                        Ok I’ve managed a male and female thread on a 150mm diameter, with a 0.3 offset, . It’s very tight can wind it on for 2 threads , and that’s it. Tomorrow doing another female with an extra 0.3 clearance on all faces, so see how that goes. I think it’s the shrinkage on the printer that’s causing the problem
                        Thanks Guys for all your help
                          Dave R @Leggy
                          That's probably it. You'll have to work that out based on the material.
                          • L
                            Leggy
                            I finally got it to work , pictures to follow , thanks Guys
                            • L
                              Leggy
                              Reply Quote 2
                              • L
                                Leggy
                                1CB2BC12-596F-4745-BC0F-C832939B95AE.mov
                                  Well done @Leggy
                                  • L
                                    Leggy
                                    Hi guys
                                    Again thanks for all your help
                                    Is there a chart you use to look up thread dimensions, pitch, tpi , crest etc
                                    I was trying a m22 x 2.5 and got a bit confused on the chart I was following, so I asked ChatGPT
                                    After 4 hours of me telling it, it was wrong, it finally agreed 🙄
                                    I was drawing it in SU then asking it questions on the iPad
                                    When I get home I’ll upload my figures and see what you think, the thread looks good on the screen, but that doesn’t mean it will fit
                                    Thanks Dean
                                    Dave RD 1 Reply Last reply 👍
                                    • L
                                      Leggy
                                      • L
                                        Leggy
                                        These are what chat told me
                                          Dave R @Leggy
                                          I would use the following site:
                                          External Metric ISO Thread Table Chart Sizes M20 - M55
                                          Metric external thread size table chart for sizes M20 to M55 Bolts and screws per. ANSI/ASME B1.13M-1995.
                                          (www.engineersedge.com)
                                          I wouldn't bother with the radiused corners because they'd be too small.
                                          • L
                                            Leggy
                                            Ill check it out
                                            • 2 / 2
