    help with a thread
    40 Posts 3 Posters 7.2k Views 3 Watching
    • L
      Leggy
      These are what chat told me
        Dave R @Leggy
        @Leggy said in help with a thread:
        Is there a chart you use to look up thread dimensions, pitch, tpi , crest etc
        I would use the following site:
        External Metric ISO Thread Table Chart Sizes M20 - M55
        Metric external thread size table chart for sizes M20 to M55 Bolts and screws per. ANSI/ASME B1.13M-1995.
        (www.engineersedge.com)
        I wouldn't bother with the radiused corners because they'd be too small.
        • L
          Leggy
          Ill check it out
          • L
            Leggy
            What about tpi?
            Dave RD 1 Reply Last reply
              Dave R @Leggy
              What about tpi?
              What do you mean? The thread pitch is given along with the other dimensions for the threads. TPI standas for Threads Per Inch and is not used for metric threads. M22x2.5 indicates the nominal diamter is 22mm and the pitch is 2.5mm. The helix rises 2.5mm for each rotation.
              • L
                Leggy
                Ah ok , I see what you mean, this is where ChatGPT was messing with me
                L 1 Reply Last reply
                • L
                  Leggy @Leggy
                  How do I get rid of the grey spiral in the last picture?
                    Can't you just select it to highlight it and hit Delete to make it go away?
                    Are you modeling internal or external threads?
                    • L
                      Leggy
                      No, it seems to be in hidden sections, so would have to select every faucet on the plane and line
                      What I found is if I draw an arc from the top of the inner profile to the bottom, and do the helix , I can click on the curve and can delete it all πŸ€·πŸΌβ€β™‚οΈ
                      cant see the difference vwhy, but it works, the threads are great
                      what I found is a difference in tolerances, I printed 3 nuts with 0.1/15/2 offsets in petg and tpu, 0.1 was good in petg, but had to go to 0.2 for tpu
                      what a week of RND
                        Dave R @Leggy
                        Likely you need to weld some edges first.
                        Not surprising. They have different shrink rates.
                        • Dave RD Dave R referenced this topic on
                        • 2 / 2
