    help with a thread
    40 Posts 3 Posters 6.7k Views 3 Watching
      Leggy
      I finally got it to work , pictures to follow , thanks Guys
        Leggy
          Leggy
          1CB2BC12-596F-4745-BC0F-C832939B95AE.mov
            Well done @Leggy
              Leggy
              Hi guys
              Again thanks for all your help
              Is there a chart you use to look up thread dimensions, pitch, tpi , crest etc
              I was trying a m22 x 2.5 and got a bit confused on the chart I was following, so I asked ChatGPT
              After 4 hours of me telling it, it was wrong, it finally agreed ๐Ÿ™„
              I was drawing it in SU then asking it questions on the iPad
              When I get home Iโ€™ll upload my figures and see what you think, the thread looks good on the screen, but that doesnโ€™t mean it will fit
              Thanks Dean
              Dave RD 1 Reply Last reply ๐Ÿ‘ Reply Quote 1
                Leggy
                  Leggy
                  These are what chat told me
                    Dave R @Leggy
                    @Leggy said in help with a thread:
                    I would use the following site:
                    External Metric ISO Thread Table Chart Sizes M20 - M55
                    Metric external thread size table chart for sizes M20 to M55 Bolts and screws per. ANSI/ASME B1.13M-1995.
                    (www.engineersedge.com)
                    I wouldn't bother with the radiused corners because they'd be too small.
                      Leggy
                      Ill check it out
                        Leggy
                        What about tpi?
                          Dave R @Leggy
                          What about tpi?
                          What do you mean? The thread pitch is given along with the other dimensions for the threads. TPI standas for Threads Per Inch and is not used for metric threads. M22x2.5 indicates the nominal diamter is 22mm and the pitch is 2.5mm. The helix rises 2.5mm for each rotation.
                            Leggy
                            Ah ok , I see what you mean, this is where ChatGPT was messing with me
                              Leggy @Leggy
                              How do I get rid of the grey spiral in the last picture?
                                Can't you just select it to highlight it and hit Delete to make it go away?
                                Are you modeling internal or external threads?
                                  Leggy
                                  No, it seems to be in hidden sections, so would have to select every faucet on the plane and line
                                  What I found is if I draw an arc from the top of the inner profile to the bottom, and do the helix , I can click on the curve and can delete it all ๐Ÿคท๐Ÿผโ€โ™‚๏ธ
                                  cant see the difference vwhy, but it works, the threads are great
                                  what I found is a difference in tolerances, I printed 3 nuts with 0.1/15/2 offsets in petg and tpu, 0.1 was good in petg, but had to go to 0.2 for tpu
                                  what a week of RND
                                    Dave R @Leggy
                                    Likely you need to weld some edges first.
                                    Not surprising. They have different shrink rates.
                                    • Dave RD Dave R referenced this topic on
                                    • 2 / 2
