    Rayscaper, My trip down the road to adjumacation.
    176 Posts 8 Posters 34.0k Views 7 Watching
      Mike Amos @pixelcruncher
      @pixelcruncher Moving on a bit.
      I have noted that textures that are repeated as in the wood texture on the furniture, can become corrup. the scaling can be lost but sampling from a different piece of that furniture can fix the issue. It's not apparent here for example.
      The 'chilli cat' image here has rescaled too. Originally stretched is has reduced in size in the render.
      Mike AmosM pixelcruncherP 2 Replies Last reply
        Mike Amos @Mike Amos
        @Mike-Amos
        Success creating a normal from a texture via Affinity photo. Lightened here in Irfanview.
        • L
          Try this Mike, you can drag in your texture and within 2 seconds you will have a normals map, and in fact any other type of map.
          NormalMap-Online
          Online NormalMap Generator FREE! Create a Normalmap directly inside your browser! No Uploads required, completely client-based
          (cpetry.github.io)
          Mike AmosM 1 Reply Last reply
            Mike Amos @L i am
            @L-i-am
            Very sharp, thanks mate.
              Looking at camera views and trying for a defined FoV. This top view with a 'Cap' is handy to see where in the render scene, I need lights.
              Still trying for the right mix but it will take a bit of fiddling.
              1st is without a domplete roof cap the second with.
                @Mike-Amos
                Repeat.
                  I change a directional light for a round light and experienced Crash #146881.
                  I will restart and go again.
                  • pixelcruncherP
                    pixelcruncher Extension Creator @Mike Amos
                    @Mike-Amos Do you mind sending me that scene again? I would like to investigate why the scaling is off.
                      @pixelcruncher
                      I have sent the model earlier. a few adjustments, the circular lights in the ceiling to 5w and the spotlights to 20w which makes them more obvious in the render.
                      Bout it re4ally.
                      Not convinced by the shower unit which is meant to be chrome so another look later.Minime Camera test 6 500 S 32m 06s gpu Ir Cropped.jpg
                      • Bryan KB
                        Looking damned good!
                          Mike Amos @Bryan K
                          @Bryan-K
                          Ta mate, getting there but it's a whole new system.
                          Very much enjoying the ride.
                            @Mike-Amos
                            Moving onwards, had some incidents of the pc shutting down without my input. Seems to be a win doze thing again but I'm keeping an eye on it.
                              @Mike-Amos
                              View change. Still trying to work out a better scene in such a small build.
                                @Mike-Amos
                                Changed view slightly.
                                  @Mike-Amos
                                  An Affinity photo adjustment.
                                    @Mike-Amos
                                    To better fit everything in the viewing panel I have tried a panoramic image.
                                    I do not have a panroramic viewer right now but it seems better ballanced.!
                                      @Mike-Amos
                                      I think I prefer the 4k x 4k version. Slightly lighter in Irfanview, will try Affinity Photo later.
                                      Well, I tried, 4k x 4k will not uploead, fair enuffski.
                                        @Mike-Amos
                                        2000 x 3000.
                                          2000 x 3000 Lightened Irfanview,
                                            Playing with a 'mask' around the physical model to increase fov and 'see' both levels.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 5 / 9
