    Rayscaper New Releases
    rayscaperrender
    785 Posts 14 Posters 363.5k Views 15 Watching
    • pixelcruncherP
      @Krass Nice, thanks for sharing! Super cool to see this result.
      • pixelcruncherP
        Hey, Rayscaper users!
        Rayscaper 0.9.83 Beta is available. You can get it via:
        • The SketchUcation store.
        • Direct download: Rayscaper_0.9.83_Beta.rbz.
        I recommend upgrading to the latest version.
        What Changed?
        • Add Nishita sky sun tracking from SketchUp shadows. The procedural sky will now automatically follow the sun position set in SketchUp's shadow settings, making it easier to match lighting conditions across your workflow. You can enable this via the menu Extensions > Rayscaper > Sync Nishita with Sun. See Syncing with SketchUp Sun for more details.
        • Improve environment power controls with logarithmic sliders. Environment intensity is now easier to adjust precisely across a wide range of values.
        • Fix crash when changing render resolution. Rayscaper will no longer crash when you adjust the resolution settings.
        • Fix alpha textures to use linear color space. Alpha channels in textures now render with correct transparency values.
        Help Me Build the Community πŸ‘
        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating
        and helps me showcase its capabilities to new users.
        Follow me on X.
        Happy Rendering!
        Thomas
        KrassK 1 Reply Last reply
        • ntxdaveN
          ntxdave
          What tool can you use to create an animation that works with Rayscaper?
          Press F1...thank me later
          • ntxdaveN
            ntxdave
            Any plans to ,ake Rayscaper work withAnamator?
            • KrassK
              Krass @ntxdave
              @ntxdave i think it only works with scene transitions. Wait for pixel cruncher answer about Animator.
              Krass
              • A
                Alattab
                How can I make a water material ?
                • pixelcruncherP
                  pixelcruncher Extension Creator @ntxdave
                  @ntxdave Like @krass mentioned, it only works for SketchUp scene animations. Fredo animator is not supported yet. Here is a guide on how to animate regular SketchUp scenes: https://rayscaper.com/guides/animation/
                  • KrassK
                    Krass @Alattab
                    @Alattab forwater may be try a transparent or glass material and try several wave normal maps in the normal slot, play with material scale
                    Krass
                    • KrassK
                      Krass
                      here a test with PBR mode/color/no roughness/ and this normal map
                      Krass
                      pixelcruncherP A 2 Replies Last reply πŸ‘
                      • KrassK
                        Krass @pixelcruncher
                        @pixelcruncher Hello ! This is great,
                        You managed to fix the resolution change issue, and you did it very quickly, thank you! I'm now going to test my new animation in HD. I really like the subtle little changes you made to the interface; it's very well thought out: the fact that you only have to click once on the value field is perfect.
                        And I really like the interface in general. The scenes load very quickly...
                        However, it's true that being able to export the project as a workable zip file on another machine without having to remap missing textures would be ideal.
                        Let me give you a specific example: I don't like modeling and preparing the Rayscaper render on my laptop. But it will be much faster for rendering animations, so I need to export the project from the PC to the laptop.
                        Krass
                        • pixelcruncherP
                          @Krass That's some nice looking water! And a great workflow.
                          I did a similar experiment. I used a glass material with an index of refraction of 1.33 (the IOR of water). I used a water texture I found online.
                          Here's how I set it up in SketchUp and Rayscaper:
                          And there are the details of the glass material:
                          I found the water texture here: https://www.cadhatch.com/seamless-water-textures
                          One of the upcoming releases, I will try to add a water material. It's such a common item in Archviz that I think Rayscaper should have one.
                          I hope this helps!
                          Cheers,
                          Thomas
                          A 1 Reply Last reply πŸ‘
                          • pixelcruncherP
                            @Krass said in Rayscaper New Releases:
                            Cheers! Glad to hear the bug is fixed.
                            Nice! I did put some work into improving the interface during the holidays.
                            Fair enough, I'm aware that this working 100% correct is super important. Expect this to be fixed in one of the upcoming releases.
                            Regards,
                            Thomas
                            • KrassK
                              Krass
                              I'm trying to find a plugin to extract all textures from a SU model, I had one before, I think it is from Eneroth...
                              Krass
                              • KrassK
                                Krass
                                eneroth material Extractor
                                Krass
                                • KrassK
                                  Krass
                                  In the meantime, to transfer a project to another machine, simply go to the editor of the material and open the texture in the Windows viewer, then save it in the images folder generated by the Rayscaper material archive once SU is opened on the other machine (from the archive created by Rayscaper).
                                  Krass
                                  • A
                                    Alattab @Krass
                                    @Krass thank you
                                    • A
                                      Alattab @pixelcruncher
                                      @pixelcruncher Where can I add specular luminosity maps? Or where can i mange specular value
                                      • A
                                        Alattab
                                        Just a suggestion: all PBR parameters should be available, in addition to an AO parameter that allows the user to add all PBR maps. Also, the ability to add FORE GROUND AND BACK GROUND should be added instead of using the environment image, and the ability to resize the environment image should also be included.
                                        pixelcruncherP 1 Reply Last reply πŸ‘
                                        • KrassK
                                          Krass
                                          Yes, when you talk about resizing HDRI maps, it's an ideal function, but you know, even D5 Render doesn't have that feature yet. It's available in Twinmotion and V-Ray (Infinite Dome) for the programs I use. For the background, you can also place an arc-shaped plane with an image in Raycacaper, which often works.
                                          Have you tried that slot for your specular map?
                                          Krass
                                          A 1 Reply Last reply πŸ‘Ž
                                          • majidM
                                            majid
                                            Unbelieveably good!
                                            1 Reply Last reply β™₯
