    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • KrassK
      Krass @pixelcruncher
      @pixelcruncher Hello ! This is great,
      You managed to fix the resolution change issue, and you did it very quickly, thank you! I'm now going to test my new animation in HD. I really like the subtle little changes you made to the interface; it's very well thought out: the fact that you only have to click once on the value field is perfect.
      And I really like the interface in general. The scenes load very quickly...
      However, it's true that being able to export the project as a workable zip file on another machine without having to remap missing textures would be ideal.
      Let me give you a specific example: I don't like modeling and preparing the Rayscaper render on my laptop. But it will be much faster for rendering animations, so I need to export the project from the PC to the laptop.
      Krass
      • pixelcruncherP
        @Krass That's some nice looking water! And a great workflow.
        I did a similar experiment. I used a glass material with an index of refraction of 1.33 (the IOR of water). I used a water texture I found online.
        Here's how I set it up in SketchUp and Rayscaper:
        And there are the details of the glass material:
        I found the water texture here: https://www.cadhatch.com/seamless-water-textures
        One of the upcoming releases, I will try to add a water material. It's such a common item in Archviz that I think Rayscaper should have one.
        I hope this helps!
        Cheers,
        Thomas
        A 1 Reply Last reply πŸ‘
        • pixelcruncherP
          @Krass said in Rayscaper New Releases:
          Cheers! Glad to hear the bug is fixed.
          Nice! I did put some work into improving the interface during the holidays.
          Fair enough, I'm aware that this working 100% correct is super important. Expect this to be fixed in one of the upcoming releases.
          Regards,
          Thomas
          • KrassK
            Krass
            I'm trying to find a plugin to extract all textures from a SU model, I had one before, I think it is from Eneroth...
            Krass
            • KrassK
              Krass
              eneroth material Extractor
              Krass
              • KrassK
                Krass
                In the meantime, to transfer a project to another machine, simply go to the editor of the material and open the texture in the Windows viewer, then save it in the images folder generated by the Rayscaper material archive once SU is opened on the other machine (from the archive created by Rayscaper).
                Krass
                  Alattab @Krass
                  @Krass thank you
                    Alattab @pixelcruncher
                    @pixelcruncher Where can I add specular luminosity maps? Or where can i mange specular value
                      Alattab
                      Just a suggestion: all PBR parameters should be available, in addition to an AO parameter that allows the user to add all PBR maps. Also, the ability to add FORE GROUND AND BACK GROUND should be added instead of using the environment image, and the ability to resize the environment image should also be included.
                      pixelcruncherP 1 Reply Last reply πŸ‘
                      • KrassK
                        Krass
                        Yes, when you talk about resizing HDRI maps, it's an ideal function, but you know, even D5 Render doesn't have that feature yet. It's available in Twinmotion and V-Ray (Infinite Dome) for the programs I use. For the background, you can also place an arc-shaped plane with an image in Raycacaper, which often works.
                        Have you tried that slot for your specular map?
                        Krass
                        A 1 Reply Last reply πŸ‘Ž
                        • majidM
                          majid
                          Unbelieveably good!
                          1 Reply Last reply β™₯
                            Alattab @Krass
                            @Krass thank you , i will try this slot , but there is an However, there is a difference between specular and specular tint. For clear water that has a specular, it is best to use metallic with the transparency.
                            • KrassK
                              Krass
                              Hi, would it be possible to have the total render time remain displayed in the dedicated window after the render is complete? Of course, I've noted the estimated time that appears during the animation render, but the final time disappears once the job is finished...
                              Krass
                              Mike AmosM pixelcruncherP 2 Replies Last reply
                                Mike Amos @Krass
                                @Krass
                                Not here mate. The render time is a constant.![Render Time Persistent.
                                • KrassK
                                  Krass
                                  Hi, I don't quite understand, do you mean the total rendering time is displayed at the bottom here? Also for the animation?
                                  Krass
                                    Pardon me, I missed the 'animation' part of your post, just wondering if it was a new behaviour from the app.
                                    • pixelcruncherP
                                      pixelcruncher Extension Creator @Alattab
                                      @Alattab said in Rayscaper New Releases:
                                      Which application is this?
                                      AO parameter is on the list, but I haven't gotten around to it yet.
                                      By background, you mean adding an image to the backplate, for example for compositing? And would you then save this image as part of the render, or not?
                                      What is foreground? Do you have an example from other render software?
                                      The ability to resize the environment image should also be included.
                                      I'm not sure what that means. Do you mean a smaller / bigger resolution, or something else? The environment is wrapped as a "sphere" around your scene, so resizing will only impact the level of detail.
                                      Thanks for the feedback!
                                      Regards,
                                      Thomas
                                      • pixelcruncherP
                                        @Krass
                                        So you mean keeping this window open until you explicitly close it after rendering?
                                          Alattab
                                          I'm still learning, and I hope the program's creator will allow me to provide feedback and suggest improvements. I'm a beginner with SketchUp and have tried many rendering programs that work independently, like Stanalone. I think it's great that it supports Intel OpenImage Denoiser. I'd like contrast control added to the post-processing section, and full PBR properties added, along with additional materials like transparent liquids, bubbled, fizz, and airborne water.
                                            @pixelcruncher Back palette (background) and front plate (foreground), like a keyshot render. If you choose a transparent background, you can add other images as a background or in front image as clipart in front of rendered image , some thing like whate happen in sketchup style editting
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 37
                                            • 38
                                            • 17 / 38
