    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.9k Views 14 Watching
    • ntxdaveN
      ntxdave
      Any plans to ,ake Rayscaper work withAnamator?
      Press F1...thank me later
      • KrassK
        Krass @ntxdave
        @ntxdave i think it only works with scene transitions. Wait for pixel cruncher answer about Animator.
        Krass
          Alattab
          How can I make a water material ?
          KrassK 1 Reply Last reply
          • pixelcruncherP
            pixelcruncher Extension Creator @ntxdave
            @ntxdave Like @krass mentioned, it only works for SketchUp scene animations. Fredo animator is not supported yet. Here is a guide on how to animate regular SketchUp scenes: https://rayscaper.com/guides/animation/
            • KrassK
              Krass @Alattab
              @Alattab forwater may be try a transparent or glass material and try several wave normal maps in the normal slot, play with material scale
              Krass
              • KrassK
                Krass
                here a test with PBR mode/color/no roughness/ and this normal map
                Krass
                pixelcruncherP A 2 Replies Last reply πŸ‘
                • KrassK
                  Krass @pixelcruncher
                  @pixelcruncher Hello ! This is great,
                  You managed to fix the resolution change issue, and you did it very quickly, thank you! I'm now going to test my new animation in HD. I really like the subtle little changes you made to the interface; it's very well thought out: the fact that you only have to click once on the value field is perfect.
                  And I really like the interface in general. The scenes load very quickly...
                  However, it's true that being able to export the project as a workable zip file on another machine without having to remap missing textures would be ideal.
                  Let me give you a specific example: I don't like modeling and preparing the Rayscaper render on my laptop. But it will be much faster for rendering animations, so I need to export the project from the PC to the laptop.
                  Krass
                  • pixelcruncherP
                    @Krass That's some nice looking water! And a great workflow.
                    I did a similar experiment. I used a glass material with an index of refraction of 1.33 (the IOR of water). I used a water texture I found online.
                    Here's how I set it up in SketchUp and Rayscaper:
                    And there are the details of the glass material:
                    I found the water texture here: https://www.cadhatch.com/seamless-water-textures
                    One of the upcoming releases, I will try to add a water material. It's such a common item in Archviz that I think Rayscaper should have one.
                    I hope this helps!
                    Cheers,
                    Thomas
                    A 1 Reply Last reply πŸ‘
                    • pixelcruncherP
                      @Krass said in Rayscaper New Releases:
                      Cheers! Glad to hear the bug is fixed.
                      Nice! I did put some work into improving the interface during the holidays.
                      Fair enough, I'm aware that this working 100% correct is super important. Expect this to be fixed in one of the upcoming releases.
                      Regards,
                      Thomas
                      • KrassK
                        Krass
                        I'm trying to find a plugin to extract all textures from a SU model, I had one before, I think it is from Eneroth...
                        Krass
                        • KrassK
                          Krass
                          eneroth material Extractor
                          Krass
                          • KrassK
                            Krass
                            In the meantime, to transfer a project to another machine, simply go to the editor of the material and open the texture in the Windows viewer, then save it in the images folder generated by the Rayscaper material archive once SU is opened on the other machine (from the archive created by Rayscaper).
                            Krass
                              Alattab @Krass
                              @Krass thank you
                                Alattab @pixelcruncher
                                @pixelcruncher Where can I add specular luminosity maps? Or where can i mange specular value
                                  Alattab
                                  Just a suggestion: all PBR parameters should be available, in addition to an AO parameter that allows the user to add all PBR maps. Also, the ability to add FORE GROUND AND BACK GROUND should be added instead of using the environment image, and the ability to resize the environment image should also be included.
                                  pixelcruncherP 1 Reply Last reply πŸ‘
                                  • KrassK
                                    Krass
                                    Yes, when you talk about resizing HDRI maps, it's an ideal function, but you know, even D5 Render doesn't have that feature yet. It's available in Twinmotion and V-Ray (Infinite Dome) for the programs I use. For the background, you can also place an arc-shaped plane with an image in Raycacaper, which often works.
                                    Have you tried that slot for your specular map?
                                    Krass
                                    A 1 Reply Last reply πŸ‘Ž
                                    • majidM
                                      majid
                                      Unbelieveably good!
                                      1 Reply Last reply β™₯
                                        Alattab @Krass
                                        @Krass thank you , i will try this slot , but there is an However, there is a difference between specular and specular tint. For clear water that has a specular, it is best to use metallic with the transparency.
                                        • KrassK
                                          Krass
                                          Hi, would it be possible to have the total render time remain displayed in the dedicated window after the render is complete? Of course, I've noted the estimated time that appears during the animation render, but the final time disappears once the job is finished...
                                          Krass
                                          Mike AmosM pixelcruncherP 2 Replies Last reply
                                            Mike Amos @Krass
                                            @Krass
                                            Not here mate. The render time is a constant.![Render Time Persistent.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 26
                                            • 27
                                            • 17 / 27
