    Rayscaper New Releases
    rayscaperrender
    484 Posts 12 Posters 218.8k Views 13 Watching
    • S
      sashapepperspray @pixelcruncher
      @pixelcruncher thank you very much!
      • P
        pixelcruncher Extension Creator @ntxdave
        @ntxdave Can you provide some context on what's now working?
        As soon as you have a Skatter composition, click generate, and the skattered items should appear in Rayscaper. I will create a demo video later. It would be great if you could provide a screenshot (or video) of what youare seeing. Just saying "it doesn't work" isn't providing me much to help you.
          Thanks Thomas. I think the inclusion of Skatter will make for a more capable render program and enable us to produce better results, getting to grips with it is the issue a few of us will have but keeping on will be the answer.
          Step by step, tbh, I have never had a decent result but that is me and NOT Skatter at fault.
          • ntxdaveN
            ntxdave
            OK - Some progress. Although there are some problems, I just did a new test and "kind of" got it to work. Although the grass and bush colors are wrong in the rendered copy, here is the result of the test.
            As I said, this is progress but so far, I can only get this to work with a new project. If I go back to an existing model, I cannot get things to work with an old/existing model. I do cannot get the Generate option to show up.
            Press F1...thank me later
            • ntxdaveN
              ntxdave
              OK, I just tried an old/existing file again and am getting this error:
              P 1 Reply Last reply
              • P
                @ntxdave Sorry about that, this seems like a real bug. I will investigate!
                • P
                  Here's a quick video on how to use Rayscaper with Skatter. Still trying to get better at making video content πŸ™‚
                  ntxdaveN 1 Reply Last reply
                  • P
                    And here are some teapots in the night πŸ™‚
                    • KrassK
                      Krass
                      But why aren't the transparent PNG files of the leaves taken into account?
                      Krass
                      • ntxdaveN
                        ntxdave @pixelcruncher
                        @pixelcruncher said in Rayscaper New Releases:
                        Thanks for posting the video. However, in the video you have generated the skattered items in the model. Now what you need to do is to turn on the β€œ Render only” option and then go to Rayscaper and see if the skattered items are generated by Rayscaper.
                        I think we are moving in the right direction. Just need to β€œwork some things out”. πŸ˜€
                        • ntxdaveN
                          ntxdave
                          OK, I just gave things a second go round and things are not generating correctly when I use the "render only" option.
                          Here is my SketchUp model which you can use for testing/messing around.
                          Test - 2.skp
                          • P
                            @Krass I didn't modify the materials, just used them as they came from SketchUp. But it's possible ofcourse:
                            But maybe it's more intuitive to use the alpha channel from the color slot immediately if one exists?
                            • P
                              @ntxdave - In your test file, it had a ton of geometry generated in the model. If I tried to re-create your scene again, step-by-step I got this:
                              Can you try to just generate the grass on the plane, a first step and see if that works?
                              As a sanity check, you are using Rayscaper 0.9.72?
                              • KrassK
                                Krass
                                Great!
                                Krass
                                • ntxdaveN
                                  Yes, I have updated to Rayscaper 0.9.72. I am having ongoing problems. I will let you know more when I can. I will try to create a very basic file and show what I am see both if I generate in model and with render only.
                                  It is probably going to be much later though. I want to get to the bottom of the problem(s) I am seeing.
                                  • P
                                    @ntxdave Sounds good!
                                    • KrassK
                                      Krass
                                      Rayscaper 0.9.71 renders / Photoshop / Nano Banana for the characters / Magnific Upscale
                                      Krass
                                      • KrassK
                                        Krass
                                        Compared to D5 Render Plus and D5 Render AI Enhancement, it's much better
                                        D5 is faster, but its path tracing is a sham
                                        https://jskup.fr/wp-content/uploads/2025/11/scene-6.FB_.jpg
                                        Krass
                                        • P
                                          @Krass
                                          Compared to D5 Render Plus and D5 Render AI Enhancement, it's very mediocre!
                                          What exactly is mediocre, or what are you missing? That helps me improve the software. Now I can only guess at what's mediocre compared to D5 render.
                                          Cheers,
                                          Thomas
                                          • KrassK
                                            Krass
                                            Sorry Pixelcruncher, that's my faulty translation... I really want to highlight Rayscaper! I love the photorealistic quality of RS's path tracing. I meant the opposite in my post and I've corrected it.
                                            Krass
                                            1 Reply Last reply β™₯
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 24
                                            • 25
                                            • 13 / 25
