    Rayscaper New Releases
    rayscaperrender
    744 Posts 14 Posters 317.8k Views 15 Watching
    • ntxdaveN
      ntxdave
      But now I need to be remember how to make RayScaper work with Skatter.
      Press F1...thank me later
      • ntxdaveN
        ntxdave
        So far, I cannot get Rayscaper to work with Skatter. Need some help.
        • KrassK
          Krass
          That's impressive! With Skatter... well done!
          Krass
          ntxdaveN 1 Reply Last reply
          • ntxdaveN
            ntxdave @Krass
            @Krass said in Rayscaper New Releases:
            Don’t know what I am doing wrong but it is not working for me. 😞
            • KrassK
              Krass
              I don't use Skatter... sorry
              Krass
                sashapepperspray @pixelcruncher
                @pixelcruncher thank you very much!
                • pixelcruncherP
                  pixelcruncher Extension Creator @ntxdave
                  @ntxdave Can you provide some context on what's now working?
                  As soon as you have a Skatter composition, click generate, and the skattered items should appear in Rayscaper. I will create a demo video later. It would be great if you could provide a screenshot (or video) of what youare seeing. Just saying "it doesn't work" isn't providing me much to help you.
                    Thanks Thomas. I think the inclusion of Skatter will make for a more capable render program and enable us to produce better results, getting to grips with it is the issue a few of us will have but keeping on will be the answer.
                    Step by step, tbh, I have never had a decent result but that is me and NOT Skatter at fault.
                    • ntxdaveN
                      ntxdave
                      OK - Some progress. Although there are some problems, I just did a new test and "kind of" got it to work. Although the grass and bush colors are wrong in the rendered copy, here is the result of the test.
                      As I said, this is progress but so far, I can only get this to work with a new project. If I go back to an existing model, I cannot get things to work with an old/existing model. I do cannot get the Generate option to show up.
                      • ntxdaveN
                        ntxdave
                        OK, I just tried an old/existing file again and am getting this error:
                        • pixelcruncherP
                          @ntxdave Sorry about that, this seems like a real bug. I will investigate!
                          • pixelcruncherP
                            Here's a quick video on how to use Rayscaper with Skatter. Still trying to get better at making video content πŸ™‚
                            • pixelcruncherP
                              And here are some teapots in the night πŸ™‚
                              • KrassK
                                Krass
                                But why aren't the transparent PNG files of the leaves taken into account?
                                Krass
                                • ntxdaveN
                                  ntxdave @pixelcruncher
                                  @pixelcruncher said in Rayscaper New Releases:
                                  Thanks for posting the video. However, in the video you have generated the skattered items in the model. Now what you need to do is to turn on the β€œ Render only” option and then go to Rayscaper and see if the skattered items are generated by Rayscaper.
                                  I think we are moving in the right direction. Just need to β€œwork some things out”. πŸ˜€
                                  • ntxdaveN
                                    ntxdave
                                    OK, I just gave things a second go round and things are not generating correctly when I use the "render only" option.
                                    Here is my SketchUp model which you can use for testing/messing around.
                                    Test - 2.skp
                                    • pixelcruncherP
                                      @Krass I didn't modify the materials, just used them as they came from SketchUp. But it's possible ofcourse:
                                      But maybe it's more intuitive to use the alpha channel from the color slot immediately if one exists?
                                      • pixelcruncherP
                                        @ntxdave - In your test file, it had a ton of geometry generated in the model. If I tried to re-create your scene again, step-by-step I got this:
                                        Can you try to just generate the grass on the plane, a first step and see if that works?
                                        As a sanity check, you are using Rayscaper 0.9.72?
                                        • KrassK
                                          Krass
                                          Great!
                                          Krass
                                          • ntxdaveN
                                            Yes, I have updated to Rayscaper 0.9.72. I am having ongoing problems. I will let you know more when I can. I will try to create a very basic file and show what I am see both if I generate in model and with render only.
                                            It is probably going to be much later though. I want to get to the bottom of the problem(s) I am seeing.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 37
                                            • 38
                                            • 13 / 38
