    Rayscaper New Releases
    rayscaperrender
    743 Posts 14 Posters 312.5k Views 15 Watching
    • ntxdaveN
      ntxdave @Krass
      @Krass said in Rayscaper New Releases:
      That's impressive! With Skatter... well done!
      Don’t know what I am doing wrong but it is not working for me. 😞
      Press F1...thank me later
      • KrassK
        Krass
        I don't use Skatter... sorry
        Krass
          sashapepperspray @pixelcruncher
          @pixelcruncher thank you very much!
          • pixelcruncherP
            pixelcruncher Extension Creator @ntxdave
            @ntxdave Can you provide some context on what's now working?
            As soon as you have a Skatter composition, click generate, and the skattered items should appear in Rayscaper. I will create a demo video later. It would be great if you could provide a screenshot (or video) of what youare seeing. Just saying "it doesn't work" isn't providing me much to help you.
              Thanks Thomas. I think the inclusion of Skatter will make for a more capable render program and enable us to produce better results, getting to grips with it is the issue a few of us will have but keeping on will be the answer.
              Step by step, tbh, I have never had a decent result but that is me and NOT Skatter at fault.
              • ntxdaveN
                ntxdave
                OK - Some progress. Although there are some problems, I just did a new test and "kind of" got it to work. Although the grass and bush colors are wrong in the rendered copy, here is the result of the test.
                As I said, this is progress but so far, I can only get this to work with a new project. If I go back to an existing model, I cannot get things to work with an old/existing model. I do cannot get the Generate option to show up.
                • ntxdaveN
                  ntxdave
                  OK, I just tried an old/existing file again and am getting this error:
                  • pixelcruncherP
                    @ntxdave Sorry about that, this seems like a real bug. I will investigate!
                    • pixelcruncherP
                      Here's a quick video on how to use Rayscaper with Skatter. Still trying to get better at making video content πŸ™‚
                      ntxdaveN 1 Reply Last reply
                      • pixelcruncherP
                        And here are some teapots in the night πŸ™‚
                        • KrassK
                          Krass
                          But why aren't the transparent PNG files of the leaves taken into account?
                          Krass
                          • ntxdaveN
                            ntxdave @pixelcruncher
                            @pixelcruncher said in Rayscaper New Releases:
                            Thanks for posting the video. However, in the video you have generated the skattered items in the model. Now what you need to do is to turn on the β€œ Render only” option and then go to Rayscaper and see if the skattered items are generated by Rayscaper.
                            I think we are moving in the right direction. Just need to β€œwork some things out”. πŸ˜€
                            • ntxdaveN
                              ntxdave
                              OK, I just gave things a second go round and things are not generating correctly when I use the "render only" option.
                              Here is my SketchUp model which you can use for testing/messing around.
                              Test - 2.skp
                              • pixelcruncherP
                                @Krass I didn't modify the materials, just used them as they came from SketchUp. But it's possible ofcourse:
                                But maybe it's more intuitive to use the alpha channel from the color slot immediately if one exists?
                                • pixelcruncherP
                                  @ntxdave - In your test file, it had a ton of geometry generated in the model. If I tried to re-create your scene again, step-by-step I got this:
                                  Can you try to just generate the grass on the plane, a first step and see if that works?
                                  As a sanity check, you are using Rayscaper 0.9.72?
                                  • KrassK
                                    Krass
                                    Great!
                                    Krass
                                    • ntxdaveN
                                      Yes, I have updated to Rayscaper 0.9.72. I am having ongoing problems. I will let you know more when I can. I will try to create a very basic file and show what I am see both if I generate in model and with render only.
                                      It is probably going to be much later though. I want to get to the bottom of the problem(s) I am seeing.
                                      • pixelcruncherP
                                        @ntxdave Sounds good!
                                        • KrassK
                                          Krass
                                          Rayscaper 0.9.71 renders / Photoshop / Nano Banana for the characters / Magnific Upscale
                                          Krass
                                          • KrassK
                                            Krass
                                            Compared to D5 Render Plus and D5 Render AI Enhancement, it's much better
                                            D5 is faster, but its path tracing is a sham
                                            https://jskup.fr/wp-content/uploads/2025/11/scene-6.FB_.jpg
                                            Krass
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 37
                                            • 38
                                            • 13 / 38
