    Rayscaper New Releases
    rayscaperrender
    462 Posts 12 Posters 154.5k Views 13 Watching
    • P Offline
      pixelcruncher Extension Creator @Mike Amos
      @Mike-Amos Thank for reporting. Sorry about that!
      I can reproduce the crash on minimizing, not on closing the Rayscaper window, though. Working on a fix.
      • P Offline
        @Mike-Amos Version 0.9.68 is out now, can you confirm that it fixes the crash you saw earlier today? Thanks!
          Sorry, confirm that the crash still happens.
          • KrassK Offline
            Krass
            Hello, if I leave Rayscaper open and import a texture directly onto a face (with the import tool) it crashes
            Krass
            • KrassK Offline
              Krass
              I can't create an emissive material with an image, if I increase the power the image disappears and the texture is white. I can't make a monitor screen. Can someone help me?
              Krass
              • KrassK Offline
                Krass
                crash again, I wasn't doing anything special... Sketchup 2024 and Rayscaper 9.6.8
                Krass
                • KrassK Offline
                  Krass
                  Another crash when reopening RS and trying to apply a texture
                  Krass
                    I can confirm that with the models I had issues with in Sketchup V2024, crash occurs when minimising Rayscaper. After that last build they ceased when closing Rayscaper. In Sketchup 2026, No crash on minimising or closing Rayscaper no matter which model is in use. Other apps also function better, faster, cleanup for example would freeze. NOT in Sketchup V2026.
                    • KrassK Offline
                      Krass
                      I came back to 9.64 version for test
                      Krass
                      • KrassK Offline
                        Krass
                        quelle galère
                        Krass
                          Rich O Brien Moderator @Krass
                          @Krass said in Rayscaper New Releases:
                          quelle galère
                          Patience is a virtue. Having an app have backwards compatibility along with supporting multiple different GPUs and CPUs etc is challenging for a single developer.
                            Mike Amos @Rich O Brien
                            @Rich-O-Brien
                            Agreed, getting this far this fast as a one man band, part time. Wow.
                            Being in beta still, imperfection is a given but the ride is still good and hoping I am contributing sufficiently.
                            P 1 Reply Last reply Reply Quote 1
                            • KrassK Offline
                              Krass
                              Yes! Indeed
                              Krass
                              • P Offline
                                Hey guys,
                                Looking into the crashes.
                                Was this on the first texture, or after multiple imports?
                                Currently, Rayscaper doesn't support emission with a texture. Which image are you talking about? Maybe a screenshot of your setup helps me understand it better.
                                Looking into the crashes, I think (I hope) I found the root cause.
                                I understand the frustrations, and I appreciate your help in making the software a lot better!
                                Cheers,
                                Thomas
                                KrassK 1 Reply Last reply Reply Quote 0
                                • KrassK Offline
                                  Krass @pixelcruncher
                                  Nice render Mike!
                                  @pixelcruncher said in Rayscaper New Releases:
                                  I created a surface and imported a texture
                                  I found a solution to make an image emissive: for example for PC screens on the following images I make a copy of the face that must receive the image and I place it in front 2 or 3 millimeters of the initial face to which I applied an emissive. On this copy of the face I put my image as texture and I increase the Transmission slider, and it works well. (I just discovered this feature!)
                                  ci-dessous 3 rendus avec un upscale KREA.AI
                                  Krass
                                  • KrassK Offline
                                    Krass
                                    for the record, all the furniture is really at my house, but I tried to see in these images what I could fit into this apartment that I could buy....
                                    the character is not contractual, I have a shaved head!
                                    Krass
                                    • P Offline
                                      @Mike-Amos Very nice render!
                                      • P Offline
                                        @Krass Great renders! Glad you found a workaround. That computer screen looks believable to me.
                                        https://www.krea.ai/image
                                        You render it grainy in a low res, and then let it upscale? Or do you enhance the images in other ways with AI?
                                        BTW, I found the issue, will post a fix shortly. The crash occurs when you load too many thumbnails in the asset browser.
                                        Cheers,
                                        Thomas
                                        • KrassK Offline
                                          Krass
                                          I use AI Upscale to get a sharper render and correct details, characters, it improves materials, wood, etc.
                                          Krass
                                          • P Offline
                                            Hey, Rayscaper users!
                                            Another release!
                                            Rayscaper 0.9.69 Beta is available in the SketchUcation store. As
                                            always, I recommend upgrading to the latest version.
                                            What Changed?
                                            • Fix a crash when scrolling the asset browser. - @Krass can you let me know if this version behaves better for you?
                                            Help Me Build the Community 👍
                                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn’t matter)! This is motivating
                                            and helps me showcase its capabilities to new users.
                                            Follow me on Twitter.
                                            Happy Rendering!
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 23
                                            • 24
                                            • 10 / 24
