    D5 Render Work
    95 Posts 12 Posters 6.7k Views 12 Watching
    • marked001M Offline
      marked001
      cafe render...
      http://www.revision21vis.com
      instagram: revi21on
      • ntxdaveN Offline
        ntxdave
        Nice πŸ‘ πŸ‘ πŸ‘
        I wish I could come up with something like this. πŸ˜„
        Press F1...thank me later
          marked001
          Its all the software! Very easy to get good results.
          instagram: revi21on
          • ntxdaveN Offline
            ntxdave
            I meant coming up with the model itself. I don’t seem to be able to design something like this. Yes, once designed the render engines are making it somewhat easier to come up with good renders.
            I like your results. πŸ‘ πŸ‘
              marked001
              Well I definitely do not design the majority of the stuff I post. Some when its conceptual and there isn't actually a design or when we're working through a design. But for the most part, these are all other's designs.. in case that wasn't clear.
              instagram: revi21on
              • ntxdaveN Offline
                ntxdave
                Thanks for the reply. Where do you find stuff like this (and your other neat scenes/models)?
                  marked001
                  99% of this stuff is paid work so comes from the architect, designer, broker, etc. Sometimes its just a plan and some photo reference of what they want, sometimes plans and elevations and complete finishes.
                  instagram: revi21on
                  • ntxdaveN Offline
                    ntxdave
                    OK, now I understand. πŸ˜„ πŸ˜„
                    • Bryan KB Offline
                      That cafe is excellent! πŸ‘
                        marked001
                        Thanks Bryan.
                        Here are some conceptual images for a set build of a high end upper west side apartment for a tv show. They're a weird format because that's the aspect ratio the show is being shot in.
                        instagram: revi21on
                          Beautiful Mark great style and modelling, and I like that aspect ratio. cinematographic πŸ‘
                            marked001
                            Its definitely odd to try to use indoors and see as much as you can. 2:1...I guess its a compromise between 4:3 and 16:9
                            instagram: revi21on
                            • Bryan KB Offline
                              Those set mock-ups turned out really good! πŸ‘
                                Very nicely done, worth a raise. πŸ‘
                                  marked001
                                  Its Union work.. so a raise is out of the question for a few years.. haha.
                                  Object moved
                                  (www.usa829.org)
                                  instagram: revi21on
                                    marked001
                                    quick one from friday afternoon. addition to an existing house.
                                    One thing I like over Lumion, with D5 is that this is straight out of D5 with no post processing. Obviously I 'should' probably spend a little time, but sometimes there just isn't time available. But with Lumion I was always forced to do some post processing to get it where I want it.
                                    instagram: revi21on
                                    • ntxdaveN Offline
                                      ntxdave
                                      I really like this one. πŸ‘ πŸ‘ πŸ‘
                                        marked001
                                        Thanks!
                                        A couple more from last week from the show I'm working on.
                                        instagram: revi21on
                                          @marked001 said:
                                          Thanks! A couple more from last week from the show I'm working on.
                                          The lighting is great. Everything is great. But the lighting is really nice.
                                          The subtle noise patterns really breaks up the textured walls.
                                          • ntxdaveN Offline
                                            ntxdave
                                            Very well done. So good they look like photos. πŸ‘ πŸ‘ πŸ‘
                                            • 2 / 5
