    Rayscaper Alpha Version Available
    114 Posts 14 Posters 15.0k Views 14 Watching
    • jo-keJ Offline
      jo-ke
      I reinstalled rayscaper on my notebook.
      I reopend the test file, that I made yesterday, but most of material are lost.
      The file is saved in my dropbox.
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        OK, I've found out: HDR has to be refreshed.
        The tramwaymodel renders well exept the blue surfaces.
        http://www.zz7.de
        • P Offline
          Thanks jo-ke for reporting. I can reproduce this bug locally and plan to have a release this week that fixes this bug, and the umlaut crash.
          Regards,
          Thomas
            SandraEli Newcomers
            Please keep us posted when the Mac OS version is out
            I want to test it so bad
            • P Offline
              Hey SandraEli,
              Thanks for the interest! A Mac version is in the works, but the primary focus is to remove the alpha label and release a rock-solid Windows version.
              I will keep you posted when the Mac version is out.
              Cheers,
              Thomas
              • majidM Offline
                majid
                This is great that there are plenty of free materials available in Rayscraper, but wondering how may I change their scale or rotation. Am I missing a tutorial/description?
                • P Offline
                  Hey Majid,
                  You are right. Documentation and tutorials still need to be added for Rayscaper.
                  There are two ways to change the placement of a texture on a material.
                  You can edit the UV transformation of the textures individually or use the global UV editor to edit all textures for a material in parallel.
                  Edit individual textures
                  You can do this by opening the texture settings assigned to the slot, for example, in the below image for the Color slot. And then, modify the transformation; it updates in real-time, so you should be able to eyeball it.
                  Edit all textures of a material
                  Or you can edit all textures for a single material simultaneously using the Global UV editor. This one can be opened via the edits menu at the top of the material.
                  I hope this helps. Let me know if it's not clear, then I can make a quick video.
                  Better documentation and tutorials will arrive soon.
                  Cheers,
                  Thomas
                    sashapepperspray
                    is there a way to pan or zoom on the rendered image in the render viewport?
                    • P Offline
                      Not there yet, but it’s on the roadmap for the 1.0 release.
                      Cheers,
                      Thomas
                      • majidM Offline
                        majid
                        I was really busy recently doing my project. Just installed the latest version and tried it using the previous model. The toolbar does not show and when I start rendering many materials are missed and had to reload them manually. Also it seems slower to me...Maybe it is because my laptop is old and the GPU needs an update...
                        I will keep an eye on this post and pray for fast updates πŸ˜„
                        • P Offline
                          Hey Majid,
                          Which version are you using?
                          You can get the toolbar back with this: https://rayscaper.com/manual/user-interface/#i-lost-my-toolbar - I renamed the title of the toolbar in a previous release, hence the reason it disappeared.
                          Can you share the log and scene where the materials went missing? The log is named SUEX_Rayscaper.log, see item 5 here on how to get it: https://rayscaper.com/getting-help/report-a-bug/
                          What is slower? Do the render times or the user interface feel slower? If it's slow, I consider that a bug πŸ’š
                          I will be releasing Rayscaper on a more frequent cadence now, have to get to 1.0.
                          Cheers,
                          Thomas
                          • majidM Offline
                            majid
                            I did a clean installation, yet the toolbar is missing..
                            I think the denoiser refresh is less frequent maybe ...
                            • P Offline
                              I replied to your message, I need some more info.
                              Cheers,
                              Thomas
                              • majidM Offline
                                majid
                                Thanks THomas. Just replied to it.
                                  sashapepperspray
                                  two questions
                                  are bump maps (height maps) planned to be added for materials?
                                  are cutting components going to be supported (once hidden objects are)?
                                  thank you for your work.
                                  • P Offline
                                    two questions
                                    Yes, bump maps will be in the upcoming 1.0 release.
                                    Are you referring to section cuts? They are planned for the 1.x release.
                                    The Rayscaper roadmap is here: https://rayscaper.com/manual/roadmap/
                                    Cheers,
                                    Thomas
                                    • ntxdaveN Offline
                                      ntxdave
                                      Thanks for sharing. πŸ˜„
                                      Press F1...thank me later
                                        sashapepperspray
                                        I am talking about components that glue to face and cut an opening
                                        • P Offline
                                          Do you mind posting an example to help me understand better?
                                          Thanks,
                                          Thomas
                                          • jo-keJ Offline
                                            jo-ke
                                            that looks much better
                                            saving in a folder containing "ΓΌ" is not possible yet it caused this error:
                                            http://www.zz7.de
                                            • 6
                                            • 4 / 6
