    Rayscaper Alpha Version Available
    114 Posts 14 Posters 17.3k Views 14 Watching
    • majidM Offline
      majid
      This is great that there are plenty of free materials available in Rayscraper, but wondering how may I change their scale or rotation. Am I missing a tutorial/description?
        Hey Majid,
        You are right. Documentation and tutorials still need to be added for Rayscaper.
        There are two ways to change the placement of a texture on a material.
        You can edit the UV transformation of the textures individually or use the global UV editor to edit all textures for a material in parallel.
        Edit individual textures
        You can do this by opening the texture settings assigned to the slot, for example, in the below image for the Color slot. And then, modify the transformation; it updates in real-time, so you should be able to eyeball it.
        Edit all textures of a material
        Or you can edit all textures for a single material simultaneously using the Global UV editor. This one can be opened via the edits menu at the top of the material.
        I hope this helps. Let me know if it's not clear, then I can make a quick video.
        Better documentation and tutorials will arrive soon.
        Cheers,
        Thomas
          sashapepperspray
          is there a way to pan or zoom on the rendered image in the render viewport?
            Not there yet, but it’s on the roadmap for the 1.0 release.
            Cheers,
            Thomas
            • majidM Offline
              majid
              I was really busy recently doing my project. Just installed the latest version and tried it using the previous model. The toolbar does not show and when I start rendering many materials are missed and had to reload them manually. Also it seems slower to me...Maybe it is because my laptop is old and the GPU needs an update...
              I will keep an eye on this post and pray for fast updates πŸ˜„
                Hey Majid,
                Which version are you using?
                You can get the toolbar back with this: https://rayscaper.com/manual/user-interface/#i-lost-my-toolbar - I renamed the title of the toolbar in a previous release, hence the reason it disappeared.
                Can you share the log and scene where the materials went missing? The log is named SUEX_Rayscaper.log, see item 5 here on how to get it: https://rayscaper.com/getting-help/report-a-bug/
                What is slower? Do the render times or the user interface feel slower? If it's slow, I consider that a bug πŸ’š
                I will be releasing Rayscaper on a more frequent cadence now, have to get to 1.0.
                Cheers,
                Thomas
                • majidM Offline
                  majid
                  I did a clean installation, yet the toolbar is missing..
                  I think the denoiser refresh is less frequent maybe ...
                    I replied to your message, I need some more info.
                    Cheers,
                    Thomas
                    • majidM Offline
                      majid
                      Thanks THomas. Just replied to it.
                        sashapepperspray
                        two questions
                        are bump maps (height maps) planned to be added for materials?
                        are cutting components going to be supported (once hidden objects are)?
                        thank you for your work.
                          two questions
                          Yes, bump maps will be in the upcoming 1.0 release.
                          Are you referring to section cuts? They are planned for the 1.x release.
                          The Rayscaper roadmap is here: https://rayscaper.com/manual/roadmap/
                          Cheers,
                          Thomas
                          • ntxdaveN Offline
                            ntxdave
                            Thanks for sharing. πŸ˜„
                            Press F1...thank me later
                              sashapepperspray
                              I am talking about components that glue to face and cut an opening
                                Do you mind posting an example to help me understand better?
                                Thanks,
                                Thomas
                                • jo-keJ Offline
                                  jo-ke
                                  that looks much better
                                  saving in a folder containing "ΓΌ" is not possible yet it caused this error:
                                  http://www.zz7.de
                                    Thanks for reporting! This will be fixed in the next release.
                                    Cheers,
                                    Thomas
                                    • F Offline
                                      fakebob
                                      Hi! This software shows so much promise! I'm excited more than when I first got kerkythea waaaaay back.
                                      I downloaded the newest alpha 0.8.4 today because the 0.8.3 one just crashed my 2023 sketchup pro on either:
                                      a) adding a sketchup texture/colour to a face or
                                      b) opening the Rayscaper Start Render screen (it pops up then everything crashes)
                                      Is anyone else having the same issue? I removed the previous version before installing the update.
                                      Bob
                                      • E Offline
                                        ezequiel1982 Newcomers
                                        Hi! I installed on Sketchup 2022 and I'm getting the following error:
                                        Error; #<LoadError; cannot load such file -- /users/ezequiel/library/application support/sketchup 2022/sketchup/plugins/rayscaper/installed/Mac/2.7.2/0.8.4 Alpha/resources/SUEX_Rayscaper_SetDllDirectory>
                                        /Applications/SketchUp 2022/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.7.1/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb;92;in `require'
                                        /users/ezequiel/library/application support/sketchup 2022/sketchup/plugins/rayscaper/main.rbe;84;in `<module;Rayscaper>'
                                        /users/ezequiel/library/application support/sketchup 2022/sketchup/plugins/rayscaper/main.rbe;5;in `<main>'
                                        /Applications/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `eval'
                                        /Applications/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `require'
                                        /Applications/SketchUp 2022/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb;197;in `load'
                                        /Users/ezequiel/Library/Application Support/SketchUp 2022/SketchUp/Plugins/rayscaper.rb;16;in `register_extension'
                                        /Users/ezequiel/Library/Application Support/SketchUp 2022/SketchUp/Plugins/rayscaper.rb;16;in `<module;Rayscaper>'
                                        /Users/ezequiel/Library/Application Support/SketchUp 2022/SketchUp/Plugins/rayscaper.rb;6;in `<top (required)>'
                                          Hey there,
                                          Looks like you are trying Rayscaper on a Mac. We don't have a Mac version yet. We want to stabilize our Windows version before releasing the Mac version.
                                          Regards,
                                          Thomas
                                          • F Offline
                                            fakebob
                                            @fakebob said:
                                            Oh, my! I'm sorry to have wasted your time, but I read the log file and realised I am using my laptop which has a Radeon RX 5500M graphics card...... which is not CUDA compliant. I should have read the documentation first!
                                            I'll chalk this up to ignorance, and hope there's an Radeon RX version in the future (pretty please!)!
                                            An update, the plot thickens.
                                            So my laptop has 2 graphics cards, an AMD Ryzen integrated and a Radeon RX 5500M that I run my external monitor on. In the interest of sound technical reasoning, I updated my graphics driver software (Adrenalin) to the latest version (24.1.1, released on 11/1/24), did a full reboot, etc. and then got sketchup open. It worked!
                                            And the crashing on picking a material also stopped happening, (even though it did take a little time to get going for some reason).
                                            So, moral of the story: if you're having crashes, update your graphics card software to the latest version first and see if it still happens.
                                            I am getting a message in the log:
                                            2024-02-04 08:07:38.919 (1293.107s) [PreProcessWorker] ERR| OIDN device creation failed: invalid physical device ID: 1
                                            2024-02-04 08:07:38.919 (1293.107s) [PreProcessWorker] ERR| Failed to create the open image denoiser, disabling AI denoise.
                                            What's that all about?
                                            I'm gonna go play with this now!
                                            • 4 / 6
