    On " How to Round Complex Corners in SketchUp"
    17 Posts 6 Posters 1.2k Views 6 Watching
    • Gus RG
      Gus R
      Has anyone tried this with much success? It works for me sometimes and other time it doesn't. I have some examples that I'm stuck on that I can upload but was wondering if anyone had any experience with this technique. I can get the fillet to loft but it just doesn't connect with the two main elements.
      The video is from TutorialsUp and there are no verbal explanations. Just music. Making things more difficult is that I can't find any other instructions on this technique anywhere on the internet. I'm sure Blender could do this in seconds. Just a matter of learning Blender.
      The sample is below the video. It's not a working project and just something to practice with. I left the 3d offsets in place. Each solid is unique.
      Complex Corners Sample.skp
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • BoxB
        I'm unsure what you mean by this. At the most basic level you do understand that the lofted part is a separate group and needs to be exploded to connect with the other parts.
        If that's not the issue could you perhaps explain a little what the problem really is.
        • Gus RG
          Gus R
          Yes, it's a group. I can get it to close with no gaps when I use single cubic Bรฉzier curve (2nd image) but it leaves a gap when I use the B-spline smoothing (1st image) which is the effect I'm looking for. That doesn't allow for a solid without time consuming repair even though it can render OK. I tried doing it with the model at 100X the size and that didn't work. I think it might be this particular form.
          It works fine with simpler intersections although the yellow one needed some coaxing. I can see a bump on the surface.
          • BoxB
            My guess would be that your edges don't have corresponding vertices. If the edges are too different it can force overlaps. I'd also scale the middle profile somewhat as shown in the tut.
            It can also be easier, or more controllable, if you use an arc to join the profiles.
            I haven't tried to make this nice and smooth, it's just thrown together to show another technique.
            • BoxB
              I've done a quick bit using your model. Here I just used a few straight lines to create a path for the beziers. This helps to create a smooth transition.
              • Gus RG
                Gus R
                Thanks for giving it a shot, Box. I tried the skin contours method using a different technique and that worked too. I thought I found another method early this morning and when I went back to try it again it either didn't work or I didn't do it like I did earlier in the morning. I forced it to fillet and everything matched up but it wouldn't turn into a solid even though it looked much better. I guess the need for an object to be a perfect solid is a sort of obsession.
                I think the non-matching number of segments and that middle loop is causing the distortions
                Maybe someone will develop a round complex corner/bevel/fillet plugin.
                • Gus RG
                  Gus R
                  I think I found a solution with the original process. I just copied the loop at the end of the spoke to the top position of that center loop replacing that center loop. I was able to make it a solid with solid inspector and it needed some very minor clean-up.
                  • Gus RG
                    Gus R
                    You can do some pretty cool things with this.
                    • BoxB
                      If you are wanting to do a lot of that sort of thing you may find SUbD works for you.
                      • Gus RG
                        Gus R
                        That's funny because I'm working on a re-render of a Ferrari GTO wheel where I used exactly that. I was thinking about SubD for this too. Thanks.
                        • R
                          rv1974
                          Learning chamfering in proper program would take a fraction of time you spent messing in vain in SU and discussing it here.
                          • Gus RG
                            Gus R
                            True and my intent is to learn Blender but it's about the challenge and this is after all a Sketchup forum and not a Blender forum and it's good for those that want to continue to use Sketchup to learn from these things so I don't see it as being in vain.
                            • R
                              rv1974
                              take a look at plasticity
                              • Gus RG
                                Gus R
                                OK. This took me 5 minutes from opening Plasticity.
                                • ntxdaveN
                                  ntxdave
                                  Another interesting tool. ๐Ÿ‘
                                  Press F1...thank me later
                                  • G
                                    Glenn at home
                                    And MoI 3D would almost be as easy. ๐Ÿ˜‰
                                      If you're half thinking of purchasing it now is a good time because when 1.3 drops its increases
                                      I have it and love it. 1.3 with Blender Bridge is insane looking ๐Ÿ‘
