    On " How to Round Complex Corners in SketchUp"
    17 Posts 6 Posters 967 Views 6 Watching
    • Gus RG Offline
      Gus R
      I think I found a solution with the original process. I just copied the loop at the end of the spoke to the top position of that center loop replacing that center loop. I was able to make it a solid with solid inspector and it needed some very minor clean-up.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Gus RG Offline
        Gus R
        You can do some pretty cool things with this.
        • BoxB Offline
          If you are wanting to do a lot of that sort of thing you may find SUbD works for you.
          • Gus RG Offline
            Gus R
            That's funny because I'm working on a re-render of a Ferrari GTO wheel where I used exactly that. I was thinking about SubD for this too. Thanks.
              rv1974
              @gus r said:
              Making things more difficult is that I can't find any other instructions on this technique anywhere on the internet. I'm sure Blender could do this in seconds. Just a matter of learning Blender.
              Learning chamfering in proper program would take a fraction of time you spent messing in vain in SU and discussing it here.
              • Gus RG Offline
                Gus R
                True and my intent is to learn Blender but it's about the challenge and this is after all a Sketchup forum and not a Blender forum and it's good for those that want to continue to use Sketchup to learn from these things so I don't see it as being in vain.
                  rv1974
                  take a look at plasticity
                  • Gus RG Offline
                    Gus R
                    OK. This took me 5 minutes from opening Plasticity.
                    • ntxdaveN Offline
                      ntxdave
                      Another interesting tool. πŸ‘
                      Press F1...thank me later
                        Glenn at home
                        And MoI 3D would almost be as easy. πŸ˜‰
                          If you're half thinking of purchasing it now is a good time because when 1.3 drops its increases
                          I have it and love it. 1.3 with Blender Bridge is insane looking πŸ‘
