    On " How to Round Complex Corners in SketchUp"
    17 Posts 6 Posters 1.2k Views 6 Watching
    • Gus RG
      Gus R
      Thanks for giving it a shot, Box. I tried the skin contours method using a different technique and that worked too. I thought I found another method early this morning and when I went back to try it again it either didn't work or I didn't do it like I did earlier in the morning. I forced it to fillet and everything matched up but it wouldn't turn into a solid even though it looked much better. I guess the need for an object to be a perfect solid is a sort of obsession.
      I think the non-matching number of segments and that middle loop is causing the distortions
      Maybe someone will develop a round complex corner/bevel/fillet plugin.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • Gus RG
        Gus R
        I think I found a solution with the original process. I just copied the loop at the end of the spoke to the top position of that center loop replacing that center loop. I was able to make it a solid with solid inspector and it needed some very minor clean-up.
        • Gus RG
          Gus R
          You can do some pretty cool things with this.
          • BoxB
            If you are wanting to do a lot of that sort of thing you may find SUbD works for you.
            • Gus RG
              Gus R
              That's funny because I'm working on a re-render of a Ferrari GTO wheel where I used exactly that. I was thinking about SubD for this too. Thanks.
                rv1974
                @gus r said:
                Making things more difficult is that I can't find any other instructions on this technique anywhere on the internet. I'm sure Blender could do this in seconds. Just a matter of learning Blender.
                Learning chamfering in proper program would take a fraction of time you spent messing in vain in SU and discussing it here.
                • Gus RG
                  Gus R
                  True and my intent is to learn Blender but it's about the challenge and this is after all a Sketchup forum and not a Blender forum and it's good for those that want to continue to use Sketchup to learn from these things so I don't see it as being in vain.
                    rv1974
                    take a look at plasticity
                    • Gus RG
                      Gus R
                      OK. This took me 5 minutes from opening Plasticity.
                      • ntxdaveN
                        ntxdave
                        Another interesting tool. πŸ‘
                        Press F1...thank me later
                        • G
                          Glenn at home
                          And MoI 3D would almost be as easy. πŸ˜‰
                            If you're half thinking of purchasing it now is a good time because when 1.3 drops its increases
                            I have it and love it. 1.3 with Blender Bridge is insane looking πŸ‘
