    Subtract from a non solid
    7 Posts 4 Posters 4.0k Views 4 Watching
      DuffBeer
      Hi all. I cannot for the life of me figure this out. I would like to make a hole throught the body of this group by means of subtracting the pin group. I understand the body must be a solid but cannot fathom out how to make such. Have highlighted the axis in colour and can identify the non axix areas. How can I rectify this situation please. Perhaps subtraction is not the way to go. Many thanks
      Router Neck.skp
        Run Fixit by AntonS and it'll fix the issue and make it solid
        https://i.imgur.com/1tCbRD9.png
          Solid Inspector 2 identifies a stray edge. Remove that from the group and it'll be solid.
            Edit>Cut the two pins and open the main-group for editing, Edit>Paste-in-Place.
            Select and Explode the pins.
            Select everything and right-click > context-menu to Intersect everything.
            Delete the unwanted parts of the pins.
            Erase the 'caps' in the ends of the hole.
            Reverse a few of the faces that are not properly oriented...
            Now you have a solid with the desired pin-holes...
            SolidInspector or FixIt might report some errors, which are fixable, but the object still reports as a non-solid.
            But it looks OK !
            Weird...
              SketchUp reports it as a solid for me after Solid Inspector 2 has completed.
                https://i.imgur.com/RZNM5gf.png
                FixIt plus Union and I get Solid.
                  DuffBeer
                  Thanks to all for the speedy replies. Appreciate the free knowledge this forum has to offer.
