    2.2k Posts 487 Posters 934.6k Views 492 Watching
      Rich O Brien Moderator @djcregan
      @djcregan said in SCFLicense: Extension Licensing on Sketchucation:
      Yes
      I fully understand this
      I have Removed the plugin, reinstalled it, even removed and reinstalled Libfredo. I think I will just buy it again as its costing me more the 15 dollars to f.. about trying to sort. Annoying though.
      Send me an email at support@sketchucation.com and we'll walk you through it.
      There's no need to repurchase that's wasting money if the fix is relatively easy.
      • K Offline
        khan1986 Newcomers
        hello i got my license file but when i activate it . it show communication error with sketchucation.
          Rich O Brien Moderator @khan1986
          @khan1986 said in SCFLicense: Extension Licensing on Sketchucation:
          We replied to your email earlier regarding this. Server communication errors are client side. Most likely a strict network policy, firewall or admin privileges are the root cause.
          We refunded your purchase and disabled your license per your request via email.
            junphuc17945 @TIG
            @TIG my old pc, not installed new Fredo version, so i can not release license
            TIGT 1 Reply Last reply Reply Quote 0
              TIG Moderator @junphuc17945
              @junphuc17945
              As Rich explained in the post just before yours...
              Send an email at support@sketchucation.com and he'll walk you through fixing it.
                Lprawita Newcomers
                I just bought the $50 license and I tried to activate it.
                I got an error message like this:
                  Rich O Brien Moderator @Lprawita
                  @Lprawita
                  That is your network blocking access to our server.
                  Please whitelist *.sketchucation.com or activate on a less strict network
                  D 1 Reply Last reply Reply Quote 0
                    dhcu321 Newcomers @Rich O Brien
                    @Rich-O-Brien
                    Hello, I really need your help.
                    First of all, I'm sorry that i'm not good at english.
                    I have two problems.
                    The first one is that Joint Push Pull License ID 165592; is not cancelled.
                    Can you release it?
                    The second one is to register for a license on a new PC, but I got an A04 error code.
                    How can I fix it?
                    Thank you.
                      Rich O Brien Moderator @dhcu321
                      @dhcu321
                      Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp (on both devices separately) and copy/paste the output
                      of both devices into your reply.
                        mencalada Newcomers
                        Hola porfavor envio este correo para socilicitar la etension del plugin Joint Push Pull
                          DietVillaa Newcomers
                          Hello, can you also release seat Seat ID: 190451; HW ID: RR1728036983.0J; Date of activation: 04/10/2024, thank you! hoping for your fast repoonse!
                            Rich O Brien Moderator @DietVillaa
                            @DietVillaa
                            @dhcu321 Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp (on both devices separatel...
                            sketchucation (community.sketchucation.com)
                              Thank you for your reply.
                              These problems occurred on the same PC.
                              I think this error occurred while logging into Windows.
                              Let me know if you need any more information.
                              @Rich-O-Brien
                              Fredo6 Plugins Information on 2024-10-21 11:22:07 +0900
                              • Platform: x64-mswin64_140 - Ruby: 2.7.2
                              • Sketchup: 22.0.354
                              • LibFredo6: v14.4c
                              • LibFredo6 Binary loaded
                              • Sketchucation ExtensionStore: 4.4.1
                              • SCFLicense: v6.4a - 74
                              • Fredo6 Plugins
                                Curviloft v2.0a
                                FredoScale v3.6a
                                JointPushPull v4.8a
                                RoundCorner v3.4a
                              • SCFLicense directory present
                                Signature File: 2024-06-24 10:24:45 +0900
                                @dhcu321 Please update Libfredo to latest release
                                SketchUp Plugins | PluginStore | SketchUcation
                                SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                (sketchucation.com)
                                  Javier_ELARQ Newcomers
                                  Hola, como hago para obtener la licencia?
                                    Darius
                                    Hello,
                                    Have 3 seats on an extension, vant use the 1st one, only two releasable ones. How can I use the first one ? aaa.png
                                      Rich O Brien Moderator @Darius
                                      @Darius Update Sketchucation Tools and Libfredo on that device to enable online releasing for that device.
                                      Or open SketchUp on that device and release a seat using the License dialog.
                                        Darius @Rich O Brien
                                        @Rich-O-Brien Problem is that we have 3 working seats, but the none of it uses 1st license. Is there a way to release it manually ?
                                          @Darius said in SCFLicense: Extension Licensing on Sketchucation:
                                          Sorry, your message is unclear. You have working seats that use the license file is describing a proper use case.
                                          If you go to any of the devices you can release the seat from its License dialog. Since I don't know what extension you are talking about I can't give more details.
                                          If you want to email us at support@sketchucation.com we'll try help.
                                            celestinf
                                            Bonjour,
                                            Je me permets de vous écire car j'ai fais l'acquisition en 2023 de plusieurs licences que je vois bien dans mon espace License. J'ai du changer de disque dur et réinstaller l'ensemble des éléments de mon pc. Lorsque je lance par exemple le fredoscale depuis sketchup j'ai le message me disant d'acheter ou utiliser ma license. Je vais donc charger dans mon espace License la License que je valide ensuite par sketchup et j'obtient le message "erreur dans la validation de licence, requete à sketchupaction ERROR_A0B.
                                            Pouvez vous me donner la procédure afin que je puisse corriger cela?
                                            Merci à vous
                                            • 95
                                            • 96
                                            • 97
                                            • 98
                                            • 99
                                            • 109
                                            • 110
                                            • 97 / 110
