    2.2k Posts 485 Posters 894.5k Views 490 Watching
      @pklenk702 said:
      Could an Ad Blocker, or some other program/adjustment/device that the IT people have installed in their attempt to keep us kids in line be preventing access to the appropriate files
      In those cases where IPs or URLs are monitored/blocked you usually see a 'Cannot Access Sketchucation' type message when you try to license.
      Your ruby output seems to suggest your Libfredo is not installed correctly. You can see LibFredo6 Binary NOT loaded in the output in the console.
      I would go into C:\Users\SomeName\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins and delete the Fredo6_!LibFredo6 folder and the Fredo6_!LibFredo6.rb file
      If SketchUp is open close it and start it again. Now install Libfredo and restart SketchUp.
      Now run Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support and see if there's still errors. In an ideal environment you should see something like this
      Fredo6 Plugins Information on 2024-02-26 19;20;48 +0000
      - Platform; x64-mswin64_140 - Ruby; 2.7.7
      - Sketchup; 23.1.340
      - LibFredo6; v14.2a
      - [b]LibFredo6 Binary loaded[/b]
      - Sketchucation ExtensionStore; 4.3.1
      Your setup is crying about Libfredo mostly and if that gets sorted we can look into activating.
        arjmbenitez
        I need this
          Jillyace Newcomers
          Hello I recently had to reset my laptop and had to redownload sketchup. I share the SCFLicense with 2 other friends and all the seats have been taken. When I redownload sketchup before the license usually still works but this time around it doesn't anymore. What can I do?
            Release the seat at https://sketchucation.com/webshop/my-licences.php
              sra
              Hello, I purchased FREDO6 BUNDLE 2022-8 PACK. I received the license and extension files, but I got an error code ( ERROR_A04 ) in the license registration process.
              FYI, I'm using the Sketchup 2022 program, the SketchUcation version is 4.3.1, and the Fredo6 LibFredo6 version is 14.2.
              I also converted computer user name to English name, but it won't be solved.
              What kind of solution is there? I want a quick solution.
              I'll be waiting for your answer.
              registration error
              SCF LicenseLog
                Close SketchUp
                Delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
                Open SketchUp
                Activate license per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                  sra
                  I'm sorry, but it won't be solved by the way you told me. Error codes B03 and A04 keep coming up. I still need help.
                    Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                    • W Offline
                      Wujcenty
                      Hello, @Rich-O-Brien!
                      Can you release this licences:
                      Round Corner:
                      Seat ID: 29019; HW ID: AM1649685560.0Q; Date of activation: 11/04/2022
                      JointPushPull:
                      Seat ID: 29018; HW ID: AM1649685560.0Q; Date of activation: 11/04/2022
                      Curviloft:
                      Seat ID: 34946; HW ID: AM1649685560.0Q; Date of activation: 12/05/2022
                      FredoScale:
                      Seat ID: 35457; HW ID: AM1649685560.0Q; Date of activation: 16/05/2022
                      I don't have access to this computer anymore.
                        sra
                        Thanks for your reply.
                        Here is LibFredo6 plugins information.
                        • Sketchucation ExtensionStore: 4.3.1
                        • SCFLicense: v6.1a - 72
                        • Fredo6 Plugins
                          Curviloft v1.9b
                          Curvizard v2.4b
                          FredoScale v3.5a
                          JointPushPull v4.7a
                          RoundCorner v3.3a
                          ThruPaint v2.3a
                        • SCFLicense directory present
                          Signature File: 2024-03-08 09:20:45 +0900
                          • Fredo6 Plugins
                            Curviloft v1.9b
                            Curvizard v2.4b
                            FredoScale v3.5a
                            JointPushPull v4.7a
                            RoundCorner v3.3a
                            ThruPaint v2.3a
                          Please install Libfredo
                          https://sketchucation.com/pluginstore?pln=LibFredo6
                          Restart SketchUp after installation and activate per guide
                            Rich O Brien Moderator @Wujcenty
                            @Wujcenty send an email to support[at]sketchucation.com and we'll look into it
                            W 1 Reply Last reply Reply Quote 0
                            • W Offline
                              Wujcenty @Rich O Brien
                              @Rich-O-Brien Thanks!
                              • H Offline
                                hectoremanuel
                                Hello, my license was uninstalled. When I want to install it again, this sign pops up. How can I solve that_?30800068-19a9-4684-b17b-311277389153-image.png
                                  Rich O Brien Moderator @hectoremanuel
                                  @hectoremanuel
                                  Follow the steps in the alert
                                  • Click OK
                                  • Delete signature file
                                  • Restart SketchUp
                                    da800429 Newcomers
                                    TIGT 1 Reply Last reply Reply Quote 1
                                      TIG Moderator @da800429
                                      @da800429
                                      The trial period has expired.
                                      Have you downloaded the license file, placed it in a safe folder on your computer, then run the submenu item for FredoScale - the dialog appears as you showed.
                                      Follow the instructions that Rich sets out in the first post of this thread {although the latest version of the SketchUcation tools is now 4..4.0 and Fredo has updated his LibFredo and most of his Extensions].
                                      The failure to communicate with SketchUcation.com might be do to your firewall blocking the site - whitelist it.
                                      sketchucation.com ?
                                      IP addresses 178.63.47.155, 144.76.69.227
                                      D 1 Reply Last reply Reply Quote 0
                                        da800429 Newcomers @TIG
                                        There is a paid purchase serial number
                                        It was usable for a few days but suddenly unavailable.
                                        The above content appears after I log in again
                                        @TIG 1713108206236.jpg ![alt text](![image url](1713108238265.jpg image url))
                                          Rich O Brien Moderator @da800429
                                          @da800429
                                            da800429 Newcomers @Rich O Brien
                                            @Rich-O-Brien
                                            Is this what you are referring to?
                                            Fredo6 Plugins Information on 2024-04-15 02:03:34 +0800
                                            • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                            • Sketchup: 22.0.316
                                            • LibFredo6: v14.3b
                                            • LibFredo6 Binary loaded
                                            • Sketchucation ExtensionStore: 4.4.0
                                            • SCFLicense: v6.4a - 74
                                            • Fredo6 Plugins
                                              Curviloft v2.0a
                                              Curvizard v2.5a
                                              FredoCorner v2.7a
                                              FredoScale v3.6a
                                              FredoSpline v2.6a
                                              FredoTools v4.5a
                                              JointPushPull v4.8a
                                              RoundCorner v3.4a
                                              ToolsOnSurface v2.6a
                                              TopoShaper v2.7a
                                              VisuHole v1.5a
                                              Signature File: 2023-08-22 06:52:55 +0800
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 109
                                            • 110
                                            • 91 / 110
