    2.3k Posts 515 Posters 2.5m Views 520 Watching
      arjmbenitez
      I need this
        Jillyace Newcomers
        Hello I recently had to reset my laptop and had to redownload sketchup. I share the SCFLicense with 2 other friends and all the seats have been taken. When I redownload sketchup before the license usually still works but this time around it doesn't anymore. What can I do?
          Release the seat at https://sketchucation.com/webshop/my-licences.php
            sra
            Hello, I purchased FREDO6 BUNDLE 2022-8 PACK. I received the license and extension files, but I got an error code ( ERROR_A04 ) in the license registration process.
            FYI, I'm using the Sketchup 2022 program, the SketchUcation version is 4.3.1, and the Fredo6 LibFredo6 version is 14.2.
            I also converted computer user name to English name, but it won't be solved.
            What kind of solution is there? I want a quick solution.
            I'll be waiting for your answer.
            registration error
            SCF LicenseLog
              Close SketchUp
              Delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
              Open SketchUp
              Activate license per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
                sra
                I'm sorry, but it won't be solved by the way you told me. Error codes B03 and A04 keep coming up. I still need help.
                  Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
                  • W
                    Wujcenty
                    Hello, @Rich-O-Brien!
                    Can you release this licences:
                    Round Corner:
                    Seat ID: 29019; HW ID: AM1649685560.0Q; Date of activation: 11/04/2022
                    JointPushPull:
                    Seat ID: 29018; HW ID: AM1649685560.0Q; Date of activation: 11/04/2022
                    Curviloft:
                    Seat ID: 34946; HW ID: AM1649685560.0Q; Date of activation: 12/05/2022
                    FredoScale:
                    Seat ID: 35457; HW ID: AM1649685560.0Q; Date of activation: 16/05/2022
                    I don't have access to this computer anymore.
                      sra
                      Thanks for your reply.
                      Here is LibFredo6 plugins information.
                      • Sketchucation ExtensionStore: 4.3.1
                      • SCFLicense: v6.1a - 72
                      • Fredo6 Plugins
                        Curviloft v1.9b
                        Curvizard v2.4b
                        FredoScale v3.5a
                        JointPushPull v4.7a
                        RoundCorner v3.3a
                        ThruPaint v2.3a
                        Signature File: 2024-03-08 09:20:45 +0900
                        • Fredo6 Plugins
                          Curviloft v1.9b
                          Curvizard v2.4b
                          FredoScale v3.5a
                          JointPushPull v4.7a
                          RoundCorner v3.3a
                          ThruPaint v2.3a
                        Please install Libfredo
                        https://sketchucation.com/pluginstore?pln=LibFredo6
                        Restart SketchUp after installation and activate per guide
                          Rich O Brien Moderator @Wujcenty
                          @Wujcenty send an email to support[at]sketchucation.com and we'll look into it
                          W 1 Reply Last reply
                          • W
                            Wujcenty @Rich O Brien
                            @Rich-O-Brien Thanks!
                            • H
                              hectoremanuel
                              Hello, my license was uninstalled. When I want to install it again, this sign pops up. How can I solve that_?30800068-19a9-4684-b17b-311277389153-image.png
                                Rich O Brien Moderator @hectoremanuel
                                @hectoremanuel
                                Follow the steps in the alert
                                • Click OK
                                • Delete signature file
                                • Restart SketchUp
                                  da800429 Newcomers
                                  TIGT 1 Reply Last reply
                                    TIG Moderator @da800429
                                    @da800429
                                    The trial period has expired.
                                    Have you downloaded the license file, placed it in a safe folder on your computer, then run the submenu item for FredoScale - the dialog appears as you showed.
                                    Follow the instructions that Rich sets out in the first post of this thread {although the latest version of the SketchUcation tools is now 4..4.0 and Fredo has updated his LibFredo and most of his Extensions].
                                    The failure to communicate with SketchUcation.com might be do to your firewall blocking the site - whitelist it.
                                    sketchucation.com ?
                                    IP addresses 178.63.47.155, 144.76.69.227
                                    D 1 Reply Last reply
                                      da800429 Newcomers @TIG
                                      There is a paid purchase serial number
                                      It was usable for a few days but suddenly unavailable.
                                      The above content appears after I log in again
                                      @TIG 1713108206236.jpg ![alt text](![image url](1713108238265.jpg image url))
                                        Rich O Brien Moderator @da800429
                                        @da800429
                                          da800429 Newcomers @Rich O Brien
                                          @Rich-O-Brien
                                          Is this what you are referring to?
                                          Fredo6 Plugins Information on 2024-04-15 02:03:34 +0800
                                          • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                          • Sketchup: 22.0.316
                                          • LibFredo6: v14.3b
                                          • LibFredo6 Binary loaded
                                          • Sketchucation ExtensionStore: 4.4.0
                                          • SCFLicense: v6.4a - 74
                                          • Fredo6 Plugins
                                            Curviloft v2.0a
                                            Curvizard v2.5a
                                            FredoCorner v2.7a
                                            FredoScale v3.6a
                                            FredoSpline v2.6a
                                            FredoTools v4.5a
                                            JointPushPull v4.8a
                                            RoundCorner v3.4a
                                            ToolsOnSurface v2.6a
                                            TopoShaper v2.7a
                                            VisuHole v1.5a
                                            Signature File: 2023-08-22 06:52:55 +0800
                                            @da800429 In this post your licensing version is 6.1a - 72
                                            Now its 6.4a -74 so that suggest you've updated Sketchucation Tools to 4.4.0
                                            What happens now if you license using your license file/s at https://sketchucation.com/webshop/my-licences.php ?
                                            Please follow this guide for activation instructions
                                            D Rich O BrienR 2 Replies Last reply
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 115
                                            • 116
                                            • 91 / 116
