    2.3k Posts 517 Posters 3.0m Views 522 Watching
      @jillyace said:
      Hello I recently had to reset my laptop and had to redownload sketchup. I share the SCFLicense with 2 other friends and all the seats have been taken. When I redownload sketchup before the license usually still works but this time around it doesn't anymore. What can I do?
      Release the seat at https://sketchucation.com/webshop/my-licences.php
        sra
        Hello, I purchased FREDO6 BUNDLE 2022-8 PACK. I received the license and extension files, but I got an error code ( ERROR_A04 ) in the license registration process.
        FYI, I'm using the Sketchup 2022 program, the SketchUcation version is 4.3.1, and the Fredo6 LibFredo6 version is 14.2.
        I also converted computer user name to English name, but it won't be solved.
        What kind of solution is there? I want a quick solution.
        I'll be waiting for your answer.
        registration error
        SCF LicenseLog
          Close SketchUp
          Delete the signature file at C:\Users\SomeName\AppData\Local\SCF Licenses
          Open SketchUp
          Activate license per https://downloads.sketchucation.com/licensing/SCFLicense-Instructions_to_Users.pdf
            sra
            I'm sorry, but it won't be solved by the way you told me. Error codes B03 and A04 keep coming up. I still need help.
              Please run the Window > Libfredo Settings > Fredo6 Plugins Information for Sketchucation Support menu command in SketchUp and copy/paste the output into your reply.
              • W
                Wujcenty
                Hello, @Rich-O-Brien!
                Can you release this licences:
                Round Corner:
                Seat ID: 29019; HW ID: AM1649685560.0Q; Date of activation: 11/04/2022
                JointPushPull:
                Seat ID: 29018; HW ID: AM1649685560.0Q; Date of activation: 11/04/2022
                Curviloft:
                Seat ID: 34946; HW ID: AM1649685560.0Q; Date of activation: 12/05/2022
                FredoScale:
                Seat ID: 35457; HW ID: AM1649685560.0Q; Date of activation: 16/05/2022
                I don't have access to this computer anymore.
                  sra
                  Thanks for your reply.
                  Here is LibFredo6 plugins information.
                  • Sketchucation ExtensionStore: 4.3.1
                  • SCFLicense: v6.1a - 72
                  • Fredo6 Plugins
                    Curviloft v1.9b
                    Curvizard v2.4b
                    FredoScale v3.5a
                    JointPushPull v4.7a
                    RoundCorner v3.3a
                    ThruPaint v2.3a
                    Signature File: 2024-03-08 09:20:45 +0900
                    • Fredo6 Plugins
                      Curviloft v1.9b
                      Curvizard v2.4b
                      FredoScale v3.5a
                      JointPushPull v4.7a
                      RoundCorner v3.3a
                      ThruPaint v2.3a
                    Please install Libfredo
                    https://sketchucation.com/pluginstore?pln=LibFredo6
                    Restart SketchUp after installation and activate per guide
                      Rich O Brien Moderator @Wujcenty
                      @Wujcenty send an email to support[at]sketchucation.com and we'll look into it
                      W 1 Reply Last reply
                      • W
                        Wujcenty @Rich O Brien
                        @Rich-O-Brien Thanks!
                        • H
                          hectoremanuel
                          Hello, my license was uninstalled. When I want to install it again, this sign pops up. How can I solve that_?30800068-19a9-4684-b17b-311277389153-image.png
                            Rich O Brien Moderator @hectoremanuel
                            @hectoremanuel
                            Follow the steps in the alert
                            • Click OK
                            • Delete signature file
                            • Restart SketchUp
                              da800429 Newcomers
                              TIGT 1 Reply Last reply
                                TIG Moderator @da800429
                                @da800429
                                The trial period has expired.
                                Have you downloaded the license file, placed it in a safe folder on your computer, then run the submenu item for FredoScale - the dialog appears as you showed.
                                Follow the instructions that Rich sets out in the first post of this thread {although the latest version of the SketchUcation tools is now 4..4.0 and Fredo has updated his LibFredo and most of his Extensions].
                                The failure to communicate with SketchUcation.com might be do to your firewall blocking the site - whitelist it.
                                sketchucation.com ?
                                IP addresses 178.63.47.155, 144.76.69.227
                                D 1 Reply Last reply
                                  da800429 Newcomers @TIG
                                  There is a paid purchase serial number
                                  It was usable for a few days but suddenly unavailable.
                                  The above content appears after I log in again
                                  @TIG 1713108206236.jpg ![alt text](![image url](1713108238265.jpg image url))
                                    Rich O Brien Moderator @da800429
                                    @da800429
                                      da800429 Newcomers @Rich O Brien
                                      @Rich-O-Brien
                                      Is this what you are referring to?
                                      Fredo6 Plugins Information on 2024-04-15 02:03:34 +0800
                                      • Platform: x64-mswin64_140 - Ruby: 2.7.2
                                      • Sketchup: 22.0.316
                                      • LibFredo6: v14.3b
                                      • LibFredo6 Binary loaded
                                      • Sketchucation ExtensionStore: 4.4.0
                                      • SCFLicense: v6.4a - 74
                                      • Fredo6 Plugins
                                        Curviloft v2.0a
                                        Curvizard v2.5a
                                        FredoCorner v2.7a
                                        FredoScale v3.6a
                                        FredoSpline v2.6a
                                        FredoTools v4.5a
                                        JointPushPull v4.8a
                                        RoundCorner v3.4a
                                        ToolsOnSurface v2.6a
                                        TopoShaper v2.7a
                                        VisuHole v1.5a
                                        Signature File: 2023-08-22 06:52:55 +0800
                                        @da800429 In this post your licensing version is 6.1a - 72
                                        Now its 6.4a -74 so that suggest you've updated Sketchucation Tools to 4.4.0
                                        What happens now if you license using your license file/s at https://sketchucation.com/webshop/my-licences.php ?
                                        Please follow this guide for activation instructions
                                        D Rich O BrienR 2 Replies Last reply
                                          @Rich-O-Brien
                                          I've updated to the latest version.
                                          My license is permanent, do I need to purchase it again?
                                            Rich O Brien Moderator @Rich O Brien
                                            Can you provide us info on these steps above?
                                            @da800429 said in SCFLicense: Extension Licensing on Sketchucation:
                                            No
                                            • 89
                                            • 90
                                            • 91
                                            • 92
                                            • 93
                                            • 115
                                            • 116
                                            • 91 / 116
