    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    452 Posts 111 Posters 596.4k Views 112 Watching
      @samuel_t
      Med resolution (who don't works)
      https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_a8a4796d-366a-45ec-b815-09b229a99bbd__2_.fbx
      Low resolution who works
      https://moiscript.weebly.com/uploads/3/9/3/8/3938813/tripo_convert_c35581b0-d804-4224-990b-b31022f0afd8.fbx
      Maybe the textures...
      https://moiscript.weebly.com/uploads/3/9/3/8/3938813/uir-source.fbx
      But maybe sure on my latop 12 years old there is only 8G Hard Memory! 🙂
      • U Offline
        Uhlala Newcomers
        Hi, I have the same message as romanencom with Universal Importer 1.2.6
        Any idea? Thanks.
        • U Offline
          Uhlala Newcomers @romanencom
          @romanencodem Hi, I have the same issue with Universal Importer 1.2.6
            BGUERRE
            hello
            thank you to provide universal importer to the SU community.
            Unfortunately, i did try to dowload .obj file, but get the following error message
            OBJ fil is about 16 MO and he was generating by 3D Snap an IOS app.
            Any suggestion ?.
            thank you
            Bruno
            samuel_tS 1 Reply Last reply Reply Quote 0
            • samuel_tS Offline
              samuel_t @BGUERRE
              @BGUERRE Hello,
              You're welcome!
              Seems there's an issue in .MTL file paired with .OBJ file.
              Can you please upload them and send me both (in private if you prefer)?
              • Rich O BrienR Rich O Brien referenced this topic on
              • K Offline
                kevgrn114 Newcomers
                Hi, Just found your Universal plugin today, I've been wanting something like that for a long time!! It seem to work fine for me exporting dxf files from lightburn except that anything that is a curve is chopped up into dashed lines. Squares come in fine but circles or curves get the dash effect. Any thoughts? Thanks
                  titiinorbita
                  This post is deleted!
                    artemisglt
                    hello! and thank you for the great plug in! I am trying to import an obj file of this bed in sketchup.
                    link text
                    I select the option to claim missing textures and select the obj file. In which order do I select the textures?
                    The model has a diffuse map, two normal maps and a displacement map. If I select the diffuse map and the two normal maps, I get an error..
                    Any ideas?
                    panixiaP 1 Reply Last reply Reply Quote 0
                    • panixiaP Offline
                      panixia @artemisglt
                      @artemisglt You just select the diffuse map and call it a day.
                      (you can add the other maps after the import if you really need them)
                      A 1 Reply Last reply Reply Quote 0
                        artemisglt @panixia
                        @panixia if i press claim missing textures, then import the obj object, I select the diffuse map and then it asks me to select again another missing texture. if i click the normal map, it asks me for a third texture and if select all three I receive an error. if i select the diffuse map every time again I receive an error.. any ideas?
                        • panixiaP Offline
                          panixia @artemisglt
                          @artemisglt does it happen with a specific model or with all models?
                            artemisglt @panixia
                            @panixia it happens with all the models, that is why I asked to see what I am doing wrong. I send the link to the initial model, I referred to, if you can have a look.
                            • 19
                            • 20
                            • 21
                            • 22
                            • 23
                            • 23 / 23
