    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 697.8k Views 151 Watching
    • OxerO
      Oxer
      @fredo6 said:
      Strange. Normally, Sketchup should take care of that, as it does on PC with the Alt toggle.
      By the way, my understanding, the mapping of modifiers between PC and Mac is
      • Shift on PC --> Shift
      • Ctrl on PC --> Command (i.e. the apple key)
      • Alt on PC --> Ctrl
      In edge selection, ALT is used for setting the 'all connected edges' mode
      1. as a toggle (press and release), to set/unset this mode as the current mode
      2. when clicking (keep pressed), to temporarily force the selection of all connected edges, regardless of the current mode
      Do you have a problem for 1) only, or for both usages?
      ALT on PC --> CMD ⌘ on Mac
      CTRL on PC --> ALT on Mac
      If I use CMD instead of ALT, the 2) usage works fine.
      CTRL+Left-click on Mac it's like a right-click, it appears the contextual menu, press and release CTRL key on the Mac does nothing.
      I translated the last version on FredoCorner to Spanish language, here is the file:
      FredoCorner_ES.lang.zip
      http://www.oxervision.blogspot.com/
      • fredo6F
        fredo6
        Woooh. I thought the equivalent of CTRL on PC was Command⌘ on Mac.
        Then within FredoCorner, does the ⌘Z works as the shortcut for Undo (for instance an edge selection), or do you need to use ALT-Z?
        • OxerO
          Oxer
          I talking about the use of keys modifiers on FredoCorner.
          If I press ⌘Z or ALT-Z these modifiers don't work for Undo (for instance an edge selection), I can Undo the operations when I do click on curved arrow (left) of the palette.
          macOS 10.13.6
          SU2016
          • fredo6F
            fredo6
            NEW RELEASE: FredoCorner v1.1d - 19 Sep 18
            FredoCorner 1.1d includes bug fixing, as well as a full translation in Spanish by Oxer and in Chinese (by Arc).
            Requirement: LibFredo6 8.6e
            Please note that:
            • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
            • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
            • Terminal corners (that is ending on a single edge) may present issues and bugs
            • Variable offset tools are experimental
            • No documentation yet, so watch the videos that I will publish.
            Please report issues, questions and any feedback in the present thread
            Home Page of FredoCorner for information and Download.
            Main post of this FredoCorner thread.
            • fredo6F
              fredo6
              Oxer,
              You are right. Actually, this is the Sketchup API doing this mapping of CTRL on PC toward ALT on Mac. I always thought it was CTRL on PC toward ⌘ on Mac!!
              I can indeed change the behavior.
              I just open a thread to get the opinions of Mac users.
              Fredo
              PS: by the way, in the native Push Pull tool, what is the modifier key on Mac to keep the original face?
              • L
                laudhi
                I don't know this is a bug or not, but there is a difference between Fredo Corner and Round Corner when applied to simple box with holes.
                • OxerO
                  Oxer
                  It's the ALT key on Mac.
                  • jiminy-billy-bobJ
                    jiminy-billy-bob
                    Does this help, Fredo ?
                    https://www.sketchup.com/sites/www.sketchup.com/files/sketchup2018refcardmac.pdf
                    • fredo6F
                      fredo6
                      Very useful. Thanks a lot.
                      On Mac, it seems that Sketchup uses Alt as the equivalent of Ctrl on PC. Skeytchup also uses Command on Mac as a modifier (which appears to be the equivalent of Alt on PC).
                      So I better stick to this convention and keep my plugins the way they work.
                      Simply, I will change the tooltips and documentation, so that it is reflected.
                      Fredo
                      • E
                        evapal
                        Hi Fredo,
                        You make fantastic plugins that allows to explore new design forms and I'd like to thank you for that. It's just I've downloaded your new FredoCorner as it is prefect to model a seat I am working on right now but it doesn't seem to work. I can see the toolbar but don't get the control board. I've got Mac and Sketchup 2017. I'd appreciate any word of advice :: 😢
                        • fredo6F
                          fredo6
                          @evapal said:
                          Hi Fredo,
                          Could you elaborate a little bit more on your problem.
                          Could you also open the Ruby console before you launch FredoCorner, to see if there are errors messages.
                          Note that you need to upgrade LibFredo6 to its latest version (8.6g)
                          Fredo
                          • fredo6F
                            fredo6
                            NEW RELEASE: FredoCorner v1.1e - 23 Sep 18
                            FredoCorner 1.1e includes bug fixing and small adjustments.
                            Requirement: LibFredo6 8.6g
                            Please note that:
                            • E
                              elmouthcall
                              Bonjour,
                              Je viens de télécharger round corner.
                              Je suis en version 2018 pro et je n'arrive pas à le trouver dans sketchup.
                              Comment faire, s'il te plait.
                              Cordialement.
                              • TIGT
                                @elmouthcall said:
                                Bonjour,
                                Cordialement.
                                It also requires an updated LibFredo.
                                Download it from here: https://sketchucation.com/pluginstore?pln=LibFredo6
                                Install that.
                                Restart SketchUp to ensure everything is synced.
                                Il nécessite également une mise à jour LibFredo.
                                Téléchargez-le ici: https://sketchucation.com/pluginstore?pln=LibFredo6
                                Installez ça.
                                Redémarrez SketchUp pour vous assurer que tout est synchronisé.
                                • fredo6F
                                  fredo6
                                  @milenoliegsalz said:
                                  I just wanted to share some bugs which I did experiment while using the extension:
                                  I have difficulty to see the images (links are not supported with the tag [img]). Could you attach them as JPG or PNG.
                                  Also, it may be useful you attach the model(s)
                                  Fredo
                                  • M
                                    milenoliegsalz
                                    I was really waiting for such an extension for years and now its already here. Thumbs up for FREDO!!
                                    1- When trying to round up the intersection between two cylinders, I get this:
                                    SKP file:
                                    cylinder.skp
                                    2- When trying to round up an Already rounded geometry (because I want another radius for those edges), I get this:
                                    note: I needed a radius of 5mm but the maximum I got was 2,5mm
                                    Note: if I try to set the different radius, at the same time as I set the radius of all the other edges (with the experimental tool), I get also some strange geometry.
                                    SKP file:
                                    different roundings rad.skp
                                    3- If I try to bevel with the round tool and I set it to 1 segment, the faces of the corners disappear:
                                    SKP file:
                                    bevel.skp
                                    greetings
                                    Mileno
                                    • M
                                      milenoliegsalz
                                      just fixed the post and aded the SKP files.
                                      thanks,
                                      Mileno
                                      • fredo6F
                                        fredo6
                                        @milenoliegsalz
                                        Thanks for logging these cases. Very useful.
                                        As a general comment, try to design your model on a much larger scale. All your exemples are very small and Sketchup does not really like to work at these tiny scale, and in many cases has difficulty to generate faces when too small. This is a general comment, not just or FredoCorner.
                                        1) On the cylinders intersection, this is a current deficiency of FredoCorner, related to reversed offset of segments, which you can see on the picture below. I will fix this progressively. In the meantime, I think RoundCorner is less sensitive to these problems and would work better.
                                        2) On the double rounding, you can do it in one operation, using the assymmetrical rounding capability of FredoCorner, as shown on the video below. Again, scale your model up (factor 10 or 20). I still need to find out why you need to enable "strict Offset" to get the super-rounding.
                                        2) On the simple bevel, the missing triangles at corners is due to a bug which authorizes an odd number of segments in the Round tool, whereas it does only work with an even number of segments. I fixed it for the next release. If you wish a true bevel with 1 single segment, use instead the Bevel tool (green icon in the toolbar).
                                        Fredo
                                        • fredo6F
                                          fredo6
                                          NEW RELEASE: FredoCorner v1.1f - 10 Oct 18
                                          FredoCorner 1.1f includes bug fixing and small adjustments.
                                          Please note that:
                                          • fredo6F
                                            fredo6
                                            NEW RELEASE: FredoCorner v1.2a - 14 Oct 18
                                            FredoCorner 1.2a introduces Offset modes. It also includes bug fixing and small adjustments.
                                            Offset mode pertains to the way the distance between offset lines and borders is computed.
                                            1. OFFSET: offset is measured on border faces, perpendicularly. This gives a global uniform rounding of shapes.
                                            2. RADIUS: offset is computed based on a circle of specified radius which is tangent to the border faces. The offset is therefore dependent on the angle at each individual edges. If the angle is lower than 90 degrees, the rounding will appear larger in width, or smaller if the angle is greater than 90 degrees. Visually, the rounding of a shape may end up with non uniform rounding.
                                            The video below explains the concept.
                                            Please note that, in the current version of FredoCorner:
                                            • 6
                                            • 22
                                            • 23
                                            • 4 / 23
