    [Plugin][$] FredoCorner - v2.7a - 31 Mar 24
    442 Posts 153 Posters 731.8k Views 151 Watching
    • fredo6F
      @pixero said:
      Would it be possible with some kind of Global on/off switch so we can keep SU light and just turn it on before rendering?
      Maybe even some code that render engines could use to have it render even without turning it on in SU view?
      I can possibly implement a global switch. But again, you have to be extra careful with Undo / Redo.
      I'll take an additional approach which may be safer.
      • fredo6F
        NEW RELEASE: FredoCorner v1.1c - 11 Sep 18
        FredoCorner 1.1c includes some bug fixing, a full French translation as well as a first partial translation in Chinese by Arc.
        Requirement: LibFredo6 8.6d
        Please note that:
        • there are known issues and likely bugs here and there
        • This concerns in particular Collisions, i.e. when the offset is too large.
        • Terminal corners (that is ending on a single edge) may present issues and bugs
        • Variable offset tools are experimental
        • No documentation yet, so watch the videos that I will publish.
        Please report issues, questions and any feedback in the present thread
        Home Page of FredoCorner for information and Download.
        Main post of this FredoCorner thread.
        • OxerO
          Oxer
          There is a problem with the Ctrl key modifier on macOS, the Ctrl key on Mac is like a mouse right-click, it appears the Contextual Menu, generally the function assigned to the Ctrl key on Pc is the Alt Key on Mac.
          Example: When I'm in selection mode, if I press Alt key = Single Edge, i.e., the Alt key replaces to the Ctrl key on Mac.
          Fredo, is there a solution to this problem?
          • fredo6F
            Strange. Normally, Sketchup should take care of that, as it does on PC with the Alt toggle.
            By the way, my understanding, the mapping of modifiers between PC and Mac is
            • Shift on PC --> Shift
            • Ctrl on PC --> Command (i.e. the apple key)
            • Alt on PC --> Ctrl
            In edge selection, ALT is used for setting the 'all connected edges' mode
            1. as a toggle (press and release), to set/unset this mode as the current mode
            2. when clicking (keep pressed), to temporarily force the selection of all connected edges, regardless of the current mode
            Do you have a problem for 1) only, or for both usages?
            In any case, I am afraid that the keyboard is lacking modifier keys, on Mac (as for Windows too). So little hope for a solution, especially because I don't have a Mac to troubleshoot.
            • mvollrathM
              mvollrath
              Fredo, you are the best! Thank you for yet another incredible tool! I use RoundCorner daily and am very excited for the changes that come with FredoCorner!
              -Michael Vollrath
              • ArcA
                Arc
                This is full Chinese translation.
                FredoCorner_ZH.lang
                • fredo6F
                  Thank you very much. That's a big work.
                  As you may know, part of the translation of my plugins is located in LibFredo6, where I define some of the common basic strings. So if you have time, it would be nice to complete the Chinese translation of LibFredo6 (it is already largely translated).
                  Many thanks
                  • T
                    tiout
                    Bonjour Fredo.
                    Je crois que tu es français donc je me permet d'écrire en français...
                    Je viens de télécharger la version v1.1c et j'obtiens un trou a chaque sommet de cube.
                    Est-ce normal ?
                    ...et j'en profite pour te remercier pour tout ce travail et ces plugins qui sont devenus des outils usuels indispensables au quotidien.
                    Édit : finalement c’est bon après avoir remis les options par défaut...
                    • ArcA
                      Arc
                      Many thanks
                      Yes, I am working on it.
                      • OxerO
                        Oxer
                        ALT on PC --> CMD ⌘ on Mac
                        CTRL on PC --> ALT on Mac
                        If I use CMD instead of ALT, the 2) usage works fine.
                        CTRL+Left-click on Mac it's like a right-click, it appears the contextual menu, press and release CTRL key on the Mac does nothing.
                        I translated the last version on FredoCorner to Spanish language, here is the file:
                        FredoCorner_ES.lang.zip
                        • fredo6F
                          Woooh. I thought the equivalent of CTRL on PC was Command⌘ on Mac.
                          Then within FredoCorner, does the ⌘Z works as the shortcut for Undo (for instance an edge selection), or do you need to use ALT-Z?
                          • OxerO
                            Oxer
                            I talking about the use of keys modifiers on FredoCorner.
                            If I press ⌘Z or ALT-Z these modifiers don't work for Undo (for instance an edge selection), I can Undo the operations when I do click on curved arrow (left) of the palette.
                            macOS 10.13.6
                            SU2016
                            • fredo6F
                              NEW RELEASE: FredoCorner v1.1d - 19 Sep 18
                              FredoCorner 1.1d includes bug fixing, as well as a full translation in Spanish by Oxer and in Chinese (by Arc).
                              Requirement: LibFredo6 8.6e
                              Please note that:
                              • there are issues with some shortcut modifiers (Ctrl, Alt) on Mac)
                              • there are known issues and bugs here and there. This concerns in particular Collisions, i.e. when the offset is too large.
                              • fredo6F
                                Oxer,
                                You are right. Actually, this is the Sketchup API doing this mapping of CTRL on PC toward ALT on Mac. I always thought it was CTRL on PC toward ⌘ on Mac!!
                                I can indeed change the behavior.
                                I just open a thread to get the opinions of Mac users.
                                PS: by the way, in the native Push Pull tool, what is the modifier key on Mac to keep the original face?
                                • L
                                  laudhi
                                  I don't know this is a bug or not, but there is a difference between Fredo Corner and Round Corner when applied to simple box with holes.
                                  • OxerO
                                    Oxer
                                    It's the ALT key on Mac.
                                    • jiminy-billy-bobJ
                                      jiminy-billy-bob
                                      Does this help, Fredo ?
                                      https://www.sketchup.com/sites/www.sketchup.com/files/sketchup2018refcardmac.pdf
                                      • fredo6F
                                        Very useful. Thanks a lot.
                                        On Mac, it seems that Sketchup uses Alt as the equivalent of Ctrl on PC. Skeytchup also uses Command on Mac as a modifier (which appears to be the equivalent of Alt on PC).
                                        So I better stick to this convention and keep my plugins the way they work.
                                        Simply, I will change the tooltips and documentation, so that it is reflected.
                                        • E
                                          evapal
                                          Hi Fredo,
                                          You make fantastic plugins that allows to explore new design forms and I'd like to thank you for that. It's just I've downloaded your new FredoCorner as it is prefect to model a seat I am working on right now but it doesn't seem to work. I can see the toolbar but don't get the control board. I've got Mac and Sketchup 2017. I'd appreciate any word of advice :: 😢
                                          • fredo6F
                                            @evapal said:
                                            Hi Fredo,
                                            Could you elaborate a little bit more on your problem.
                                            Could you also open the Ruby console before you launch FredoCorner, to see if there are errors messages.
                                            Note that you need to upgrade LibFredo6 to its latest version (8.6g)
                                            • 22
                                            • 23
                                            • 4 / 23
