[Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
Here is a screenshot of the resulting text.
[attachment=0:14hqw0ge]<!-- ia0 -->Screen Shot 2018-09-12 at 1.31.36 PM.png<!-- ia0 -->[/attachment:14hqw0ge]
Looks good. I don't understand why Viewport doesn't open.
It should open in a Chrome browser?
Yes. To be exact: It should open in a Chromium browser.
I had "heard" of this, but this was the first time reading from beginning to end.
This is ambitious. Bravo. -
@samuel_t:
Bonjour, merci pour ce plugin, par contre depuis que je l'ai installĂ©, la fenĂȘtre Chromium s'ouvre Ă chaque dĂ©marrage de SketchUp, avec le dernier modĂšle chargĂ©, c'est un peu gĂȘnant. La camĂ©ra est assez limitĂ©e aussi, le zoom se bloque.
Petite question: est-ce que la caméra dans Chromium est gérée via une caméra 3js? Auquel cas ça serait assez simple je crois d'améliorer les choses. -
La caméra dans Chromium est gérée via une caméra A-Frame (framework qui s'appuie sur THREE.js).
Bizarre aucun problĂšme de ce genre!
Hi Samuel,
It's great to know and get this PBR extension.
I believe it is extremely useful for most modelers.
I'm very new to PBR and would like to explore more on it.
Please advise if this plugin is compatible and stable for Sketchup Pro 2019?
Any other plugin needed as supporting tools?
Thank you.Nizam Mahmud
Malaysia -
Yes. It is.
What's new in version 1.5.0 of PBR plugin?
- You can apply a height map to a material:
- You can change HDR background again.
- Material transparency is auto-detected.
Download latest PBR plugin from the SketchUcation PluginStore.
Hi Samuel, are you using parallax mapping technique for this height displacement?
Hi Filibis, yes.
What's new in version 1.5.1 of the PBR plugin?
- You can add artificial lights to model. Here how.
- Camera points by default to the front of model.
What's new in the version 1.5.2 of the PBR plugin?
- You can add artificial lights from Toolbar/Menu.
- You can adjust sunlight intensity in Viewport.
- Camera control in Viewport is similar to SU one.
What's new in the version 1.5.3 of the PBR plugin?
- Camera position in Viewport is automatically saved/restored.
- You can reset camera position in Viewport in one click on movie camera icon.
- "Propagate materials to whole model." is automatically done.
So we will win a click!
What's new in the version 1.5.4 of the PBR plugin?
- Textures not supported by glTF are supported by PBR plugin in SketchUp v2018 or greater.
- Fix bug: SketchUp model can't be saved (CFileException 0...) whereas PBR Viewport is open.
- PBR plugin checks automatically if a newer version is available @ http://www.sketchucation.com.
What's new in the version 1.5.5 of the PBR plugin?
- Ambient occlusion maps are supported. For now, they are incompatible with height maps.
- When you erase a PBR light: PBR Viewport reopens automatically. Also, PBR lights are named.
- Minor things were changed. E.g: SketchUp status bar changes when PBR Viewport (re)opens...
What's new in the version 1.5.6 of the PBR plugin?
There is an option in PBR Menu to track all changes done in SketchUp. When checked, PBR Viewport is automatically refreshed. Note that requires a powerful computer!
With your input, this post could be even better đ
Register LoginAdvertisement
