    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 102.0k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      @cadsifu said:
      Please advise if this plugin is compatible and stable for Sketchup Pro 2019?
      Yes. It is. πŸ‘
      • samuel_tS Offline
        samuel_t
        What's new in version 1.5.0 of PBR plugin?
        • You can apply a height map to a material:
          PBR Plugin Height Map Demo
        • You can change HDR background again.
        • Material transparency is auto-detected.
        Download latest PBR plugin from the SketchUcation PluginStore.
        • filibisF Offline
          filibis
          Hi Samuel, are you using parallax mapping technique for this height displacement?
          • samuel_tS Offline
            samuel_t
            Hi Filibis, yes.
            • samuel_tS Offline
              samuel_t
              What's new in version 1.5.1 of the PBR plugin?
              • You can add artificial lights to model. Here how.
              PBR Plugin Lights Demo A
              PBR Plugin Lights Demo B
              • Camera points by default to the front of model.
              • samuel_tS Offline
                samuel_t
                What's new in the version 1.5.2 of the PBR plugin?
                • You can add artificial lights from Toolbar/Menu.
                • You can adjust sunlight intensity in Viewport.
                • Camera control in Viewport is similar to SU one.
                • samuel_tS Offline
                  samuel_t
                  What's new in the version 1.5.3 of the PBR plugin?
                  • Camera position in Viewport is automatically saved/restored.
                  • You can reset camera position in Viewport in one click on movie camera icon.
                  • "Propagate materials to whole model." is automatically done.
                    So we will win a click! πŸ˜‰
                    • samuel_tS Offline
                      samuel_t
                      What's new in the version 1.5.4 of the PBR plugin?
                      • Textures not supported by glTF are supported by PBR plugin in SketchUp v2018 or greater.
                      • Fix bug: SketchUp model can't be saved (CFileException 0...) whereas PBR Viewport is open.
                      • PBR plugin checks automatically if a newer version is available @ http://www.sketchucation.com.
                      • samuel_tS Offline
                        samuel_t
                        What's new in the version 1.5.5 of the PBR plugin?
                        • Ambient occlusion maps are supported. For now, they are incompatible with height maps. πŸ˜•
                        • When you erase a PBR light: PBR Viewport reopens automatically. Also, PBR lights are named.
                        • Minor things were changed. E.g: SketchUp status bar changes when PBR Viewport (re)opens...
                        • samuel_tS Offline
                          samuel_t
                          What's new in the version 1.5.6 of the PBR plugin?
                          There is an option in PBR Menu to track all changes done in SketchUp. When checked, PBR Viewport is automatically refreshed. Note that requires a powerful computer!
                          • samuel_tS Offline
                            samuel_t
                            The version 1.5.7 of the PBR plugin:
                            • Exports sun light direction according to settings defined in Shadows panel.
                            • Fixes three little bugs about: ME tooltips, SU back faces & Viewport loader.
                            • samuel_tS Offline
                              samuel_t
                              The version 1.5.8 of the PBR plugin:
                              • Exports sun light intensity according to Light parameter defined in Shadows panel.
                              • Fixes a bug affecting some models: Viewport doesn't open and SketchUp freezes ❗
                              • samuel_tS Offline
                                samuel_t
                                The version 1.5.9 of the PBR plugin fixes URL of required plugin (glTF Exporter).
                                  DH2002
                                  First, Is this Plugin works for Mac OS SketchUp 2018 Pro?
                                  I managed to Install it and I have SimLab USDZ exporter Installed that works fine.
                                  After I install this Plugin SketchUp crashes, cant even save or load any object?
                                  I can draw a new mesh and even open this plugin, Load maps etc but when the try export files Aplication Crashes?
                                  My SketchUp the doesent work properly until I deinstall this Plugin.
                                  / Daniel
                                  • samuel_tS Offline
                                    samuel_t
                                    / Daniel
                                    First, sorry for this late reply:
                                    This plugin is compatible with SketchUp 2017-2021 for Windows and should be compatible with SketchUp 2017-2021 for macOS.
                                    If this plugin crashes when you export model as glTF file, you can try to in order:
                                    1. Open "Window > Ruby Console".
                                    2. Copy-paste below code:
                                    PBR;;GlTF.export
                                    1. Press enter to execute above code.
                                    2. Send me a screenshot.
                                    • samuel_tS Offline
                                      samuel_t
                                      The PBR 2.x plugin for SketchUp will support real-time ray tracing. Work in progress:
                                      • pabloariasP Offline
                                        pabloarias
                                        Hi. From a month, more or less, I got a popup when SU starts that said something about a newer version 4.2.6 from this plugin and opens this SketchUcation page when message accepted. But I see no news here about newer releases of this plugin. Does anybody here tell me what's wrong?
                                        Pablo Arias
                                        SketchUp trainer
                                        V-Ray licensed trainer
                                        • chonC Offline
                                          chon
                                          Hello,
                                          I think this message is about the last version of SketchUcation ExtensionStore πŸ˜‰
                                          • samuel_tS Offline
                                            samuel_t
                                            @chon said:
                                            Hello,
                                            Yes, it makes sense! πŸ˜„
                                            • 5 / 6
