    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 97.5k Views 14 Watching
    • P Offline
      peerman
      Ah thank you! I should've read the documentation better... 😳
      I will try it again.
      Best,
      iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
      • samuel_tS Offline
        samuel_t
        Best,
        No problem, Peter.
        Best regards,
        Samuel
        • samuel_tS Offline
          samuel_t
          v1.3.5 of PBR plugin has just been released. πŸ˜„
          • Enhance macOS support.
          • Upgrade Chromium browsers.
          • Update sunlight direction. Beta ❗
          • Add two materials to library.
          • Clarify menu and Viewport UI.
          • Fix camera's orbit control damping.
          • samuel_tS Offline
            samuel_t
            PBR plugin v1.3.6 includes a library of 73 materials!
            Most have been converted from texturehaven.com.
            All these materials contain at least one normal map.
            • samuel_tS Offline
              samuel_t
              The next PBR plugin version will include a virtual atmosphere (sun and stars). Demonstration:
              • samuel_tS Offline
                samuel_t
                PBR plugin v1.4.0 is out!
                What's new?
                • You can change sun elevation in Viewport. Sun and stars rise. πŸ˜„
                • You can save image in Viewport just by clicking on camera icon.
                • Hold mouse middle button to zoom more quickly in Viewport!
                • You can enter VR mode in Viewport β€” if you own a VR headset.
                • You can't change environment map from menu anymore. Sorry.
                • Material Library includes 79 materials! Thanks to Texture Haven.
                • samuel_tS Offline
                  samuel_t
                  PBR plugin v1.4.1 is out.
                  • Enhances Material Editor UX.
                  • Library includes 82 materials.
                  • chippwaltersC Offline
                    chippwalters
                    Great stuff! Just found out about this plugin. Look forward to trying it πŸ˜„
                    Currently working with Cross-Reality technologies
                    • samuel_tS Offline
                      samuel_t
                      Thank you! πŸ˜‰
                      • samuel_tS Offline
                        samuel_t
                        The latest PBR plugin version (downloadable here) includes a toolbar
                        and one more material.
                          πŸ‘
                          https://2img.net/h/s6.postimg.cc/9zsltvmlt/GIF_samu93.gif
                          • samuel_tS Offline
                            samuel_t
                            PBR plugin v1.4.3 :
                            • Checks required plugin.
                            • Externalizes material lib.
                            • samuel_tS Offline
                              samuel_t
                              I'm happy to announce that PBR plugin is now available through the SketchUcation PluginStore. πŸ˜„
                                πŸ‘
                                https://o.aolcdn.com/images/dims3/GLOB/legacy_thumbnail/630x315/format/jpg/quality/85/http%3A%2F%2Fi.huffpost.com%2Fgen%2F3708096%2Fimages%2Fn-CHAMPAGNE-628x314.jpg
                                https://s6.postimg.cc/c6p1c3ru9/mer_du_sud.jpg
                                • samuel_tS Offline
                                  samuel_t
                                  v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
                                  • samuel_tS Offline
                                    samuel_t
                                    Material Library of PBR plugin includes 100 materials --> Direct link to download it.
                                      macchu
                                      I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
                                      • samuel_tS Offline
                                        samuel_t
                                        PBR plugin requires this other plugin : glTF Exporter. Do you have installed it?
                                          macchu
                                          Yes, sorry I forgot to mention that, but the glTF exporter is also installed.
                                          • samuel_tS Offline
                                            samuel_t
                                            Please open a Ruby Console* and paste this code:
                                            PBR;;Viewport.reopen
                                            Then send me resulting text or a screen capture.
                                            (*) Window > Ruby Console
                                            • 6
                                            • 4 / 6
