    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 102.6k Views 14 Watching
      peerman
      So I played around with it a bit. A couple of things I noticed. The suns position doesn't get exported and the UVs aren't coming through correct.
      I've added a screenshot. The house is exploded (was a component) but that didn't help.
      It looks promising!
      Best,
      Peter
      iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
      • samuel_tS Offline
        samuel_t
        @peerman said:
        the UVs aren't coming through correct. [...]
        This is a known issue and there is a workaround. πŸ˜„
        Texture looks weird with perpendicular lines around.
        With your preferred photo editing software, resize texture image to a power of 2 in height and width (e.g. 1024x2048, 2048x2048, 4096x4096). Reimport texture image in SketchUp.
        Source: https://github.com/SamuelTS/SketchUp-PBR-Plugin/blob/master/docs/help.md#in-pbr-viewport
          peerman
          Ah thank you! I should've read the documentation better... 😳
          I will try it again.
          Best,
          • samuel_tS Offline
            samuel_t
            Best,
            No problem, Peter.
            Best regards,
            Samuel
            • samuel_tS Offline
              samuel_t
              v1.3.5 of PBR plugin has just been released. πŸ˜„
              • Enhance macOS support.
              • Upgrade Chromium browsers.
              • Update sunlight direction. Beta ❗
              • Add two materials to library.
              • Clarify menu and Viewport UI.
              • Fix camera's orbit control damping.
              • samuel_tS Offline
                samuel_t
                PBR plugin v1.3.6 includes a library of 73 materials!
                Most have been converted from texturehaven.com.
                All these materials contain at least one normal map.
                • samuel_tS Offline
                  samuel_t
                  The next PBR plugin version will include a virtual atmosphere (sun and stars). Demonstration:
                  • samuel_tS Offline
                    samuel_t
                    PBR plugin v1.4.0 is out!
                    What's new?
                    • You can change sun elevation in Viewport. Sun and stars rise. πŸ˜„
                    • You can save image in Viewport just by clicking on camera icon.
                    • Hold mouse middle button to zoom more quickly in Viewport!
                    • You can enter VR mode in Viewport β€” if you own a VR headset.
                    • You can't change environment map from menu anymore. Sorry.
                    • Material Library includes 79 materials! Thanks to Texture Haven.
                    • samuel_tS Offline
                      samuel_t
                      PBR plugin v1.4.1 is out.
                      • Enhances Material Editor UX.
                      • Library includes 82 materials.
                      • chippwaltersC Offline
                        chippwalters
                        Great stuff! Just found out about this plugin. Look forward to trying it πŸ˜„
                        Currently working with Cross-Reality technologies
                        • samuel_tS Offline
                          samuel_t
                          Thank you! πŸ˜‰
                          • samuel_tS Offline
                            samuel_t
                            The latest PBR plugin version (downloadable here) includes a toolbar
                            and one more material.
                              πŸ‘
                              https://2img.net/h/s6.postimg.cc/9zsltvmlt/GIF_samu93.gif
                              • samuel_tS Offline
                                samuel_t
                                PBR plugin v1.4.3 :
                                • Checks required plugin.
                                • Externalizes material lib.
                                • samuel_tS Offline
                                  samuel_t
                                  I'm happy to announce that PBR plugin is now available through the SketchUcation PluginStore. πŸ˜„
                                    πŸ‘
                                    https://o.aolcdn.com/images/dims3/GLOB/legacy_thumbnail/630x315/format/jpg/quality/85/http%3A%2F%2Fi.huffpost.com%2Fgen%2F3708096%2Fimages%2Fn-CHAMPAGNE-628x314.jpg
                                    https://s6.postimg.cc/c6p1c3ru9/mer_du_sud.jpg
                                    • samuel_tS Offline
                                      samuel_t
                                      v1.4.5 of PBR plugin fixes a light exposure issue in Viewport.
                                      • samuel_tS Offline
                                        samuel_t
                                        Material Library of PBR plugin includes 100 materials --> Direct link to download it.
                                          macchu
                                          I've downloaded the plugin and seems successfully installed but I'm unable to get a viewport to open. I've applied a PBR material and click on Reopen Viewport from the toolbar. I get a dialog box with "Propagate materials to whole model (Recommended)". Whether I select Yes or No, nothing happens. It's likely I'm not following the correct procedure?
                                          • samuel_tS Offline
                                            samuel_t
                                            PBR plugin requires this other plugin : glTF Exporter. Do you have installed it?
                                            • 4 / 6
