    POLL: Meters or Millimeters in your country?
    18 Posts 12 Posters 4.7k Views 12 Watching
    • E Offline
      Ecuadorian
      Thanks to fellow forum member TIG, I found out that not all architects in metric countries dimension their plans in meters: It turns out in the UK they do so in millimeters. In Ecuador it's the other way around: Architects dimension in meters and engineers do so in millimeters.
      How's the situation in your country?
      -Miguel Lescano
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        In France, I always saw centimeters in architecture offices.
        • TIGT Online
          I agree.
          Most of the EU [Ill advisedly] use cm for architecture - I'm not sure about engineers/surveyors. but I suspect m ?
          In the UK [and Ireland at least?] and probably some other locales [AU/NZ/SA ?] it's always mm for architects - avoiding decimal cm...
          So your survey options need to be expanded accordingly !?
          • PixeroP Offline
            Pixero
            In Sweden it's millimeter.
            Landscape architects often use meter.
            • jujuJ Offline
              juju
              South Africa, for architecture & engineering, it is mm, but land surveyor here often use m.
              • E Offline
                Ecuadorian
                Thanks everyone for your replies so far.
                So far, architects dimension their plans in:
                Meters:
                Ecuador, Mexico (and maybe the rest of Latin America).
                Centimeters:
                France (and maybe most of the EU)
                Milimeters:
                UK, Ireland, South Africa, Sweden (and maybe AU and NZ)
                Isn't there some kind of international standard for this? There should be, somewhere...
                -Miguel Lescano
                • Paul RussamP Offline
                  Paul Russam
                  I’m surprised about cm’s being used professionally, I’d always thought of them as being for children and civilians.
                  Cm’s are useful as they can be ‘seen’ and touched when in 3D form (I remember wooden coloured sticks when I was a kid we used to learn about lengths/volumes) but the idea of using them in a professional environment seems very odd.
                  Whenever I’ve had to oversee some 17 year old oink who thinks they’re the bees knees when it comes to designing I end up spending most of my time trying to get them to understand mm.
                  Paul Russam
                  English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                    jiminy-billy-bob
                    Why is it that odd? It's just a matter of convention after all.
                    Plus, I can see where it comes from : cm is pretty much the precision scale in architecture. You cannot build a building with a millimeter precision. The best you can do is around one cm.
                    • kimi kimiK Offline
                      kimi kimi
                      As long as I'm not using feet and inches everything is fine.
                        rodman100
                        Sit Surveyors always measure plots in m's and produce site drawings in m's in UK/Ireland as the Ordnance Survey National Grid reference system is in meters. However when architects get these drawings they often scale up the drawing by X1000 as they use mm's, thus destroying the integrity of the grid. This drawing is then sent on to the setting out engineer with a very odd Grid reference system!
                        • HieruH Offline
                          Hieru
                          I mostly work with UK architects. Supplied dwgs tend to be labelled in metres, but drawn in millimetres.
                          When discussing changes with architects they often switch between m, mm or cm - depending on which aspect of the design is being discussed.
                          I personally prefer to model in cm.
                          www.davidhier.co.uk
                          • E Offline
                            Ecuadorian
                            Hey, Hieru. That's something I've also seen...
                            Sometimes some people use AutoCAD units that don't match the units for dimension. For example, an engineer once sent me a plan where 1 AutoCAD unit = 1m, but it was dimensioned in mm. All other plans this engineer sent me were both drawn and dimensioned in mm. And yes, these inconsistencies can be a headache... Not with SketchUp files, but with AutoCAD files.
                            -Miguel Lescano
                            • HieruH Offline
                              Hieru
                              Yes, a real headache! I can count on one hand the number of architects I've worked with who produce faultless and consistent drawings.
                              www.davidhier.co.uk
                              • TIGT Online
                                In the UK...
                                Older people are imperial - feet/inches/lbs - many can also think in metric...
                                Younger people are metric - m/cm/kg - but many will still think in '/" for heights, miles for distances/speeds and stones/lbs for personal-weights
                                For almost 50 years the construction industry has used mm for all key setting out dimensions [architects/engineers] - unless very large dims - like master-planning when m is used.
                                For setting out m co-ords are usual - because of surveyor connections...
                                However, surveyors of both land and quantities always use metres.
                                Civil-engineers 'fall between two stools' ! Land in m and detailed structures in mm !!
                                'Commercial' surveyors like dual-units for areas - sq'/sqm and acres/hectares !
                                Because of longstanding imperial heritage things like domestic door-leaves are still made/available to standard imperial sizes - dual-labeled in mm and ".
                                • utilerU Offline
                                  utiler
                                  In Australia, mm for everything.
                                  Just Curious...
                                  • erikBE Offline
                                    erikB
                                    Belgium
                                    Architects : cm
                                    Engineers : mm
                                    Contractors : both
                                    it's complicated 😄
                                    erikB
                                      db11
                                      In Canada (officially metric, but stubbornly imperial in much of AEC industries), it's bloody complicated!:
                                      Architects: ft-in, or ft-in & mm
                                      Contractors: ft-in
                                      Engineers: mm
                                      Surveyors: m
                                      Interior Designers: ft-in
                                      Cabinet shops: mostly mm (32 mm Euro), old-school still use in
                                      Furniture makers: in
                                      • E Offline
                                        Ecuadorian
                                        Wow! Canada certainly takes the cake here in messed up combination of measurements!
                                        I just googled "32mm Euro"... Thanks for sharing that!
                                        -Miguel Lescano
