    POLL: Meters or Millimeters in your country?
    18 Posts 12 Posters 5.5k Views 12 Watching
    • jiminy-billy-bobJ
      jiminy-billy-bob
      In France, I always saw centimeters in architecture offices.
        I agree.
        Most of the EU [Ill advisedly] use cm for architecture - I'm not sure about engineers/surveyors. but I suspect m ?
        In the UK [and Ireland at least?] and probably some other locales [AU/NZ/SA ?] it's always mm for architects - avoiding decimal cm...
        So your survey options need to be expanded accordingly !?
        • PixeroP
          Pixero
          In Sweden it's millimeter.
          Landscape architects often use meter.
          • jujuJ
            juju
            South Africa, for architecture & engineering, it is mm, but land surveyor here often use m.
            • E
              Ecuadorian
              Thanks everyone for your replies so far.
              So far, architects dimension their plans in:
              Meters:
              Ecuador, Mexico (and maybe the rest of Latin America).
              Centimeters:
              France (and maybe most of the EU)
              Milimeters:
              UK, Ireland, South Africa, Sweden (and maybe AU and NZ)
              Isn't there some kind of international standard for this? There should be, somewhere...
              -Miguel Lescano
              • Paul RussamP
                Paul Russam
                I’m surprised about cm’s being used professionally, I’d always thought of them as being for children and civilians.
                Cm’s are useful as they can be ‘seen’ and touched when in 3D form (I remember wooden coloured sticks when I was a kid we used to learn about lengths/volumes) but the idea of using them in a professional environment seems very odd.
                Whenever I’ve had to oversee some 17 year old oink who thinks they’re the bees knees when it comes to designing I end up spending most of my time trying to get them to understand mm.
                Paul Russam
                English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
                • jiminy-billy-bobJ
                  jiminy-billy-bob
                  Why is it that odd? It's just a matter of convention after all.
                  Plus, I can see where it comes from : cm is pretty much the precision scale in architecture. You cannot build a building with a millimeter precision. The best you can do is around one cm.
                  • kimi kimiK
                    kimi kimi
                    As long as I'm not using feet and inches everything is fine.
                      rodman100
                      Sit Surveyors always measure plots in m's and produce site drawings in m's in UK/Ireland as the Ordnance Survey National Grid reference system is in meters. However when architects get these drawings they often scale up the drawing by X1000 as they use mm's, thus destroying the integrity of the grid. This drawing is then sent on to the setting out engineer with a very odd Grid reference system!
                      • HieruH
                        Hieru
                        I mostly work with UK architects. Supplied dwgs tend to be labelled in metres, but drawn in millimetres.
                        When discussing changes with architects they often switch between m, mm or cm - depending on which aspect of the design is being discussed.
                        I personally prefer to model in cm.
                        www.davidhier.co.uk
                        • E
                          Ecuadorian
                          Hey, Hieru. That's something I've also seen...
                          Sometimes some people use AutoCAD units that don't match the units for dimension. For example, an engineer once sent me a plan where 1 AutoCAD unit = 1m, but it was dimensioned in mm. All other plans this engineer sent me were both drawn and dimensioned in mm. And yes, these inconsistencies can be a headache... Not with SketchUp files, but with AutoCAD files.
                          -Miguel Lescano
                          • HieruH
                            Hieru
                            Yes, a real headache! I can count on one hand the number of architects I've worked with who produce faultless and consistent drawings.
                            www.davidhier.co.uk
                              In the UK...
                              Older people are imperial - feet/inches/lbs - many can also think in metric...
                              Younger people are metric - m/cm/kg - but many will still think in '/" for heights, miles for distances/speeds and stones/lbs for personal-weights
                              For almost 50 years the construction industry has used mm for all key setting out dimensions [architects/engineers] - unless very large dims - like master-planning when m is used.
                              For setting out m co-ords are usual - because of surveyor connections...
                              However, surveyors of both land and quantities always use metres.
                              Civil-engineers 'fall between two stools' ! Land in m and detailed structures in mm !!
                              'Commercial' surveyors like dual-units for areas - sq'/sqm and acres/hectares !
                              Because of longstanding imperial heritage things like domestic door-leaves are still made/available to standard imperial sizes - dual-labeled in mm and ".
                              • utilerU
                                utiler
                                In Australia, mm for everything.
                                Just Curious...
                                • erikBE
                                  erikB
                                  Belgium
                                  Architects : cm
                                  Engineers : mm
                                  Contractors : both
                                  it's complicated 😄
                                  erikB
                                    db11
                                    In Canada (officially metric, but stubbornly imperial in much of AEC industries), it's bloody complicated!:
                                    Architects: ft-in, or ft-in & mm
                                    Contractors: ft-in
                                    Engineers: mm
                                    Surveyors: m
                                    Interior Designers: ft-in
                                    Cabinet shops: mostly mm (32 mm Euro), old-school still use in
                                    Furniture makers: in
                                    • E
                                      Ecuadorian
                                      Wow! Canada certainly takes the cake here in messed up combination of measurements!
                                      I just googled "32mm Euro"... Thanks for sharing that!
                                      -Miguel Lescano
