    Smooth not working
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    6 Posts 5 Posters 10.0k Views 5 Watching
      Subd1.pngHi all, I just installed SubD 2.1.1 in 2017. As the image shows I can get it to subdivide but not smooth. Can somebody please suggest what I am doing wrong?
      Cheers
      • HornOxxH Offline
        HornOxx
        Hi - I can't see the pictures πŸ˜‰
        never trust a skinny cook
          Subd2.pngOK I just tried a cube and it worked, but it wont work with this shape.
          It does everything just not that particular model/group. So its just academic now.
          SubD is the best fun I have had in sketchup in just about forever πŸ‘
          • cottyC Offline
            cotty
            Did you change the crease value for the edges e.g.?
            my SketchUp gallery
            • panixiaP Offline
              panixia
              You may check if the "mesh smoothing" in sub-d entity info is toggled off.
              In that case, you get your subdivisions, but no smoothing happening, see the example below.
                Hi L i am, did any of the responses solve your issue?
                If not, can you share the model?
