    Assign shortcut not working
    7 Posts 5 Posters 658 Views 5 Watching
    • brooklynia373B Offline
      brooklynia373
      what am i doing wrong?
      i want to reassign CTRL +P.
      I remove its default assignment as PRINT
      I assign Edit>Pasteinplace as CTRL +P
      okay
      save the file
      it works when i reopen that specific file but not new ones.
      • HornOxxH Offline
        HornOxx
        What about when you export your entire bunch of custom shortcuts of this current file to something like "my own Preferences.dat" and then open a new file, load this "my own Preferences.dat" and save all this as your new template again? does this work for you then?
        never trust a skinny cook
          Ctrl+P is a hard coded shortcut. It is coded in Windows, not SketchUp. The operating system will override all hard coded shortcuts. You cannot permanently reassign them to SketchUp functions. Pick another shortcut.
          • HornOxxH Offline
            HornOxx
            @dave r said:
            Ctrl+P is a hard coded shortcut. It is coded in Windows, not SketchUp...
            Thank you Dave for pointing on that ❗ ❗ 😳
              F1 is another similar hard coded key.
              Another tip is to not use numpad keys as shortcuts unless they at use a modifier like CTRL/SHIFT/ALT.
              You need those for VCB input.
                slbaumgartner
                On the Mac, it is command-key chords that are pre-assigned by the GUI and can't be used as SketchUp shortcuts.
                  brooklynia373
                  k. thanks
