    Sun/shadow study animation export -> time????
    40 Posts 28 Posters 25.9k Views 28 Watching
      bsfranza
      hi there,
      i really love the geolocation feature of sketchup and the possibility to make short animations with scenes that show the daylight cycles etc.. also one can export animations
      now, is it possible to have some kind of clock or timer in the animation that shows the actual time???
      if not inside sketchup how would you go to add that to the finished animation?
      thanks for your help
        There was a plugin made some years ago that would display the time and date on screen. I used it in a shadow study animation I did for a client back then. I'll have to hunt for it because I don't remember where I got it or the name of it.
          juju
          If I recall correctly this is "time" available from Smustard.
            bsfranza
            thanks guys, unfortunately i cant find anything over at smustard but a animated clock but this does not help.. i dont need the actual time but the time of the animation... that is day and daytime of sun...
            πŸ˜•
            hope anyone else has a tipp availeable
              Time would do what you want.
              Unfortunately it's no longer available.
              I will PM you an alternative 'private' script...
                bsfranza
                thanks tig - awesome script!!
                awesome forum πŸ˜ƒ
                • N Offline
                  nohatman
                  Is this something that is available now as part of SketchUp? Or otherwise...
                  I have a need for the same to produce a shadow study. It would be great to have something accurate within SketchUp and actually linked to SU's shadow times - rather than adding a timer in After Effects which is what I have done, but this is a very cumbersome solution.
                    I'll PM you some alternative Ruby code...
                      bewilder
                      I have been looking everywhere for an extension that would show the shadow time in an animation. I hate bugging TIG for a PM with private code. Is it available anywhere else?
                        juju
                        What do you mean by shadow time?
                        • The amount of sun / shadow an area would receive?
                          or
                        • The date & time on screen when viewing an area with sun/shadows enabled?
                          Look in your PMs...
                            bewilder
                            That is perfect! Thank you for taking the time.
                              Triangle_head
                              Hello! Can You send a code for me too?
                                See yesterday's PM...
                                • X Offline
                                  xeroball
                                  Hello, Can You send a code for me also?
                                    luesak
                                    TIG, could you please share your time script? I am new here so I cannot send PMs!
                                    Kim
                                      Will you all check your PMs for an attachment...
                                        luesak
                                        Thank you TIG!
                                          TacSU
                                          Tig,
                                          Do you still have this alternate code, or in the last few years are you aware of a newer method?
                                            Look at your PMs...
                                            • 1 / 2
