    Sun/shadow study animation export -> time????
    40 Posts 28 Posters 26.1k Views 28 Watching
    • jujuJ Offline
      juju
      @dave r said:
      There was a plugin made some years ago that would display the time and date on screen. I used it in a shadow study animation I did for a client back then. I'll have to hunt for it because I don't remember where I got it or the name of it.
      If I recall correctly this is "time" available from Smustard.
        bsfranza
        thanks guys, unfortunately i cant find anything over at smustard but a animated clock but this does not help.. i dont need the actual time but the time of the animation... that is day and daytime of sun...
        πŸ˜•
        hope anyone else has a tipp availeable
          Time would do what you want.
          Unfortunately it's no longer available.
          I will PM you an alternative 'private' script...
            bsfranza
            thanks tig - awesome script!!
            awesome forum πŸ˜ƒ
            • N Offline
              nohatman
              Is this something that is available now as part of SketchUp? Or otherwise...
              I have a need for the same to produce a shadow study. It would be great to have something accurate within SketchUp and actually linked to SU's shadow times - rather than adding a timer in After Effects which is what I have done, but this is a very cumbersome solution.
                I'll PM you some alternative Ruby code...
                  bewilder
                  I have been looking everywhere for an extension that would show the shadow time in an animation. I hate bugging TIG for a PM with private code. Is it available anywhere else?
                  • jujuJ Offline
                    juju
                    What do you mean by shadow time?
                    • The amount of sun / shadow an area would receive?
                      or
                    • The date & time on screen when viewing an area with sun/shadows enabled?
                      Look in your PMs...
                        bewilder
                        That is perfect! Thank you for taking the time.
                          Triangle_head
                          Hello! Can You send a code for me too?
                            See yesterday's PM...
                            • X Offline
                              xeroball
                              Hello, Can You send a code for me also?
                                luesak
                                TIG, could you please share your time script? I am new here so I cannot send PMs!
                                Kim
                                  Will you all check your PMs for an attachment...
                                    luesak
                                    Thank you TIG!
                                      TacSU
                                      Tig,
                                      Do you still have this alternate code, or in the last few years are you aware of a newer method?
                                        Look at your PMs...
                                        • V Offline
                                          vandyck
                                          @tig said:
                                          Look in your PMs...
                                          Hello TIG !
                                          thank you in advance
                                          • V Offline
                                            virtexultra
                                            Hello TIG
                                            would you be so kind and would also send me the script?
                                            Alexander
