    Sun/shadow study animation export -> time????
    40 Posts 28 Posters 27.2k Views 28 Watching
      Time would do what you want.
      Unfortunately it's no longer available.
      I will PM you an alternative 'private' script...
      • B
        bsfranza
        thanks tig - awesome script!!
        awesome forum πŸ˜ƒ
        • N
          nohatman
          Is this something that is available now as part of SketchUp? Or otherwise...
          I have a need for the same to produce a shadow study. It would be great to have something accurate within SketchUp and actually linked to SU's shadow times - rather than adding a timer in After Effects which is what I have done, but this is a very cumbersome solution.
            I'll PM you some alternative Ruby code...
            • B
              bewilder
              I have been looking everywhere for an extension that would show the shadow time in an animation. I hate bugging TIG for a PM with private code. Is it available anywhere else?
              • jujuJ
                juju
                What do you mean by shadow time?
                • The amount of sun / shadow an area would receive?
                  or
                • The date & time on screen when viewing an area with sun/shadows enabled?
                  Look in your PMs...
                  • B
                    bewilder
                    That is perfect! Thank you for taking the time.
                    • T
                      Triangle_head
                      Hello! Can You send a code for me too?
                        See yesterday's PM...
                        • X
                          xeroball
                          Hello, Can You send a code for me also?
                          • L
                            luesak
                            TIG, could you please share your time script? I am new here so I cannot send PMs!
                            Kim
                              Will you all check your PMs for an attachment...
                              • L
                                luesak
                                Thank you TIG!
                                • T
                                  TacSU
                                  Tig,
                                  Do you still have this alternate code, or in the last few years are you aware of a newer method?
                                    Look at your PMs...
                                    • V
                                      vandyck
                                      @tig said:
                                      Look in your PMs...
                                      Hello TIG !
                                      thank you in advance
                                      • V
                                        virtexultra
                                        Hello TIG
                                        would you be so kind and would also send me the script?
                                        Alexander
                                          mateua
                                          TIG !
                                          Could You share a code with me too?
                                          thank you
                                          Mateusz
                                          • F
                                            frankthetank86
                                            Hello TIG,
                                            you are my last hope to get my problem done. I need to have a time stamp on my exported video that shows day and time of the current shadow. I tried some ruby code but that does not work on exported animated videos.
                                            Thank you very much in advance!
                                            Frankthetank86
