    Sun/shadow study animation export -> time????
    40 Posts 28 Posters 27.0k Views 28 Watching
    • N
      nohatman
      @tig said:
      Time would do what you want.
      Unfortunately it's no longer available.
      I will PM you an alternative 'private' script...
      Is this something that is available now as part of SketchUp? Or otherwise...
      I have a need for the same to produce a shadow study. It would be great to have something accurate within SketchUp and actually linked to SU's shadow times - rather than adding a timer in After Effects which is what I have done, but this is a very cumbersome solution.
        I'll PM you some alternative Ruby code...
        • B
          bewilder
          I have been looking everywhere for an extension that would show the shadow time in an animation. I hate bugging TIG for a PM with private code. Is it available anywhere else?
          • jujuJ
            juju
            What do you mean by shadow time?
            • The amount of sun / shadow an area would receive?
              or
            • The date & time on screen when viewing an area with sun/shadows enabled?
              Look in your PMs...
              • B
                bewilder
                That is perfect! Thank you for taking the time.
                • T
                  Triangle_head
                  Hello! Can You send a code for me too?
                    See yesterday's PM...
                    • X
                      xeroball
                      Hello, Can You send a code for me also?
                      • L
                        luesak
                        TIG, could you please share your time script? I am new here so I cannot send PMs!
                        Kim
                          Will you all check your PMs for an attachment...
                          • L
                            luesak
                            Thank you TIG!
                            • T
                              TacSU
                              Tig,
                              Do you still have this alternate code, or in the last few years are you aware of a newer method?
                                Look at your PMs...
                                • V
                                  vandyck
                                  @tig said:
                                  Look in your PMs...
                                  Hello TIG !
                                  thank you in advance
                                  • V
                                    virtexultra
                                    Hello TIG
                                    would you be so kind and would also send me the script?
                                    Alexander
                                      mateua
                                      TIG !
                                      Could You share a code with me too?
                                      thank you
                                      Mateusz
                                      • F
                                        frankthetank86
                                        Hello TIG,
                                        you are my last hope to get my problem done. I need to have a time stamp on my exported video that shows day and time of the current shadow. I tried some ruby code but that does not work on exported animated videos.
                                        Thank you very much in advance!
                                        Frankthetank86
                                          jaythakkar
                                          Hello TIG
                                          Can you please share the code.
                                            Miramonte
                                            Hi TIG !
                                            thank you
