    [REQ] Plugin "open file"
    23 Posts 8 Posters 2.5k Views 8 Watching
    • BepB Offline
      Bep
      I have a request for a plugin that ads a menu button, and that after you click that button it would open a specific file.
      It does not have to be a fancy Plugin.
      I could modify my own button icon, and change the filepath in the ruby script to the file i need to open.
      (maybe it allready exists ,but i just could not find it)
      Greetings,
      Bep van Malde
      "History is written by the winners"
      • BoxB Offline
        Are you looking for something like this?
        http://sketchucation.com/pluginstore?pln=RND_GOSU
        • BepB Offline
          Bep
          Almost, except the script should create a toolbar button to launch the file.
          • sdmitchS Offline
            sdmitch
            tb = UI;;Toolbar.new("Toolbar Name")
            cmd = UI;;Command.new("Plugin Name") { Sketchup.open_file "c;/users/public/sketchup/models/dummy.skp" }
            cmd.tooltip = "Plugin Name"
            cmd.status_bar_text = "Plugin Name"
            cmd.large_icon = File.join(File.dirname(__FILE__), "/Large Icon.png")
            cmd.small_icon = File.join(File.dirname(__FILE__), "/Small Icon.png")
            tb.add_item(cmd)
            tb.show unless tb.get_last_state == 0
            http://sdmitch.blogspot.com/
            • BepB Offline
              Bep
              > tb.add_item(cmd)
              Thank you Sam for your effort.
              But your script only lets me open Sketchup files.
              I would like to be able to open any kind of file like .ods or .xls or .pdf
              Could yo please change the script to do so.
              Bep
              • fredo6F Offline
                fredo6
                That's an interesting idea of plugin, actually relatively straightforward to do. It is just requesting some GUI to configure the list of files.
                I guess some authors would do it. Otherwise, I can put it on my list.
                Fredo
                • sdmitchS Offline
                  sdmitch
                  Bep
                  This is what you asked for!
                  A "specific file"!
                  • BepB Offline
                    Bep
                    @sdmitch said:
                    Bep
                    A "specific file"!
                    I apologize Sam that i put you on the wrong foot, by not being clear at the first time about what i meant with "a specific file".
                    Bep
                    • BepB Offline
                      Bep
                      Fredo
                      Thank you Fredo for being interested in writing the script.
                      In the meantime i will be waiting patiently, until one of the Ruby wizards comes up with a script.
                      Bep
                      • fredo6F Offline
                        fredo6
                        Bep,
                        Actually, the main difficulty is to decide on the icons displayed in the toolbar.
                        It could be just:
                        • colors
                        • Letters, like A, B, C, .... or numbers
                        • thumbnail of files (more difficult, and not differentiating since rather based on file type)
                        • a set of predefined icons
                        In any case, someone has to design these icons.
                        Fredo
                        • BepB Offline
                          Bep
                          @fredo6 said:
                          Bep,
                          It could be just:
                          • colors
                          Fredo
                          Fredo, i understand and foresaw the difficulty about the icons your explaining.
                          That is why i asked for a not to fancy script in the first place.
                          Sam's script almost worked for me, if only it was not limited to Sketchup files.
                          "I could modify my own button icon, and change the filepath in the ruby script to the file i need to open."
                          If i needed another tool button to launch another file, i would just copy and rename the ruby script, and put other icons and an other filepath in it.
                          I could than if i wanted the tool buttons in one toolbar, make a custom toolbar with these buttons placed together in it.
                          Bep
                          • G Offline
                            glro
                            @bep said:
                            @fredo6 said:
                            Bep,
                            It could be just:
                            • colors
                            Fredo
                            Bep
                            UI.openURL ("") is the code to open any file
                            this is an example that shows an image on my screen at ""C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\logo.jpg""
                            just change to the file you need to open
                            you can change that too
                            tb = UI::Toolbar.new("Toolbar Name")
                            cmd = UI::Command.new("Plugin Name") { Sketchup.open_file UI.openURL("C:\\Users\\glro\\AppData\\Roaming\\SketchUp\\SketchUp 2016\\SketchUp\\Plugins\\MTX\\logo.jpg") }
                            cmd.large_icon = File.join(File.dirname(__FILE__), "MCT_LRO.png")
                            cmd.small_icon = File.join(File.dirname(FILE), "MCT_LRO.png")
                            tb.add_item(cmd)
                            • G Offline
                              glro
                              this is a better version, based on TIG's code in the plugin MIRROR to add a button:
                              replace
                              C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf
                              by the path to your file
                              replace the name of module and definition also, and the name of the png file
                              ` require "sketchup"
                              module MTX
                              def MTX.notice
                              UI.openURL("C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf")
                              unless file_loaded?(File.basename(FILE))###
                              UI.menu("Plugins").add_item("MTX_Notice Metrix"){MTX.notice}
                              Context menu
                              #=begin
                              UI.add_context_menu_handler do |menu|### v3.5 TIG
                              if Sketchup.active_model.selection[0]
                                  #menu.add_separator
                                  menu.add_item("Notice Metrix"){Sketchup.active_model.select_tool(MTX.notice)}
                              end#if
                              end#do menu###
                              #=end
                              Toolbar - only adds the toolbar IF there's an icon png with it ###v3.2
                              png=File.join(File.dirname(FILE),"MTX_notice_Metrix.png")
                              if FileTest.exist?(png)
                              tb=UI::Toolbar.new("Notice Metrix")
                              cmd=UI::Command.new("MI"){Sketchup.active_model.select_tool(MTX.notice)}
                              cmd.large_icon=png
                              cmd.small_icon=png
                              cmd.tooltip="Notice Metrix"
                              cmd.status_bar_text="Notice Metrix: afficher..."
                              tb.add_item(cmd)
                              if tb.get_last_state==TB_NEVER_SHOWN
                              tb.show
                              elsif tb.get_last_state==TB_VISIBLE
                              tb.restore
                              end#if state
                              end#if toolbar
                              end#if loaded
                              file_loaded(File.basename(FILE))`
                                rv1974
                                Rather bizarre request..
                                Why one won't just put any desired desktop shortcut instead?
                                • G Offline
                                  glro
                                  maybe because when sketchup fills your screen entirely, you have to close or reduce the sketchup window to access the shortcut
                                  if the shortcup is inside the sketchup window, you can access it directly
                                  each clic matters...
                                  • BepB Offline
                                    Bep
                                    @glro said:
                                    @bep said:
                                    @fredo6 said:
                                    Bep,
                                    It could be just:
                                    • colors
                                    Fredo
                                    Bep
                                    tb.add_item(cmd)
                                    Thank you very much Glro,
                                    I got the script opening a file just as i requested.
                                    However the file will pup up in front of the Sketchup-window, and than in a split second hides behind it.
                                    I have to click the file icon on the taskbar or reach for the file-window behind the Sketchup-window, to click it, and to get it in front of the Sketchup-window again.
                                    I hope i can figure out how the fix this last bit.
                                    Bep
                                    • BepB Offline
                                      Bep
                                      Hello rv1974,
                                      do not judge too quickly.
                                      In my case its not that bizarre.
                                      The tool-button will be part of a toolbar that is used in a repetitive process.
                                      One part of the process is opening office file's to copy and paste from and to.
                                      All parts of the process are in one toolbar, in the correct sequence from left to right.
                                      Setting up these machines with all the right files and ruby's in one .rbz is the goal for meantime.
                                      The ultimate goal however is to try to automate the whole process.(taking small steps)
                                      Bep
                                        Some years ago I modified a little script file so it would open the calculator program in windows. It could be modified to open any program I expect. And looking at the thread, I suppose you could add a toolbar although I would prefer a keyboard shortcut.
                                        • BepB Offline
                                          Bep
                                          Dave, i remember your calc.rb
                                          imho keyboard shortcuts would be less efficient, be course i would have to install them on every machine next to Sketchup and all the necessary ruby's.
                                          Than i would have put sticky notes on every PC-machine with the keybord -shortcuts and instruct all persons working with these machine's.
                                          The way i see it, Sketchup with this toolbar could work as a sort off switchboard to all the necessary files and programs.
                                          Bep
                                            Didn't Sahi have a plugin to open a folder/file location?
                                            • 1 / 2
