    [REQ] Plugin "open file"
    23 Posts 8 Posters 2.7k Views 8 Watching
    • sdmitchS Offline
      sdmitch
      @bep said:
      @box said:
      Are you looking for something like this?
      http://sketchucation.com/pluginstore?pln=RND_GOSU
      Almost, except the script should create a toolbar button to launch the file.
      tb = UI;;Toolbar.new("Toolbar Name")
      cmd = UI;;Command.new("Plugin Name") { Sketchup.open_file "c;/users/public/sketchup/models/dummy.skp" }
      cmd.tooltip = "Plugin Name"
      cmd.status_bar_text = "Plugin Name"
      cmd.large_icon = File.join(File.dirname(__FILE__), "/Large Icon.png")
      cmd.small_icon = File.join(File.dirname(__FILE__), "/Small Icon.png")
      tb.add_item(cmd)
      tb.show unless tb.get_last_state == 0
      http://sdmitch.blogspot.com/
      • BepB Offline
        Bep
        > tb.add_item(cmd)
        Thank you Sam for your effort.
        But your script only lets me open Sketchup files.
        I would like to be able to open any kind of file like .ods or .xls or .pdf
        Could yo please change the script to do so.
        Bep
        "History is written by the winners"
        • fredo6F Offline
          That's an interesting idea of plugin, actually relatively straightforward to do. It is just requesting some GUI to configure the list of files.
          I guess some authors would do it. Otherwise, I can put it on my list.
          • sdmitchS Offline
            sdmitch
            @bep said:
            I have a request for a plugin that ads a menu button, and that after you click that button it would open a specific file.
            Bep
            This is what you asked for!
            A "specific file"!
            • BepB Offline
              Bep
              @sdmitch said:
              Bep
              A "specific file"!
              I apologize Sam that i put you on the wrong foot, by not being clear at the first time about what i meant with "a specific file".
              Bep
              • BepB Offline
                Bep
                Thank you Fredo for being interested in writing the script.
                In the meantime i will be waiting patiently, until one of the Ruby wizards comes up with a script.
                Bep
                • fredo6F Offline
                  Bep,
                  Actually, the main difficulty is to decide on the icons displayed in the toolbar.
                  It could be just:
                  • colors
                  • Letters, like A, B, C, .... or numbers
                  • thumbnail of files (more difficult, and not differentiating since rather based on file type)
                  • a set of predefined icons
                  In any case, someone has to design these icons.
                  • BepB Offline
                    Bep
                    @fredo6 said:
                    Bep,
                    It could be just:
                    • colors
                    Fredo, i understand and foresaw the difficulty about the icons your explaining.
                    That is why i asked for a not to fancy script in the first place.
                    Sam's script almost worked for me, if only it was not limited to Sketchup files.
                    "I could modify my own button icon, and change the filepath in the ruby script to the file i need to open."
                    If i needed another tool button to launch another file, i would just copy and rename the ruby script, and put other icons and an other filepath in it.
                    I could than if i wanted the tool buttons in one toolbar, make a custom toolbar with these buttons placed together in it.
                    Bep
                      glro
                      @bep said:
                      @fredo6 said:
                      Bep,
                      It could be just:
                      • colors
                      Bep
                      UI.openURL ("") is the code to open any file
                      this is an example that shows an image on my screen at ""C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\logo.jpg""
                      just change to the file you need to open
                      you can change that too
                      tb = UI::Toolbar.new("Toolbar Name")
                      cmd = UI::Command.new("Plugin Name") { Sketchup.open_file UI.openURL("C:\\Users\\glro\\AppData\\Roaming\\SketchUp\\SketchUp 2016\\SketchUp\\Plugins\\MTX\\logo.jpg") }
                      cmd.large_icon = File.join(File.dirname(__FILE__), "MCT_LRO.png")
                      cmd.small_icon = File.join(File.dirname(FILE), "MCT_LRO.png")
                      tb.add_item(cmd)
                        glro
                        this is a better version, based on TIG's code in the plugin MIRROR to add a button:
                        replace
                        C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf
                        by the path to your file
                        replace the name of module and definition also, and the name of the png file
                        ` require "sketchup"
                        module MTX
                        def MTX.notice
                        UI.openURL("C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf")
                        unless file_loaded?(File.basename(FILE))###
                        UI.menu("Plugins").add_item("MTX_Notice Metrix"){MTX.notice}
                        Context menu
                        #=begin
                        UI.add_context_menu_handler do |menu|### v3.5 TIG
                        if Sketchup.active_model.selection[0]
                            #menu.add_separator
                            menu.add_item("Notice Metrix"){Sketchup.active_model.select_tool(MTX.notice)}
                        end#if
                        end#do menu###
                        #=end
                        Toolbar - only adds the toolbar IF there's an icon png with it ###v3.2
                        png=File.join(File.dirname(FILE),"MTX_notice_Metrix.png")
                        if FileTest.exist?(png)
                        tb=UI::Toolbar.new("Notice Metrix")
                        cmd=UI::Command.new("MI"){Sketchup.active_model.select_tool(MTX.notice)}
                        cmd.large_icon=png
                        cmd.small_icon=png
                        cmd.tooltip="Notice Metrix"
                        cmd.status_bar_text="Notice Metrix: afficher..."
                        tb.add_item(cmd)
                        if tb.get_last_state==TB_NEVER_SHOWN
                        tb.show
                        elsif tb.get_last_state==TB_VISIBLE
                        tb.restore
                        end#if state
                        end#if toolbar
                        end#if loaded
                        file_loaded(File.basename(FILE))`
                          rv1974
                          Rather bizarre request..
                          Why one won't just put any desired desktop shortcut instead?
                            glro
                            maybe because when sketchup fills your screen entirely, you have to close or reduce the sketchup window to access the shortcut
                            if the shortcup is inside the sketchup window, you can access it directly
                            each clic matters...
                            • BepB Offline
                              Bep
                              @glro said:
                              @bep said:
                              @fredo6 said:
                              Bep,
                              It could be just:
                              • colors
                              Bep
                              tb.add_item(cmd)
                              Thank you very much Glro,
                              I got the script opening a file just as i requested.
                              However the file will pup up in front of the Sketchup-window, and than in a split second hides behind it.
                              I have to click the file icon on the taskbar or reach for the file-window behind the Sketchup-window, to click it, and to get it in front of the Sketchup-window again.
                              I hope i can figure out how the fix this last bit.
                              Bep
                              • BepB Offline
                                Bep
                                Hello rv1974,
                                do not judge too quickly.
                                In my case its not that bizarre.
                                The tool-button will be part of a toolbar that is used in a repetitive process.
                                One part of the process is opening office file's to copy and paste from and to.
                                All parts of the process are in one toolbar, in the correct sequence from left to right.
                                Setting up these machines with all the right files and ruby's in one .rbz is the goal for meantime.
                                The ultimate goal however is to try to automate the whole process.(taking small steps)
                                Bep
                                  Some years ago I modified a little script file so it would open the calculator program in windows. It could be modified to open any program I expect. And looking at the thread, I suppose you could add a toolbar although I would prefer a keyboard shortcut.
                                  • BepB Offline
                                    Bep
                                    Dave, i remember your calc.rb
                                    imho keyboard shortcuts would be less efficient, be course i would have to install them on every machine next to Sketchup and all the necessary ruby's.
                                    Than i would have put sticky notes on every PC-machine with the keybord -shortcuts and instruct all persons working with these machine's.
                                    The way i see it, Sketchup with this toolbar could work as a sort off switchboard to all the necessary files and programs.
                                    Bep
                                      Didn't Sahi have a plugin to open a folder/file location?
                                        glro
                                        Bep
                                        on my computer, the opened file stays on top on the sketchup window
                                          glro
                                          Just ONE Win+D (Alt+Tab if it's open) hit! And thisrequires a dedicated plugin??
                                          And to pin a File or Folder to the Windows 7 Taskbar won't ease solve your problem either?
                                          the "dedicated plugin" is such an easy one..no big deal
                                          and from what i understand, it is the beginning of something else
                                          i just tried to help
                                            rv1974
                                            And to pin a File or Folder to the Windows 7 Taskbar won't solve your problem either?
