    [REQ] Plugin "open file"
    23 Posts 8 Posters 2.5k Views 8 Watching
    • G Offline
      glro
      @bep said:
      I got the script opening a file just as i requested.
      However the file will pup up in front of the Sketchup-window, and than in a split second hides behind it.
      I have to click the file icon on the taskbar or reach for the file-window behind the Sketchup-window, to click it, and to get it in front of the Sketchup-window again.
      I hope i can figure out how the fix this last bit.
      Bep
      on my computer, the opened file stays on top on the sketchup window
      • G Offline
        glro
        @rv1974 said:
        @glro said:
        @rv1974 said:
        Rather bizarre request..
        Why one won't just put any desired desktop shortcut instead?
        maybe because when sketchup fills your screen entirely, you have to close or reduce the sketchup window to access the shortcut
        if the shortcup is inside the sketchup window, you can access it directly
        each clic matters...
        Just ONE Win+D (Alt+Tab if it's open) hit! And thisrequires a dedicated plugin??
        And to pin a File or Folder to the Windows 7 Taskbar won't ease solve your problem either?
        the "dedicated plugin" is such an easy one..no big deal
        and from what i understand, it is the beginning of something else
        i just tried to help
        • R Do not disturb
          rv1974
          And to pin a File or Folder to the Windows 7 Taskbar won't solve your problem either?
          • 2 / 2
