    [REQ] Plugin "open file"
    23 Posts 8 Posters 3.0k Views 8 Watching
    • sdmitchS Offline
      sdmitch
      @bep said:
      I have a request for a plugin that ads a menu button, and that after you click that button it would open a specific file.
      Bep
      This is what you asked for!
      A "specific file"!
      http://sdmitch.blogspot.com/
      • BepB Offline
        Bep
        @sdmitch said:
        Bep
        A "specific file"!
        I apologize Sam that i put you on the wrong foot, by not being clear at the first time about what i meant with "a specific file".
        Bep
        "History is written by the winners"
        • BepB Offline
          Bep
          @fredo6 said:
          That's an interesting idea of plugin, actually relatively straightforward to do. It is just requesting some GUI to configure the list of files.
          I guess some authors would do it. Otherwise, I can put it on my list.
          Thank you Fredo for being interested in writing the script.
          In the meantime i will be waiting patiently, until one of the Ruby wizards comes up with a script.
          Bep
          • fredo6F Offline
            Bep,
            Actually, the main difficulty is to decide on the icons displayed in the toolbar.
            It could be just:
            • colors
            • Letters, like A, B, C, .... or numbers
            • thumbnail of files (more difficult, and not differentiating since rather based on file type)
            • a set of predefined icons
            In any case, someone has to design these icons.
            • BepB Offline
              Bep
              @fredo6 said:
              Bep,
              It could be just:
              • colors
              Fredo, i understand and foresaw the difficulty about the icons your explaining.
              That is why i asked for a not to fancy script in the first place.
              Sam's script almost worked for me, if only it was not limited to Sketchup files.
              "I could modify my own button icon, and change the filepath in the ruby script to the file i need to open."
              If i needed another tool button to launch another file, i would just copy and rename the ruby script, and put other icons and an other filepath in it.
              I could than if i wanted the tool buttons in one toolbar, make a custom toolbar with these buttons placed together in it.
              Bep
                glro
                @bep said:
                @fredo6 said:
                Bep,
                It could be just:
                • colors
                Bep
                UI.openURL ("") is the code to open any file
                this is an example that shows an image on my screen at ""C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\logo.jpg""
                just change to the file you need to open
                you can change that too
                tb = UI::Toolbar.new("Toolbar Name")
                cmd = UI::Command.new("Plugin Name") { Sketchup.open_file UI.openURL("C:\\Users\\glro\\AppData\\Roaming\\SketchUp\\SketchUp 2016\\SketchUp\\Plugins\\MTX\\logo.jpg") }
                cmd.tooltip = "Plugin Name"
                cmd.status_bar_text = "Plugin Name"
                cmd.large_icon = File.join(File.dirname(__FILE__), "MCT_LRO.png")
                cmd.small_icon = File.join(File.dirname(FILE), "MCT_LRO.png")
                tb.add_item(cmd)
                tb.show unless tb.get_last_state == 0
                  glro
                  this is a better version, based on TIG's code in the plugin MIRROR to add a button:
                  replace
                  C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf
                  by the path to your file
                  replace the name of module and definition also, and the name of the png file
                  ` require "sketchup"
                  module MTX
                  def MTX.notice
                  UI.openURL("C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf")
                  unless file_loaded?(File.basename(FILE))###
                  UI.menu("Plugins").add_item("MTX_Notice Metrix"){MTX.notice}
                  Context menu
                  #=begin
                  UI.add_context_menu_handler do |menu|### v3.5 TIG
                  if Sketchup.active_model.selection[0]
                      #menu.add_separator
                      menu.add_item("Notice Metrix"){Sketchup.active_model.select_tool(MTX.notice)}
                  end#if
                  end#do menu###
                  #=end
                  Toolbar - only adds the toolbar IF there's an icon png with it ###v3.2
                  png=File.join(File.dirname(FILE),"MTX_notice_Metrix.png")
                  if FileTest.exist?(png)
                  tb=UI::Toolbar.new("Notice Metrix")
                  cmd=UI::Command.new("MI"){Sketchup.active_model.select_tool(MTX.notice)}
                  cmd.large_icon=png
                  cmd.small_icon=png
                  cmd.tooltip="Notice Metrix"
                  cmd.status_bar_text="Notice Metrix: afficher..."
                  tb.add_item(cmd)
                  if tb.get_last_state==TB_NEVER_SHOWN
                  tb.show
                  elsif tb.get_last_state==TB_VISIBLE
                  tb.restore
                  end#if state
                  end#if toolbar
                  end#if loaded
                  file_loaded(File.basename(FILE))`
                    rv1974
                    Rather bizarre request..
                    Why one won't just put any desired desktop shortcut instead?
                      glro
                      maybe because when sketchup fills your screen entirely, you have to close or reduce the sketchup window to access the shortcut
                      if the shortcup is inside the sketchup window, you can access it directly
                      each clic matters...
                      • BepB Offline
                        Bep
                        @glro said:
                        @bep said:
                        @fredo6 said:
                        Bep,
                        It could be just:
                        • colors
                        Bep
                        tb.add_item(cmd)
                        Thank you very much Glro,
                        I got the script opening a file just as i requested.
                        However the file will pup up in front of the Sketchup-window, and than in a split second hides behind it.
                        I have to click the file icon on the taskbar or reach for the file-window behind the Sketchup-window, to click it, and to get it in front of the Sketchup-window again.
                        I hope i can figure out how the fix this last bit.
                        Bep
                        • BepB Offline
                          Bep
                          Hello rv1974,
                          do not judge too quickly.
                          In my case its not that bizarre.
                          The tool-button will be part of a toolbar that is used in a repetitive process.
                          One part of the process is opening office file's to copy and paste from and to.
                          All parts of the process are in one toolbar, in the correct sequence from left to right.
                          Setting up these machines with all the right files and ruby's in one .rbz is the goal for meantime.
                          The ultimate goal however is to try to automate the whole process.(taking small steps)
                          Bep
                            Some years ago I modified a little script file so it would open the calculator program in windows. It could be modified to open any program I expect. And looking at the thread, I suppose you could add a toolbar although I would prefer a keyboard shortcut.
                            • BepB Offline
                              Bep
                              Dave, i remember your calc.rb
                              imho keyboard shortcuts would be less efficient, be course i would have to install them on every machine next to Sketchup and all the necessary ruby's.
                              Than i would have put sticky notes on every PC-machine with the keybord -shortcuts and instruct all persons working with these machine's.
                              The way i see it, Sketchup with this toolbar could work as a sort off switchboard to all the necessary files and programs.
                              Bep
                                Didn't Sahi have a plugin to open a folder/file location?
                                  glro
                                  Bep
                                  on my computer, the opened file stays on top on the sketchup window
                                    glro
                                    Just ONE Win+D (Alt+Tab if it's open) hit! And thisrequires a dedicated plugin??
                                    And to pin a File or Folder to the Windows 7 Taskbar won't ease solve your problem either?
                                    the "dedicated plugin" is such an easy one..no big deal
                                    and from what i understand, it is the beginning of something else
                                    i just tried to help
                                      rv1974
                                      And to pin a File or Folder to the Windows 7 Taskbar won't solve your problem either?
