    [REQ] Plugin "open file"
    23 Posts 8 Posters 2.7k Views 8 Watching
    • fredo6F Offline
      Bep,
      Actually, the main difficulty is to decide on the icons displayed in the toolbar.
      It could be just:
      • colors
      • Letters, like A, B, C, .... or numbers
      • thumbnail of files (more difficult, and not differentiating since rather based on file type)
      • a set of predefined icons
      In any case, someone has to design these icons.
      • BepB Offline
        Bep
        @fredo6 said:
        Bep,
        It could be just:
        • colors
        Fredo, i understand and foresaw the difficulty about the icons your explaining.
        That is why i asked for a not to fancy script in the first place.
        Sam's script almost worked for me, if only it was not limited to Sketchup files.
        "I could modify my own button icon, and change the filepath in the ruby script to the file i need to open."
        If i needed another tool button to launch another file, i would just copy and rename the ruby script, and put other icons and an other filepath in it.
        I could than if i wanted the tool buttons in one toolbar, make a custom toolbar with these buttons placed together in it.
        Bep
        "History is written by the winners"
          glro
          @bep said:
          @fredo6 said:
          Bep,
          It could be just:
          • colors
          Bep
          UI.openURL ("") is the code to open any file
          this is an example that shows an image on my screen at ""C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\logo.jpg""
          just change to the file you need to open
          you can change that too
          tb = UI::Toolbar.new("Toolbar Name")
          cmd = UI::Command.new("Plugin Name") { Sketchup.open_file UI.openURL("C:\\Users\\glro\\AppData\\Roaming\\SketchUp\\SketchUp 2016\\SketchUp\\Plugins\\MTX\\logo.jpg") }
          cmd.tooltip = "Plugin Name"
          cmd.status_bar_text = "Plugin Name"
          cmd.large_icon = File.join(File.dirname(__FILE__), "MCT_LRO.png")
          cmd.small_icon = File.join(File.dirname(FILE), "MCT_LRO.png")
          tb.add_item(cmd)
          tb.show unless tb.get_last_state == 0
            glro
            this is a better version, based on TIG's code in the plugin MIRROR to add a button:
            replace
            C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf
            by the path to your file
            replace the name of module and definition also, and the name of the png file
            ` require "sketchup"
            module MTX
            def MTX.notice
            UI.openURL("C:\Users\glro\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins\MTX\notice_metrix_2016_bd.pdf")
            unless file_loaded?(File.basename(FILE))###
            UI.menu("Plugins").add_item("MTX_Notice Metrix"){MTX.notice}
            Context menu
            #=begin
            UI.add_context_menu_handler do |menu|### v3.5 TIG
            if Sketchup.active_model.selection[0]
                #menu.add_separator
                menu.add_item("Notice Metrix"){Sketchup.active_model.select_tool(MTX.notice)}
            end#if
            end#do menu###
            #=end
            Toolbar - only adds the toolbar IF there's an icon png with it ###v3.2
            png=File.join(File.dirname(FILE),"MTX_notice_Metrix.png")
            if FileTest.exist?(png)
            tb=UI::Toolbar.new("Notice Metrix")
            cmd=UI::Command.new("MI"){Sketchup.active_model.select_tool(MTX.notice)}
            cmd.large_icon=png
            cmd.small_icon=png
            cmd.tooltip="Notice Metrix"
            cmd.status_bar_text="Notice Metrix: afficher..."
            tb.add_item(cmd)
            if tb.get_last_state==TB_NEVER_SHOWN
            tb.show
            elsif tb.get_last_state==TB_VISIBLE
            tb.restore
            end#if state
            end#if toolbar
            end#if loaded
            file_loaded(File.basename(FILE))`
              rv1974
              Rather bizarre request..
              Why one won't just put any desired desktop shortcut instead?
                glro
                maybe because when sketchup fills your screen entirely, you have to close or reduce the sketchup window to access the shortcut
                if the shortcup is inside the sketchup window, you can access it directly
                each clic matters...
                • BepB Offline
                  Bep
                  @glro said:
                  @bep said:
                  @fredo6 said:
                  Bep,
                  It could be just:
                  • colors
                  Bep
                  tb.add_item(cmd)
                  Thank you very much Glro,
                  I got the script opening a file just as i requested.
                  However the file will pup up in front of the Sketchup-window, and than in a split second hides behind it.
                  I have to click the file icon on the taskbar or reach for the file-window behind the Sketchup-window, to click it, and to get it in front of the Sketchup-window again.
                  I hope i can figure out how the fix this last bit.
                  Bep
                  • BepB Offline
                    Bep
                    Hello rv1974,
                    do not judge too quickly.
                    In my case its not that bizarre.
                    The tool-button will be part of a toolbar that is used in a repetitive process.
                    One part of the process is opening office file's to copy and paste from and to.
                    All parts of the process are in one toolbar, in the correct sequence from left to right.
                    Setting up these machines with all the right files and ruby's in one .rbz is the goal for meantime.
                    The ultimate goal however is to try to automate the whole process.(taking small steps)
                    Bep
                      Some years ago I modified a little script file so it would open the calculator program in windows. It could be modified to open any program I expect. And looking at the thread, I suppose you could add a toolbar although I would prefer a keyboard shortcut.
                      • BepB Offline
                        Bep
                        Dave, i remember your calc.rb
                        imho keyboard shortcuts would be less efficient, be course i would have to install them on every machine next to Sketchup and all the necessary ruby's.
                        Than i would have put sticky notes on every PC-machine with the keybord -shortcuts and instruct all persons working with these machine's.
                        The way i see it, Sketchup with this toolbar could work as a sort off switchboard to all the necessary files and programs.
                        Bep
                          Didn't Sahi have a plugin to open a folder/file location?
                            glro
                            Bep
                            on my computer, the opened file stays on top on the sketchup window
                              glro
                              Just ONE Win+D (Alt+Tab if it's open) hit! And thisrequires a dedicated plugin??
                              And to pin a File or Folder to the Windows 7 Taskbar won't ease solve your problem either?
                              the "dedicated plugin" is such an easy one..no big deal
                              and from what i understand, it is the beginning of something else
                              i just tried to help
                                rv1974
                                And to pin a File or Folder to the Windows 7 Taskbar won't solve your problem either?
