    [Plugin] Animator - v4.6a - 18 Dec 25
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    602 Posts 120 Posters 2.3m Views 120 Watching
    • T
      tomaszdrgas
      "Fog" doesn't change smoothly between cameras, like "shadows" and "field of view" does. It just jumps to next style's value.
      "date" for shadows. If I have to cameras based on sceens with two different dates (june and october), it causes jumping creasy shadows. not often people would use that but that little thing to fix.
      As well when adding camera based on sceen, using styles, layers visibility and shadows connected to camera could be by default turned on (seems good to me).
      When using camera captured from current view, options for using shadows, layers and styles attached to camera are not greyed out.. Is it becuse you can attach them? When I clicked shadows on, than it stopped the animation at the end of duration of previous camera.. so seems like it lucked of informations.. OOKK that was becouse I didn't turn on shadows on when capturing the camera.. When I chose the camera and recaptured with new shadows it worked.. though would be good it there was something in memory even if I don't turned it on..
      There is nice smoothing of the path between the possitions of ongoing cameras. So the path of camera is a nice curve. (with bezzier) But speed is stil interpolated only between two consecutive cameras so there is no smooth change of sppeed in the point of camera's placement.. this one could be "eased" too... I was hoping for that ..
      Tomasz
      • T
        tomaszdrgas
        To Fredo6 - Just very curious.. Are you a man or an institution.. Somehow can not fit it in my small head that someone having regular job, does all that work with plugins for free as a hobby in free time.. It seems not an easy thing to write it and you do a LOT..
        Big thanks... for all..
        • fredo6F
          fredo6
          I am alone, and does not even have lot of free time. So progress is slow!..., considering I wrote my plugins over 10 years now.
          Fredo
          • fredo6F
            fredo6
            Fog is not supported (yet) in Animator. So it does not do any interpolation
            Animator interpolates between the two dates. So, between June and October, you'll get many nights and days! What I think should be a nice add-on is to keep the day-time of the first day specified, and shows how the shadow becomes on the other days. I'll introduce this in a next version.
            Views (and Scene) sequencesare always captured with all style elements. However, the style can be enabled or disabled for the elementsin the timeline. I could not make my mind about the default (currrently style is Off). I guess some users would use views just for the camera positioning and treat styles independently, via visual effects.
            I plan to introduce a Travelling camera, where there is a control over the speed of camera (constant or eased or dependent on curvature of the path).
            Fredo
            • T
              tomaszdrgas
              So I opened the same file today and animation again stopped on the end of duration of sceen camera before the "capture view" camera with attached shadow.. I thought maybe I haven't saved something yesterday. So I recaptured the view with changed shadow, saved inside animator and after going out of it.. Don't remember on which save I had notification " C file 5 exception ...bla bla bla" These are only worlds I remember. I didn't knew whats that about.. sKetchup was still working all looked fine..
              I opened new file to again reopen my test animation and then I found test.skp is gone.. I saved twice so I could just use skb without problems but that was strange.. And happened second time this week just before I didn't connect it with another test file missing.. I'll show you the message if it happens again..
              test2 MP4.skp
              • fredo6F
                fredo6
                Tomasz,
                There is a small bug in the interpolation of shadows. Something weird, since apparently a shadow may not have a time defined ( shadow["ShadowTime_time_t"] is nil).
                I fixed it and will republished.
                I doubt however that this can provoke a "C File5 exception", but it creates a problem in the animation of view.
                Also, Animator just saves the animation data in the model, but cannot erase the skp file itself.
                Fredo
                PS: I noticed that you also lost the spinning of the wheels. I re-established it in the attached skp.
                tomasz - test2 MP4.skp
                • T
                  tomaszdrgas
                  I was looking for a way to remove some objects from the movement and adding others without deleting and creating another movement.. though I was uneable to do so.. probably some luck of click somewhere.. I haven't noticed it in tutorial..
                  I could go into edition of movement and select some but green arrow with dot for saving changes would stay greyed out.. When I deselected all (using arrow with x sign provided in animator) and selected what I wanted then green was green but all stopped spinning. I was going to look for that myself not to bother pros with such a littlies.. but I tried and no more ideas..
                  And the wheels spin opposite way than the arrow shows even though angle is possitive. When I change to negative (-795) they spin opposite direction but arrow aswell changed to opposite so it is always pointing wrong..
                  I'm actually childish proud of myself that I have actually foud a bag.. I mean you did, but... I helped..
                  I don't know who did it, but the file did dissapear. And in place of it was another file 1.skb . With same (about) time of creation like the time of dissapearing. And with date for a day ealier when simillar thing happend I have 0.skb file. So deffiniatelly something strange.
                  Tomasz
                  For a guy with no much time you answer with a light speed.. hollidays?
                  • fredo6F
                    fredo6
                    Tomasz
                    Here is the model with all wheels spinning correctly.
                    I also enclosed the movement (Transalation and spinnings) into a clip, so you can reuse it in the animation, changing the distance and direction (via dimming factor).
                    Film 1.mov
                    In a next version, I'll do something to make the cloning of elements and sequences easier to manage.
                    For the question of 1.skp, I guess this is not related directly to Animator. If you look at Forum, you'll see that this happens in various situations.
                    Fredo
                    • T
                      tomaszdrgas
                      Sorry for trouble but I know how to meke the spin.. in corect speed.. What I ment was..
                      I have made rotate movement for 4 wheels. So 2 of them were moving opposite direction cos they were scaled *-1. I wanted without deliting movement itself remove two wheels from it.. Couldn't do it so..
                      Only way I know is deliting the movement for 4 wheels and meke new one for 2 wheels on one side and another for other side.
                      Editing values - Works. Editing selection - Don't know if possible.
                      Thanks again..
                      • jgbJ
                        jgb
                        Fredo6, a favor please.
                        I just discovered your animation plugin, and went through this thread (quickly). It's installed but I have not yet played with it.
                        In the lead thread there is your usual documentation section and I well understand you have not (yet?) produced a .PDF guide. Instead you have references to 3 tutorials.
                        Could you please convert those references into clickable links?
                        jgb
                        jgb
                        • fredo6F
                          fredo6
                          Just fixed the link (polluted by an old bug in the forum, adding http: in URL).
                          Note that many videos are based on an older version of the GUI, but I guess you'll find your way with the updated GUI.
                          Fredo
                          • jgbJ
                            jgb
                            Thank you.
                            This old dog has difficulty learning new tricks.
                            I've tried many SU based animators over the years starting with SketchyPhysics (almost got the hang of it). Others left me wanting, others way too complex or plain unusable. I need a simple animator without the physics complications, so I hope, based on the quality and functions of your stuff, most of which I use daily (Curviloft in particular), this rendition of an SU animator will do the trick.
                            jgb
                            • fredo6F
                              fredo6
                              New Release: Animator - v1.7c - 16 Aug 17
                              Requirement: LibFredo6 v7.7c
                              Minor release
                              • bug fixing
                              • First support of VRay (v3.40.04) for rendering of animations
                              See main post for RBZ files
                              • T
                                tomaszdrgas
                                I guess easiest would be interpolating date and hour seperately.
                                • fredo6F
                                  fredo6
                                  Definitely.
                                  If the two dates are separated by less than 24 hours, then interpolate the dates
                                  Otherwise, interpolate the days, but keeping the same hour.
                                  Fredo
                                  • vaillyV
                                    vailly
                                    Nice job again Fredo6.
                                    Is it possible to animate the "sun" to see the shadow of a building moving from early in the morning through the night?
                                    Thanks,
                                    François
                                    • fredo6F
                                      fredo6
                                      This is possible with the Visual Effect "Shadow"
                                      In the timeline,
                                      • put a first one with the date/time of early morning
                                      • put a second one with the date/time of late evening at the end (based on your video duration)
                                      Shadow is a visual effect. So it can be combined with object and camera movements and with other visual effects (zoom, etc...).
                                      Note that if the two date/time are separated with more than 24h, then you'll get a Season shadow animation. This is how you can simulate the shadow across several days, months or years.
                                      Fredo
                                      • fredo6F
                                        fredo6
                                        New Release: Animator - v1.8a - 02 Nov 17
                                        Requirement: LibFredo6 v7.9a
                                        Minor release
                                        • bug fixing
                                        • First batch of Performance improvement for large models
                                        • M
                                          Mike598601
                                          Hey Fredo, you are genius 😄 I love animator
                                          I tried rendering a clip in Twilight V2 pro, only 2 second duration (51 frames) - 30 hours in it had rendered 14 clips, so I decided to purchase V-Ray and upgraded LibFredo6 to 7.9 and animator to 1.8 as it says Vray is supported. Tried to render the same animation and it only took 1.5 hours - an amazing improvement!! I saw every frame rendering, However, the resulting movie, both MP4 and MOV were both only 1 frame long 😞 - Have I missed something? Can you advise me please?
                                          Keep up the brilliant work!!!
                                          • fredo6F
                                            fredo6
                                            For animation, I don't think you need super-rendering. If you have only 51 frames, with a rendering of 10 s, you should keep it under 10 minutes, whether Twilight or VRay.
                                            Could you post or PM your model, so that I see how it renders with Vray and Twilight.
                                            Fredo
