    Is it possible to distribute vertices uniformly?
    8 Posts 4 Posters 979 Views 4 Watching
    • alsomarA
      alsomar Extension Creator
      Well, that's the question: Is it possible to distribute the vertices from a quad mesh uniformly? I mean if is there a way to avoid doing it manually or starting again from zero. Is there any extension to convert the right mesh into the left mesh?
      http://i.imgur.com/zyC6nHj.png?1
      Alejandro Soriano Visuals · All my links
        No, but I did ask Thomthom to add this to SUbD because some type of relax is needed.
        • alsomarA
          First of all I have to say I can't write a single line of code, but I think it could fit better including this feature in Vertex Tools. You should be able to select a single loop and distribute the distances between its vertices, makes sense?
          http://i.imgur.com/029ZcWp.jpg
          • Z
            ZahariStoyanov
            Yes, that would come in handy! 😄
            • sdmitchS
              sdmitch
              Something like this?
              http://sdmitch.blogspot.com/
              • alsomarA
                That looks really nice! Does it work distributing non-coplanar vertices/edges?
                • sdmitchS
                  sdmitch
                  I don't know but, if you would like to post a SU2014 sample of what you are referring to, I will test it.
                  • alsomarA
                    Ok, thank you so much! I've uploaded a sample here:
                    https://www.dropbox.com/s/naim6y7o6ys57iv/quad-mesh.skp?dl=0
                    Looks like this:
                    http://i.imgur.com/2pGXj2j.png
