    [Preview] Wrap-R Video #2
    extensions
    72 Posts 26 Posters 19.6k Views 26 Watching
      Here's an update to where Wrap-R is at....
      Direct .skp import/export.
      Full SketchUp control scheme in Wrap-r (e.g. Middle Mouse Rotate, M to move, S to scale, Q to rotate etc..)
      UV Layout export to .svg for external texture painting support.
      UV shell flipping, pinning and unpinning
      Enjoy the weekend!
      • massimoM Offline
        massimo Moderator
        Rich, what are the big differences between this and the OBJ export/import feature of SketchUV plugin?
          SketchUV still means the user needs to learn an familiar environment to unwrap.
          Wrap-R will be using the same controls, shortcuts and behaviour as SU.
          Plus SketchUV doesn't unwrap. It maps by projection methods. Or it exports to OBJ where you then unwrap.
          Users want a solution that behaves like SU and does things simpler.
          Anyone that already is quite comfortable in a 3rd partly UV tool won't see much benefit. Anyone who can't quite get to grips why 3rd party tools do things different than SU will get benefits.
          Horses for courses.
          • F Offline
            faust07
            πŸ‘ that's the right way for us SU users! πŸ‘
            • massimoM Offline
              massimo Moderator
              Ok, I see. Thanks.
              • PixeroP Offline
                Pixero
                Looking good! πŸ‘
                Now I've started drooling again...
                Will the shortcuts be the same as the user have set them to inside SU?
                I don't use the standard keys.
                  Shortcuts can be changed.
                  • FrederikF Offline
                    Frederik
                    This looks better and better...!! πŸ‘
                    And this awesome plugin is expected to be ready for release by...?!?
                    Excuse my ignorance, but that unwrapped texture map with the "funny" shapes, will it become available for use in applications like Allegorithmic - or is the purpose that user only need a normal square texture map to make amendments to the texture...?!?
                    I.e. how will I be able to add dirt to a map and know exactly where it will be on my model...?
                    Cheers
                    Kim Frederik
                      A tricky teasing! πŸ˜„
                      With a frenzied music ! πŸ’š
                      • JQLJ Offline
                        JQL
                        Yup... this is great!
                        ETA?
                        www.casca.pt
                        Visit us on facebook!
                        • JQLJ Offline
                          JQL
                          Kim,
                          Once you have an unwrapped model, the rest is taken care of in Substance procedurally.
                          If you'll be using substance you'll have no problem with that.
                          Problem will be there only for people that Unwrap, paint their textures manually on an editor, and then change their models and have to reunwrap them. I don't know if there will be a way to make a model conform to the previous texture...
                          Blender does this. You move a vertex and it doesn't change the unwrapping, the texture fits to the triangle/quad no matter what happens to it. I don't know if this will be possible in SU, hence I keep asking for it.
                          www.casca.pt
                            @fred
                            You can export your unwrap to svg and do whatever you want in your image editor.
                            If you export the model to .obj from Wrap-R you can then go to Substance Painter...
                            • JQLJ Offline
                              JQL
                              Then you simply create a material based on the textures exported from painter/designer.
                              In your case you can, of course, use Thea Converter and apply those materials directly in SU with the help of T4SU or thrupaint.
                              www.casca.pt
                              • JQLJ Offline
                                JQL
                                @Rich,
                                Will we also be able to import textures directly into unwrapper or will we have to work with SU textures?
                                www.casca.pt
                                • FrederikF Offline
                                  Frederik
                                  This is EXCELLENT...!!! πŸ’š
                                  Thanks, Rich...!
                                  And also thanks for your comments, JoΓ£o... πŸ‘
                                  Cheers
                                  Kim Frederik
                                    @jql
                                    world is your oyster once you have a uv map.
                                    without one you can't bake normals, ao etc...
                                    texture import is vital but not from the outset. main purpose is to get this out as a minimum viable product and then let the users dictate it's dev.
                                    • soloS Offline
                                      solo
                                      This is so exciting, I cannot wait to try this.
                                      http://www.solos-art.com
                                      • JQLJ Offline
                                        JQL
                                        @rich o brien said:
                                        @jql
                                        You're absolutelly right!
                                        Also, my concerns are really not aiming at my current workflow as I'm using substance and as you say the only thing I need is an UV map and doing it with sketchup tools.
                                        Basically, I need only what you have right now!
                                        But I just cannot help pestering you, it's a way to feel involved already. Will it also be easy to select some edges and rotate them or edit them somehow so they get absolutelly vertical or horizontal?
                                        That would help a lot in some architectural workflows and I cannot do it with blender (I know it's pbcac... don't shove that on me! πŸ˜„)
                                        www.casca.pt
                                        • cmeedC Offline
                                          cmeed
                                          looks amazing....
                                          c
                                            "Will it also be easy to select some edges and rotate them or edit them somehow so they get absolutely vertical or horizontal?
                                            Will it?
                                            It can do it already πŸ˜‰
                                            Align to top,bottom, left and right. Pin points too. And Relax.
                                            • 4 / 4
